root/Development/ray/src/px/SConscript
Revision: 1.17
Committed: Thu Apr 24 10:28:25 2008 UTC (17 years, 8 months ago) by schorsch
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 #def radbin(name): return name
11 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
12
13 warp3d = env.Object(source="warp3d.c")
14 clrtab = env.Object(source="clrtab.c")
15 neuclrtab = env.Object(source="neuclrtab.c")
16
17 # standard targets
18 PROGS = (
19 # name files libs
20 ('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d],
21 ['rtpic','rtproc','rtpath','rtargs','rtio','rtcont','rtmem','rterror']),
22 ('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d],
23 ['rtpic','rtproc','rtpath','rtargs','rtio','rtmath','rtcont','rtmem','rterror']),
24 ('pfilt', Split('pfilt.c pf2.c pf3.c'),
25 ['rtlamps','rtpic','rtpath','rtargs','rtio','rtmath']),
26 ('pcwarp', ['pcwarp.c', warp3d],
27 ['rtpic','rtio','rtcont','rtmem','rterror']),
28 ('pvalue', ['pvalue.c'], ['rtpic','rtargs','rtio','rtmath']),
29 ('pcompos', ['pcompos.c'], ['rtpic','rtproc','rtpath','rtio','rterror']),
30 ('psign', ['psign.c'],
31 ['rtpic','rtscene','rtpath','rtargs','rtio','rtcont','rtmem','rterror']),
32 ('protate', ['protate.c'], ['rtpic','rtio']),
33 ('pextrem', ['pextrem.c'], ['rtpic','rtio']),
34 ('pflip', ['pflip.c'], ['rtpic','rtio']),
35 ('pcomb', ['pcomb.c'],
36 ['rtpic','rtproc','rtpath','rtfunc','rtargs','rtio','rtmath','rtcont','rtmem']),
37 ('pinterp', ['pinterp.c'],
38 ['rtproc','rtpic','rtpath','rtargs','rtio','rtmath','rtmem','rterror']),
39
40 ('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
41 ('ra_ps', ['ra_ps.c'], ['rtpic','rtargs','rtio','rtmem']),
42 ('ra_ppm', ['ra_ppm.c'], ['rtpic','rtio','rtmem']),
43 ('ra_bmp', ['ra_bmp.c'], ['rtpic','rtproc','rtio','rtmem']),
44 ('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
45 ('ra_t16', ['ra_t16.c'], ['rtpic','rtio','rtmem']),
46 ('ra_rgbe', ['ra_rgbe.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']),
47 ('ra_pict', ['ra_pict.c'], ['rtpic','rtio','rtmem']),
48 ('ra_hexbit',['ra_hexbit.c'], ['rtpic','rtio','rtmem']),
49 ('ra_xyze', ['ra_xyze.c'], ['rtpic','rtio','rtmem']),
50
51 ('ttyimage', ['ttyimage.c'], ['rtpic','rtio','rtmem']),
52 )
53 for p in PROGS:
54 prog = env.Program(target=radbin(p[0]), source=p[1],
55 LIBS=p[2]+mlib)
56 progs.append(prog)
57
58
59 # tiff library (unix-specific for the moment)
60 if os.name == 'posix':
61 cwd = os.getcwd()
62 upperdir = os.path.split(cwd)[0]
63
64 libtiff = env.Command(radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']),
65 None,
66 [('cd "%(tiffdir)s"; '
67 'env CC="$CC" '
68 './configure -C '
69 '"libdir=%(upperdir)s/lib" '
70 '--enable-static --disable-shared --disable-cxx '
71 '--enable-logluv --disable-jpeg --disable-zlib --disable-pixarlog; '
72 'cd %(portdir)s; make all;'
73 'cd %(libtiffdir)s; make install-exec;' # don't install headers
74 ) % {
75 'upperdir':upperdir,
76 'tiffdir':os.path.join(cwd, 'tiff'),
77 'portdir':os.path.join(cwd, 'tiff', 'port'),
78 'libtiffdir':os.path.join(cwd, 'tiff', 'libtiff')
79 }
80 ])
81
82 # tiff programs
83 ra_tiff = env.Program(target=radbin('ra_tiff'), source=['ra_tiff.c'],
84 LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
85 progs.append(ra_tiff)
86
87 normtiff = env.Program(target=radbin('normtiff'),source=['normtiff.c'],
88 LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
89 progs.append(normtiff)
90
91
92 # X11 targets
93 if env.has_key('X11LIB'):
94 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
95 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
96 xlibs = ['X11','rtpic','rtargs','rtio','rtmath','rtmem']
97 x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice
98 CPPPATH=xincl)
99
100 ximage = env.Program(target=radbin('ximage'),
101 source=Split('x11image.c x11raster.c')+[clrtab],
102 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
103 progs.append(ximage)
104
105 xshowtrace = env.Program(target=radbin('xshowtrace'),
106 source=Split('xshowtrace.c') + [x11findwind],
107 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
108 progs.append(xshowtrace)
109
110 if os.name == 'posix': # XXX ignoring trad.wsh
111 for s in Split('''normpat falsecolor pdfblur pmblur pmdblur pbilat
112 xyzimage phisto pdelta pgblur ra_pfm ran2tiff'''):
113 Default(env.InstallCsh(radbin(s), s + '.csh'))
114 # XXX probably needs fixing
115 #else:
116 # for s in Split('''falsecolor'''):
117 # Default(env.InstallCsh(radbin(s), s + '.csh'))
118 # ignored by Rmakefile: pacuity phisteq psquish pveil vlpic
119
120 Default('#src/px')
121 env.Install('$RAD_BINDIR', progs)
122
