root/radiance/ray/src/px/SConscript
Sun Apr 27 17:22:49 2008 UTC (16 years, 11 months ago) by schorsch
Diff to previous 1.17
Thu Apr 24 10:28:25 2008 UTC (17 years ago) by schorsch
Diff to previous 1.16
Mon Apr 21 07:31:29 2008 UTC (17 years ago) by schorsch
Changes since 1.15: +9 -9 lines
Diff to previous 1.15
Scons update for mingw.
Fri Mar 10 19:40:13 2006 UTC (19 years, 1 month ago) by schorsch
Changes since 1.14: +4 -13 lines
Diff to previous 1.14
Sat Sep 17 07:45:11 2005 UTC (19 years, 7 months ago) by schorsch
Diff to previous 1.13
Added pmdblur.csh and ran2tiff.csh install for SCons.
Wed Sep 14 09:26:25 2005 UTC (19 years, 7 months ago) by schorsch
Diff to previous 1.12
Cleaned up tifflib support (don't copy header files to common during build).
Mon Sep 12 14:44:09 2005 UTC (19 years, 7 months ago) by schorsch
Changes since 1.11: +27 -6 lines
Diff to previous 1.11
Updates to SConscripts for 3R7.
Thu Feb 10 16:43:08 2005 UTC (20 years, 2 months ago) by schorsch
Diff to previous 1.10
Install ra_pvm.csh on posix systems.
Mon Nov 8 19:24:46 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 1.9: +2 -3 lines
Diff to previous 1.9
Fri Nov 5 22:15:43 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 1.8: +0 -51 lines
Diff to previous 1.8
Sat Oct 23 18:55:52 2004 UTC (20 years, 6 months ago) by schorsch
CVS Tags: rad3R6P1
Changes since 1.7: +6 -2 lines
Diff to previous 1.7
Thu Oct 21 15:47:12 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.6: +27 -24 lines
Diff to previous 1.6
SCons build simplifications.
Tue Jul 6 11:49:09 2004 UTC (20 years, 9 months ago) by schorsch
Changes since 1.5: +5 -4 lines
Diff to previous 1.5
Sun Jul 4 12:08:48 2004 UTC (20 years, 9 months ago) by schorsch
Diff to previous 1.4
Fri Mar 26 21:32:01 2004 UTC (21 years, 1 month ago) by schorsch
Diff to previous 1.3
Added new ra_bmp.c.
Fri Jan 2 23:27:43 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 1.2: +5 -4 lines
Diff to previous 1.2
Made tifflib compile a bit more robust.
Mon Oct 27 10:35:43 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.1: +98 -83 lines
Tue Oct 21 19:27:29 2003 UTC (21 years, 6 months ago) by schorsch
