--- ray/src/px/SConscript 2004/10/21 15:47:12 1.7 +++ ray/src/px/SConscript 2005/09/12 14:44:09 1.12 @@ -13,9 +13,6 @@ def radlib(name): return os.path.join('$RAD_BUILDLIB', warp3d = env.Object(source="warp3d.c") clrtab = env.Object(source="clrtab.c") neuclrtab = env.Object(source="neuclrtab.c") -ciq = env.Object(source="ciq.c") -cut = env.Object(source="cut.c") -closest = env.Object(source="closest.c") # standard targets PROGS = ( @@ -26,7 +23,7 @@ PROGS = ( ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtcont','rtmem','rterror']), ('pfilt', Split('pfilt.c pf2.c pf3.c'), ['rtlamps','rtpic','rtio','rtpath','rtargs','rtmath']), -('pcwarp', ['pcwarp.c', warp3d], +('pcwarp', ['pcwarp.c', warp3d], ['rtpic','rtio','rtcont','rtmem','rterror']), ('pvalue', ['pvalue.c'], ['rtpic','rtio','rtargs','rtmath']), ('pcompos', ['pcompos.c'], ['rtpic','rtproc','rtpath','rtio','rterror']), @@ -40,20 +37,12 @@ PROGS = ( ('pinterp', ['pinterp.c'], ['rtproc','rtpic','rtio','rtpath','rtargs','rtmath','rtmem','rterror']), -('oki20c', ['oki20c.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']), -('oki20', ['oki20.c'], ['rtpic','rtproc','rtpath','rtio','rtmem','rterror']), - ('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']), -('ra_pr', Split('ra_pr.c biq.c')+ [ciq, cut, closest], - ['rtpic','rtio','rtmem']), -('ra_pr24', ['ra_pr24.c'], ['rtpic','rtio','rtmem']), -('ra_avs', ['ra_avs.c'], ['rtpic','rtio','rtmem']), ('ra_ps', ['ra_ps.c'], ['rtpic','rtio','rtargs','rtmem']), ('ra_ppm', ['ra_ppm.c'], ['rtpic','rtio','rtmem']), -('ra_bmp', ['ra_bmp.c'], ['rtpic','rtio','rtmem']), +('ra_bmp', ['ra_bmp.c'], ['rtpic','rtproc','rtio','rtmem']), ('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']), ('ra_t16', ['ra_t16.c'], ['rtpic','rtio','rtmem']), -('ra_bn', ['ra_bn.c'], ['rtpic','rtio','rtmem']), ('ra_rgbe', ['ra_rgbe.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']), ('ra_pict', ['ra_pict.c'], ['rtpic','rtio','rtmem']), ('ra_hexbit',['ra_hexbit.c'], ['rtpic','rtio','rtmem']), @@ -67,43 +56,38 @@ for p in PROGS: progs.append(prog) -# special targets not normally built -SPECIAL = ( -# name files libs -('psum', ['psum.c'], ['rtpic','rtio']), -#('panim', ['panim.c'], ['client','rpcsvc']),# missing externals - -('ra_im', ['ra_im.c'], ['rtproc','rtpath','rtio','rterror']), - -#('aedimage', Split('aedimage.c')+[ciq, cut, closest],[]),# missing externals -('t4027', ['t4027.c'], ['rtpic']), -('paintjet', ['paintjet.c'], ['rtpic','rtio','rtmem']), -('mt160r', ['mt160r.c'], ['rtpic','rtio','rtmem']), -('greyscale', ['greyscale.c'], ['rtpic']), -('colorscale', ['colorscale.c'], ['rtpic']), -('d48c', ['d48c.c'], ['rtpic']), -) -specprogs = [] -specinst = [] -for p in SPECIAL: - prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) - specprogs.append(prog) - specinst.append(env.Install('$RAD_BINDIR', prog)) -env.Alias('px_special', specprogs) -env.Alias('px_special_install', specinst) - - # tiff library (unix-specific for the moment) if os.name == 'posix': cwd = os.getcwd() + upperdir = os.path.split(cwd)[0] + libtiff = env.Command(radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']), - 'tiff/config.local', - [('cd "%s"; ' - 'sh ./configure -quiet -noninteractive ' - '-with-CC="$CC" -with-ENVOPTS="$CCFLAGS"; ' - 'cd libtiff; ' - 'make install;') % os.path.join(cwd, 'tiff')]) + None, + [('cd "%(tiffdir)s"; ' + 'env CC="$CC" ' + './configure -C '#-with-CC="$CC" ' + '"libdir=%(upperdir)s/lib" "includedir=%(upperdir)s/common" ' + '--enable-static --disable-shared --disable-cxx ' + '--enable-logluv --disable-jpeg ' + '--disable-zlib --disable-pixarlog; ' + #'"-with-ENVOPTS=$CCFLAGS"; ' + 'cd %(portdir)s; make all;' + 'cd %(libtiffdir)s; make install;') % { + 'upperdir':upperdir, + 'tiffdir':os.path.join(cwd, 'tiff'), + 'portdir':os.path.join(cwd, 'tiff', 'port'), + 'libtiffdir':os.path.join(cwd, 'tiff', 'libtiff') + } + ]) +# libtiff = env.Command(radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']), +# 'tiff/config.local', +# [('cd "%s"; ' +# 'sh ./configure -quiet -noninteractive ' +# '-with-CC="$CC" -with-ENVOPTS="$CCFLAGS"; ' +# 'cd libtiff; ' +# 'make install;') % os.path.join(cwd, 'tiff')]) + # tiff programs ra_tiff = env.Program(target=radbin('ra_tiff'), source=Split('ra_tiff.c'), LIBS=['tiff','rtpic','rtio','rtmem'] + mlib) @@ -114,13 +98,6 @@ if os.name == 'posix': progs.append(normtiff) -# pixar format requires extra lib -if env.has_key('PIXAR_LIB'): - ra_pixar = env.Program(radbin('ra_pixar'), source='ra_pixar.c', - LIBS=['rtpic', '$PIXAR_LIB']) - progs.append(ra_pixar) - - # X11 targets if env.has_key('X11LIB'): xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] @@ -139,19 +116,15 @@ if env.has_key('X11LIB'): CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib) progs.append(xshowtrace) -# NeWS ?!? -# if env.has_key('OGL'): -# glimage = env.Program(target=radbin('glimage'), -# CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']], -# source=Split('glimage.c'), -# LIBS=['gl_s']+env['LIBS'],) -# progs.append(glimage) - if os.name == 'posix': # XXX ignoring trad.wsh for s in Split('''normpat falsecolor pdfblur - pmblur xyzimage phisto pdelta pgblur'''): + pmblur xyzimage phisto pdelta pgblur ra_pfm'''): Default(env.InstallCsh(radbin(s), s + '.csh')) +# XXX probably needs fixing +#else: +# for s in Split('''falsecolor'''): +# Default(env.InstallCsh(radbin(s), s + '.csh')) Default('#src/px') env.Install('$RAD_BINDIR', progs)
