root/radiance/ray/src/px/SConscript
Revision: 1.24
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 3 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Changes since 1.23: +15 -9 lines
1 from __future__ import division, print_function, unicode_literals
2
3 import os
4
5 Import('env') # inherit from parent
6
7 mlib = ['$RAD_MLIB']
8 progs = []
9
10 # compose paths
11 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
12 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
13
14 warp3d = env.Object(source="warp3d.c")
15 clrtab = env.Object(source="clrtab.c")
16 neuclrtab = env.Object(source="neuclrtab.c")
17
18 # standard targets
19 PROGS = (
20 # name files libs
21 ('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d], ['rtrad']),
22 ('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d], ['rtrad']),
23 ('pfilt', Split('pfilt.c pf2.c pf3.c'), ['rtrad']),
24 ('pcwarp', ['pcwarp.c', warp3d], ['rtrad']),
25 ('pvalue', ['pvalue.c'], ['rtrad']),
26 ('pcompos', ['pcompos.c'], ['rtrad']),
27 ('psign', ['psign.c'], ['rtrad']),
28 ('protate', ['protate.c'], ['rtrad']),
29 ('pextrem', ['pextrem.c'], ['rtrad']),
30 ('pflip', ['pflip.c'], ['rtrad']),
31 ('pcomb', ['pcomb.c'], ['rtrad']),
32 ('pinterp', ['pinterp.c'], ['rtrad']),
33 ('psketch', ['psketch.c'], ['rtrad']),
34
35 ('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtrad']),
36 ('ra_ps', ['ra_ps.c'], ['rtrad']),
37 ('ra_ppm', ['ra_ppm.c'], ['rtrad']),
38 ('ra_bmp', ['ra_bmp.c'], ['rtrad']),
39 ('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtrad']),
40 ('ra_t16', ['ra_t16.c'], ['rtrad']),
41 ('ra_rgbe', ['ra_rgbe.c'], ['rtrad']),
42 ('ra_pict', ['ra_pict.c'], ['rtrad']),
43 ('ra_hexbit',['ra_hexbit.c'], ['rtrad']),
44 ('ra_xyze', ['ra_xyze.c'], ['rtrad']),
45 ('pmblur2', ['pmblur2.c'], ['rtrad']),
46
47 ('ttyimage', ['ttyimage.c'], ['rtrad']),
48 )
49 for p in PROGS:
50 prog = env.Program(target=radbin(p[0]), source=p[1],
51 LIBS=p[2]+mlib)
52 progs.append(prog)
53
54
55 # tiff library (building it is unix-specific for the moment)
56 # If we haven't found one supporting LogLuv installed, build our own.
57 libtiff_fn = radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX'])
58 if os.name == 'posix' and not env.get('TIFFLIB_INSTALLED'):
59 cwd = os.getcwd()
60 upperdir = os.path.split(cwd)[0]
61 libtiff = env.Command(libtiff_fn, None,
62 [('cd "%(tiffdir)s"; '
63 'env CC="$CC" '
64 './configure -C '
65 '"libdir=%(upperdir)s/lib" '
66 '--enable-static --disable-shared --disable-cxx '
67 '--enable-logluv --disable-jpeg --disable-zlib --disable-pixarlog; '
68 'cd %(portdir)s; make all;'
69 'cd %(libtiffdir)s; make install-exec;' # don't install headers
70 ) % {
71 'upperdir':upperdir,
72 'tiffdir':os.path.join(cwd, 'tiff'),
73 'portdir':os.path.join(cwd, 'tiff', 'port'),
74 'libtiffdir':os.path.join(cwd, 'tiff', 'libtiff')
75 }
76 ])
77
78 env['TIFFLIB_INSTALLED'] = 1
79
80 if os.name == 'posix': # cleanup action for a previously built tifflib
81 Clean(libtiff_fn, [libtiff_fn, radlib(env['LIBPREFIX'] + 'tiff.la')])
82
83 if env.get('TIFFLIB_INSTALLED'):
84 libtiff = env.get('RAD_LIBTIFF')
85 # tiff programs
86 tiffi = env.get('RAD_TIFFINCLUDE')
87 if tiffi: tiffincl = [tiffi] + env.get('CPPPATH', [])
88 else: tiffincl = env.get('CPPPATH', [])
89 tiffl = env.get('RAD_TIFFLIB')
90 if tiffl: tifflib = [tiffl] + env.get('LIBPATH', [])
91 else: tifflib = env.get('LIBPATH', [])
92
93 ra_tiff = env.Program(target=radbin('ra_tiff'), source=['ra_tiff.c'],
94 CPPPATH = tiffincl, LIBPATH=tifflib,
95 LIBS=[libtiff,'rtrad'] + mlib)
96 progs.append(ra_tiff)
97
98 normtiff = env.Program(target=radbin('normtiff'),source=['normtiff.c'],
99 CPPPATH = tiffincl, LIBPATH=tifflib,
100 LIBS=[libtiff,'rtrad'] + mlib)
101 progs.append(normtiff)
102
103
104 # X11 targets
105 if env.has_key('X11LIB'):
106 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
107 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
108 xlibs = ['X11','rtrad']
109 env.x11findwind = env.Object(source='../common/x11findwind.c',
110 CPPPATH=xincl)
111
112 ximage = env.Program(target=radbin('ximage'),
113 source=Split('x11image.c x11raster.c')+[clrtab],
114 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
115 progs.append(ximage)
116
117 xshowtrace = env.Program(target=radbin('xshowtrace'),
118 source=Split('xshowtrace.c') + [env.x11findwind],
119 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
120 progs.append(xshowtrace)
121
122 pyscripts = Split('''falsecolor phisto''')
123 if os.name == 'posix': # XXX ignoring trad.wsh
124 for s in Split('''normpat pdfblur pmblur pmdblur
125 xyzimage pgblur ra_pfm ran2tiff pbilat'''):
126 Default(env.InstallScript(radbin(s), s + '.csh'))
127 for s in pyscripts:
128 Default(env.InstallScript(radbin(s), s + '.py'))
129 else:
130 for s in pyscripts:
131 Default(env.InstallScript(radbin(s + '.py'), s + '.py'))
132
133
134 # ignored by Rmakefile: pacuity phisteq psquish pveil vlpic
135
136 Default('#src/px')
137 env.Install('$RAD_BINDIR', progs)
138
139 # vim: set syntax=python:
140 # vi: set ts=4 sw=4 :
