root/Development/ray/src/px/SConscript
Revision: 1.1
Committed: Tue Oct 21 19:27:29 2003 UTC (22 years ago) by schorsch
1 import os
2
3 Import('env') # inherit from parent
4
5 # make a modified local copy
6 px = env.Copy(LIBS=['rt'] + env['RAD_MLIB'])
7
8 # compose paths
9 def radbin(name): return os.path.join(px['RAD_BUILDBIN'], name)
10 def radlib(name): return os.path.join(px['RAD_BUILDLIB'], name)
11
12 # standard targets
13 PROGS = (
14 ('macbethcal', Split('macbethcal.c pmapgen.c mx3.c warp3d.c')),
15 ('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c warp3d.c')),
16 ('pfilt', Split('pfilt.c pf2.c pf3.c')),
17 ('pcwarp', Split('pcwarp.c warp3d.c')),
18 ('pvalue', Split('pvalue.c')),
19 ('pcompos', Split('pcompos.c')),
20 ('psign', Split('psign.c')),
21 ('protate', Split('protate.c')),
22 ('pextrem', Split('pextrem.c')),
23 ('pflip', Split('pflip.c')),
24 ('pcomb', Split('pcomb.c')),
25 ('pinterp', Split('pinterp.c')),
26
27 ('oki20c', Split('oki20c.c')),
28 ('oki20', Split('oki20.c')),
29
30 ('ra_gif', Split('ra_gif.c clrtab.c neuclrtab.c')),
31 ('ra_pr', Split('ra_pr.c ciq.c cut.c closest.c biq.c')),
32 ('ra_pr24', Split('ra_pr24.c')),
33 ('ra_avs', Split('ra_avs.c')),
34 ('ra_ps', Split('ra_ps.c')),
35 ('ra_ppm', Split('ra_ppm.c')),
36 ('ra_t8', Split('ra_t8.c clrtab.c neuclrtab.c')),
37 ('ra_t16', Split('ra_t16.c')),
38 ('ra_bn', Split('ra_bn.c')),
39 ('ra_rgbe', Split('ra_rgbe.c')),
40 ('ra_pict', Split('ra_pict.c')),
41 ('ra_hexbit', Split('ra_hexbit.c')),
42 ('ra_xyze', Split('ra_xyze.c')),
43
44 ('ttyimage', Split('ttyimage.c')),
45 )
46 for p in PROGS:
47 prog = px.Program(target=radbin(p[0]), source=p[1])
48 Default(prog)
49 env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], prog)])
50
51
52 # special targets not normally built
53 SPECIAL = (
54 #('psum', Split('psum.c'), ['rt']), # (errors)
55 #('panim', Split('panim.c'), px['LIBS]+['client','rpcsvc']),
56
57 ('ra_im', Split('ra_im.c')),
58
59 #('aedimage', Split('aedimage.c ciq.c cut.c closest.c'), []), # (errors)
60 ('t4027', Split('t4027.c'), ['rt']),
61 ('paintjet', Split('paintjet.c')),
62 ('mt160r', Split('mt160r.c')),
63 ('greyscale', Split('greyscale.c')),
64 ('colorscale', Split('colorscale.c')),
65 ('d48c', Split('d48c.c'), ['rt']), # (warnings)
66 )
67 specprogs = []
68 specinst = []
69 for p in SPECIAL:
70 if len(p) > 2:
71 prog = px.Program(target=radbin(p[0]), source=p[1],
72 LIBS=p[2])
73 else:
74 prog = px.Program(target=radbin(p[0]), source=p[1])
75 specprogs.append(prog)
76 specinst.append(px.Install(px['RAD_BINDIR'], prog))
77 px.Alias('px_special', specprogs)
78 px.Alias('px_special_install', specinst)
79
80
81 # tiff library (unix-specific for the moment)
82 if os.name == 'posix':
83 cwd = os.getcwd()
84 libtiff = px.Command(radlib(px['LIBPREFIX'] + 'tiff' + px['LIBSUFFIX']),
85 'tiff/config.local',
86 ['cd "%s";'
87 'sh ./configure -quiet -noninteractive -with-CC=$CC -with-ENVOPTS=$CCFLAGS;'
88 'cd libtiff;'
89 'make install;' % os.path.join(cwd, 'tiff')])
90
91 # tiff programs
92 ra_tiff = px.Program(target=radbin('ra_tiff'), source=Split('ra_tiff.c'),
93 LIBS=['tiff'] + px['LIBS'])
94 Default(ra_tiff)
95 env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], ra_tiff)])
96
97 normtiff = px.Program(target=radbin('normtiff'), source=Split('normtiff.c'),
98 LIBS=['tiff'] + px['LIBS'])
99 Default(normtiff)
100 env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], normtiff)])
101
102
103 # pixar format requires extra lib
104 if px.has_key('PIXAR_LIB'):
105 ra_pixar = px.Program(radbin('ra_pixar'), source=['ra_pixar.c'],
106 LIBS=['rt', px['PIXAR_LIB']])
107 Default(ra_pixar)
108 env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], ra_pixar)])
109
110
111 # X11 targets
112 if px.has_key('X11LIB'):
113 px.Append(CPPPATH=px['X11INCLUDE'])
114 px.Append(LIBS=['X11'])
115 px.Append(LIBPATH=px['X11LIB'])
116
117 ximage = px.Program(target=radbin('ximage'),
118 source=Split('x11image.c x11raster.c clrtab.c'),)
119 Default(ximage)
120 env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], ximage)])
121
122 xshowtrace = px.Program(target=radbin('xshowtrace'),
123 source=Split('xshowtrace.c x11findwind.c'),)
124 Default(xshowtrace)
125 env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], xshowtrace)])
126
127 # NeWS ?!?
128 # if px.has_key('OGL'):
129 # glimage = px.Program(target=radbin('glimage'),
130 # CPPFLAGS=px.get('CPPFLAGS', []) + [px['RAD_STEREO']],
131 # source=Split('glimage.c'),
132 # LIBS=['gl_s']+px['LIBS'],)
133 # Default(glimage)
134 # env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], glimage)])
135
136
