root/radiance/ray/src/px/SConscript
Revision: 1.11
Committed: Thu Feb 10 16:43:08 2005 UTC (19 years, 2 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1
Install ra_pvm.csh on posix systems.
# User Rev Content
1 schorsch 1.1 import os
2
3     Import('env') # inherit from parent
4
5 schorsch 1.7 mlib = ['$RAD_MLIB']
6     progs = []
7 schorsch 1.1
8     # compose paths
9 schorsch 1.7 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10     #def radbin(name): return name
11     def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
12 schorsch 1.2
13     warp3d = env.Object(source="warp3d.c")
14     clrtab = env.Object(source="clrtab.c")
15     neuclrtab = env.Object(source="neuclrtab.c")
16 schorsch 1.1
17     # standard targets
18     PROGS = (
19 schorsch 1.2 # name files libs
20     ('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d],
21     ['rtpic','rtproc','rtpath','rtio','rtargs','rtcont','rtmem','rterror']),
22     ('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d],
23     ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtcont','rtmem','rterror']),
24     ('pfilt', Split('pfilt.c pf2.c pf3.c'),
25     ['rtlamps','rtpic','rtio','rtpath','rtargs','rtmath']),
26 schorsch 1.10 ('pcwarp', ['pcwarp.c', warp3d],
27     ['rtpic','rtio','rtcont','rtmem','rterror']),
28 schorsch 1.2 ('pvalue', ['pvalue.c'], ['rtpic','rtio','rtargs','rtmath']),
29     ('pcompos', ['pcompos.c'], ['rtpic','rtproc','rtpath','rtio','rterror']),
30     ('psign', ['psign.c'],
31     ['rtpic','rtscene','rtio','rtpath','rtargs','rtcont','rtmem','rterror']),
32     ('protate', ['protate.c'], ['rtpic','rtio']),
33     ('pextrem', ['pextrem.c'], ['rtpic','rtio']),
34     ('pflip', ['pflip.c'], ['rtpic','rtio']),
35     ('pcomb', ['pcomb.c'],
36     ['rtpic','rtproc','rtpath','rtio','rtfunc','rtargs','rtmath','rtcont','rtmem']),
37     ('pinterp', ['pinterp.c'],
38     ['rtproc','rtpic','rtio','rtpath','rtargs','rtmath','rtmem','rterror']),
39
40     ('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
41     ('ra_ps', ['ra_ps.c'], ['rtpic','rtio','rtargs','rtmem']),
42     ('ra_ppm', ['ra_ppm.c'], ['rtpic','rtio','rtmem']),
43 schorsch 1.8 ('ra_bmp', ['ra_bmp.c'], ['rtpic','rtproc','rtio','rtmem']),
44 schorsch 1.2 ('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
45     ('ra_t16', ['ra_t16.c'], ['rtpic','rtio','rtmem']),
46     ('ra_rgbe', ['ra_rgbe.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']),
47     ('ra_pict', ['ra_pict.c'], ['rtpic','rtio','rtmem']),
48     ('ra_hexbit',['ra_hexbit.c'], ['rtpic','rtio','rtmem']),
49     ('ra_xyze', ['ra_xyze.c'], ['rtpic','rtio','rtmem']),
50 schorsch 1.1
51 schorsch 1.2 ('ttyimage', ['ttyimage.c'], ['rtpic','rtio','rtmem']),
52 schorsch 1.1 )
53     for p in PROGS:
54 schorsch 1.2 prog = env.Program(target=radbin(p[0]), source=p[1],
55 schorsch 1.7 LIBS=p[2]+mlib)
56     progs.append(prog)
57 schorsch 1.1
58
59     # tiff library (unix-specific for the moment)
60     if os.name == 'posix':
61     cwd = os.getcwd()
62 schorsch 1.2 libtiff = env.Command(radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']),
63 schorsch 1.1 'tiff/config.local',
64 schorsch 1.3 [('cd "%s"; '
65     'sh ./configure -quiet -noninteractive '
66     '-with-CC="$CC" -with-ENVOPTS="$CCFLAGS"; '
67     'cd libtiff; '
68     'make install;') % os.path.join(cwd, 'tiff')])
69 schorsch 1.1
70     # tiff programs
71 schorsch 1.2 ra_tiff = env.Program(target=radbin('ra_tiff'), source=Split('ra_tiff.c'),
72     LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
73 schorsch 1.7 progs.append(ra_tiff)
74 schorsch 1.1
75 schorsch 1.2 normtiff = env.Program(target=radbin('normtiff'), source=Split('normtiff.c'),
76     LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
77 schorsch 1.7 progs.append(normtiff)
78 schorsch 1.1
79
80     # X11 targets
81 schorsch 1.2 if env.has_key('X11LIB'):
82 schorsch 1.7 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
83     xlibp = env.get('LIBPATH', []) + ['$X11LIB']
84 schorsch 1.2 xlibs = ['X11','rtpic','rtio','rtmath','rtargs','rtmem']
85 schorsch 1.6 x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice
86 schorsch 1.7 CPPPATH=xincl)
87 schorsch 1.2
88     ximage = env.Program(target=radbin('ximage'),
89     source=Split('x11image.c x11raster.c')+[clrtab],
90 schorsch 1.6 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
91 schorsch 1.7 progs.append(ximage)
92 schorsch 1.1
93 schorsch 1.2 xshowtrace = env.Program(target=radbin('xshowtrace'),
94 schorsch 1.5 source=Split('xshowtrace.c') + [x11findwind],
95 schorsch 1.6 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
96 schorsch 1.7 progs.append(xshowtrace)
97 schorsch 1.1
98
99 schorsch 1.7 if os.name == 'posix': # XXX ignoring trad.wsh
100     for s in Split('''normpat falsecolor pdfblur
101 schorsch 1.11 pmblur xyzimage phisto pdelta pgblur ra_pfm'''):
102 schorsch 1.7 Default(env.InstallCsh(radbin(s), s + '.csh'))
103 schorsch 1.8 # XXX probably needs fixing
104     #else:
105     # for s in Split('''falsecolor'''):
106     # Default(env.InstallCsh(radbin(s), s + '.csh'))
107 schorsch 1.7
108     Default('#src/px')
109     env.Install('$RAD_BINDIR', progs)
110
