1 |
import os |
2 |
3 |
Import('env') # inherit from parent |
4 |
5 |
mlib = ['$RAD_MLIB'] |
6 |
progs = [] |
7 |
8 |
# compose paths |
9 |
def radbin(name): return os.path.join('$RAD_BUILDBIN', name) |
10 |
def radlib(name): return os.path.join('$RAD_BUILDLIB', name) |
11 |
12 |
warp3d = env.Object(source="warp3d.c") |
13 |
clrtab = env.Object(source="clrtab.c") |
14 |
neuclrtab = env.Object(source="neuclrtab.c") |
15 |
16 |
# standard targets |
17 |
PROGS = ( |
18 |
# name files libs |
19 |
('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d], |
20 |
['rtpic','rtproc','rtpath','rtargs','rtio','rtcont','rtmem','rterror']), |
21 |
('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d], |
22 |
['rtpic','rtproc','rtpath','rtargs','rtio','rtmath','rtcont','rtmem','rterror']), |
23 |
('pfilt', Split('pfilt.c pf2.c pf3.c'), |
24 |
['rtlamps','rtpic','rtpath','rtargs','rtio','rtmath']), |
25 |
('pcwarp', ['pcwarp.c', warp3d], |
26 |
['rtpic','rtio','rtcont','rtmem','rterror']), |
27 |
('pvalue', ['pvalue.c'], ['rtpic','rtargs','rtio','rtmath']), |
28 |
('pcompos', ['pcompos.c'], ['rtpic','rtproc','rtpath','rtio','rterror']), |
29 |
('psign', ['psign.c'], |
30 |
['rtpic','rtscene','rtpath','rtargs','rtio','rtcont','rtmem','rterror']), |
31 |
('protate', ['protate.c'], ['rtpic','rtio']), |
32 |
('pextrem', ['pextrem.c'], ['rtpic','rtio']), |
33 |
('pflip', ['pflip.c'], ['rtpic','rtio']), |
34 |
('pcomb', ['pcomb.c'], |
35 |
['rtpic','rtproc','rtpath','rtfunc','rtargs','rtio','rtmath','rtcont','rtmem']), |
36 |
('pinterp', ['pinterp.c'], |
37 |
['rtproc','rtpic','rtpath','rtargs','rtio','rtmath','rtmem','rterror']), |
38 |
39 |
('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']), |
40 |
('ra_ps', ['ra_ps.c'], ['rtpic','rtargs','rtio','rtmem']), |
41 |
('ra_ppm', ['ra_ppm.c'], ['rtpic','rtio','rtmem']), |
42 |
('ra_bmp', ['ra_bmp.c'], |
43 |
['rtpic','rtproc','rterror','rtpath','rtio','rtmem']), |
44 |
('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']), |
45 |
('ra_t16', ['ra_t16.c'], ['rtpic','rtio','rtmem']), |
46 |
('ra_rgbe', ['ra_rgbe.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']), |
47 |
('ra_pict', ['ra_pict.c'], ['rtpic','rtio','rtmem']), |
48 |
('ra_hexbit',['ra_hexbit.c'], ['rtpic','rtio','rtmem']), |
49 |
('ra_xyze', ['ra_xyze.c'], ['rtpic','rtio','rtmem']), |
50 |
('pmblur2', ['pmblur2.c'], ['rtpic','rtargs','rtio','rtargs','rtmath','rtmem','rtcont','rterror',mlib]), |
51 |
52 |
('ttyimage', ['ttyimage.c'], ['rtpic','rtio','rtmem']), |
53 |
54 |
for p in PROGS: |
55 |
prog = env.Program(target=radbin(p[0]), source=p[1], |
56 |
LIBS=p[2]+mlib) |
57 |
progs.append(prog) |
58 |
59 |
60 |
# tiff library (building it is unix-specific for the moment) |
61 |
# If we haven't found one supporting LogLuv installed, build our own. |
62 |
libtiff_fn = radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']) |
63 |
if os.name == 'posix' and not env.get('TIFFLIB_INSTALLED'): |
64 |
cwd = os.getcwd() |
65 |
upperdir = os.path.split(cwd)[0] |
66 |
libtiff = env.Command(libtiff_fn, None, |
67 |
[('cd "%(tiffdir)s"; ' |
68 |
'env CC="$CC" ' |
69 |
'./configure -C ' |
70 |
'"libdir=%(upperdir)s/lib" ' |
71 |
'--enable-static --disable-shared --disable-cxx ' |
72 |
'--enable-logluv --disable-jpeg --disable-zlib --disable-pixarlog; ' |
73 |
'cd %(portdir)s; make all;' |
74 |
'cd %(libtiffdir)s; make install-exec;' # don't install headers |
75 |
76 |
'upperdir':upperdir, |
77 |
'tiffdir':os.path.join(cwd, 'tiff'), |
78 |
'portdir':os.path.join(cwd, 'tiff', 'port'), |
79 |
'libtiffdir':os.path.join(cwd, 'tiff', 'libtiff') |
80 |
81 |
82 |
83 |
env['TIFFLIB_INSTALLED'] = 1 |
84 |
85 |
if os.name == 'posix': # cleanup action for a previously built tifflib |
86 |
Clean(libtiff_fn, [libtiff_fn, radlib(env['LIBPREFIX'] + 'tiff.la')]) |
87 |
88 |
if env.get('TIFFLIB_INSTALLED'): |
89 |
# tiff programs |
90 |
tiffi = env.get('RAD_TIFFINCLUDE') |
91 |
if tiffi: tiffincl = [tiffi] + env.get('CPPPATH', []) |
92 |
else: tiffincl = env.get('CPPPATH', []) |
93 |
tiffl = env.get('RAD_TIFFLIB') |
94 |
if tiffl: tifflib = [tiffl] + env.get('LIBPATH', []) |
95 |
else: tifflib = env.get('LIBPATH', []) |
96 |
97 |
ra_tiff = env.Program(target=radbin('ra_tiff'), source=['ra_tiff.c'], |
98 |
CPPPATH = tiffincl, LIBPATH=tifflib, |
99 |
LIBS=['tiff','rtpic','rtio','rtmem'] + mlib) |
100 |
progs.append(ra_tiff) |
101 |
102 |
normtiff = env.Program(target=radbin('normtiff'),source=['normtiff.c'], |
103 |
104 |
105 |
progs.append(normtiff) |
106 |
107 |
108 |
# X11 targets |
109 |
if env.has_key('X11LIB'): |
110 |
xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] |
111 |
xlibp = env.get('LIBPATH', []) + ['$X11LIB'] |
112 |
xlibs = ['X11','rtpic','rtargs','rtio','rtmath','rtmem'] |
113 |
env.x11findwind = env.Object(source='../common/x11findwind.c', # XXX remote magic |
114 |
CPPPATH=xincl) |
115 |
116 |
ximage = env.Program(target=radbin('ximage'), |
117 |
source=Split('x11image.c x11raster.c')+[clrtab], |
118 |
CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib) |
119 |
progs.append(ximage) |
120 |
121 |
xshowtrace = env.Program(target=radbin('xshowtrace'), |
122 |
source=Split('xshowtrace.c') + [env.x11findwind], # XXX remote magic |
123 |
124 |
progs.append(xshowtrace) |
125 |
126 |
if os.name == 'posix': # XXX ignoring trad.wsh |
127 |
for s in Split('''normpat pdfblur pmblur pmdblur |
128 |
xyzimage phisto pdelta pgblur ra_pfm ran2tiff pbilat'''): |
129 |
Default(env.InstallScript(radbin(s), s + '.csh')) |
130 |
for s in Split('''falsecolor'''): |
131 |
Default(env.InstallScript(radbin(s), s + '.pl')) |
132 |
# XXX probably needs fixing |
133 |
#else: |
134 |
# for s in Split('''falsecolor'''): |
135 |
# Default(env.InstallScript(radbin(s), s + '.pl')) |
136 |
# ignored by Rmakefile: pacuity phisteq psquish pveil vlpic |
137 |
138 |
Default('#src/px') |
139 |
env.Install('$RAD_BINDIR', progs) |
140 |
141 |
# vim: set syntax=python: |
