--- ray/src/px/SConscript 2003/10/21 19:27:29 1.1 +++ ray/src/px/SConscript 2004/11/08 19:24:46 1.10 @@ -2,135 +2,109 @@ import os Import('env') # inherit from parent -# make a modified local copy -px = env.Copy(LIBS=['rt'] + env['RAD_MLIB']) +mlib = ['$RAD_MLIB'] +progs = [] # compose paths -def radbin(name): return os.path.join(px['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(px['RAD_BUILDLIB'], name) +def radbin(name): return os.path.join('$RAD_BUILDBIN', name) +#def radbin(name): return name +def radlib(name): return os.path.join('$RAD_BUILDLIB', name) +warp3d = env.Object(source="warp3d.c") +clrtab = env.Object(source="clrtab.c") +neuclrtab = env.Object(source="neuclrtab.c") + # standard targets PROGS = ( -('macbethcal', Split('macbethcal.c pmapgen.c mx3.c warp3d.c')), -('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c warp3d.c')), -('pfilt', Split('pfilt.c pf2.c pf3.c')), -('pcwarp', Split('pcwarp.c warp3d.c')), -('pvalue', Split('pvalue.c')), -('pcompos', Split('pcompos.c')), -('psign', Split('psign.c')), -('protate', Split('protate.c')), -('pextrem', Split('pextrem.c')), -('pflip', Split('pflip.c')), -('pcomb', Split('pcomb.c')), -('pinterp', Split('pinterp.c')), +# name files libs +('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d], + ['rtpic','rtproc','rtpath','rtio','rtargs','rtcont','rtmem','rterror']), +('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d], + ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtcont','rtmem','rterror']), +('pfilt', Split('pfilt.c pf2.c pf3.c'), + ['rtlamps','rtpic','rtio','rtpath','rtargs','rtmath']), +('pcwarp', ['pcwarp.c', warp3d], + ['rtpic','rtio','rtcont','rtmem','rterror']), +('pvalue', ['pvalue.c'], ['rtpic','rtio','rtargs','rtmath']), +('pcompos', ['pcompos.c'], ['rtpic','rtproc','rtpath','rtio','rterror']), +('psign', ['psign.c'], + ['rtpic','rtscene','rtio','rtpath','rtargs','rtcont','rtmem','rterror']), +('protate', ['protate.c'], ['rtpic','rtio']), +('pextrem', ['pextrem.c'], ['rtpic','rtio']), +('pflip', ['pflip.c'], ['rtpic','rtio']), +('pcomb', ['pcomb.c'], + ['rtpic','rtproc','rtpath','rtio','rtfunc','rtargs','rtmath','rtcont','rtmem']), +('pinterp', ['pinterp.c'], + ['rtproc','rtpic','rtio','rtpath','rtargs','rtmath','rtmem','rterror']), -('oki20c', Split('oki20c.c')), -('oki20', Split('oki20.c')), +('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']), +('ra_ps', ['ra_ps.c'], ['rtpic','rtio','rtargs','rtmem']), +('ra_ppm', ['ra_ppm.c'], ['rtpic','rtio','rtmem']), +('ra_bmp', ['ra_bmp.c'], ['rtpic','rtproc','rtio','rtmem']), +('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']), +('ra_t16', ['ra_t16.c'], ['rtpic','rtio','rtmem']), +('ra_rgbe', ['ra_rgbe.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']), +('ra_pict', ['ra_pict.c'], ['rtpic','rtio','rtmem']), +('ra_hexbit',['ra_hexbit.c'], ['rtpic','rtio','rtmem']), +('ra_xyze', ['ra_xyze.c'], ['rtpic','rtio','rtmem']), -('ra_gif', Split('ra_gif.c clrtab.c neuclrtab.c')), -('ra_pr', Split('ra_pr.c ciq.c cut.c closest.c biq.c')), -('ra_pr24', Split('ra_pr24.c')), -('ra_avs', Split('ra_avs.c')), -('ra_ps', Split('ra_ps.c')), -('ra_ppm', Split('ra_ppm.c')), -('ra_t8', Split('ra_t8.c clrtab.c neuclrtab.c')), -('ra_t16', Split('ra_t16.c')), -('ra_bn', Split('ra_bn.c')), -('ra_rgbe', Split('ra_rgbe.c')), -('ra_pict', Split('ra_pict.c')), -('ra_hexbit', Split('ra_hexbit.c')), -('ra_xyze', Split('ra_xyze.c')), - -('ttyimage', Split('ttyimage.c')), +('ttyimage', ['ttyimage.c'], ['rtpic','rtio','rtmem']), ) for p in PROGS: - prog = px.Program(target=radbin(p[0]), source=p[1]) - Default(prog) - env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], prog)]) + prog = env.Program(target=radbin(p[0]), source=p[1], + LIBS=p[2]+mlib) + progs.append(prog) -# special targets not normally built -SPECIAL = ( -#('psum', Split('psum.c'), ['rt']), # (errors) -#('panim', Split('panim.c'), px['LIBS]+['client','rpcsvc']), - -('ra_im', Split('ra_im.c')), - -#('aedimage', Split('aedimage.c ciq.c cut.c closest.c'), []), # (errors) -('t4027', Split('t4027.c'), ['rt']), -('paintjet', Split('paintjet.c')), -('mt160r', Split('mt160r.c')), -('greyscale', Split('greyscale.c')), -('colorscale', Split('colorscale.c')), -('d48c', Split('d48c.c'), ['rt']), # (warnings) -) -specprogs = [] -specinst = [] -for p in SPECIAL: - if len(p) > 2: - prog = px.Program(target=radbin(p[0]), source=p[1], - LIBS=p[2]) - else: - prog = px.Program(target=radbin(p[0]), source=p[1]) - specprogs.append(prog) - specinst.append(px.Install(px['RAD_BINDIR'], prog)) -px.Alias('px_special', specprogs) -px.Alias('px_special_install', specinst) - - # tiff library (unix-specific for the moment) if os.name == 'posix': cwd = os.getcwd() - libtiff = px.Command(radlib(px['LIBPREFIX'] + 'tiff' + px['LIBSUFFIX']), + libtiff = env.Command(radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']), 'tiff/config.local', - ['cd "%s";' - 'sh ./configure -quiet -noninteractive -with-CC=$CC -with-ENVOPTS=$CCFLAGS;' - 'cd libtiff;' - 'make install;' % os.path.join(cwd, 'tiff')]) + [('cd "%s"; ' + 'sh ./configure -quiet -noninteractive ' + '-with-CC="$CC" -with-ENVOPTS="$CCFLAGS"; ' + 'cd libtiff; ' + 'make install;') % os.path.join(cwd, 'tiff')]) # tiff programs - ra_tiff = px.Program(target=radbin('ra_tiff'), source=Split('ra_tiff.c'), - LIBS=['tiff'] + px['LIBS']) - Default(ra_tiff) - env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], ra_tiff)]) + ra_tiff = env.Program(target=radbin('ra_tiff'), source=Split('ra_tiff.c'), + LIBS=['tiff','rtpic','rtio','rtmem'] + mlib) + progs.append(ra_tiff) - normtiff = px.Program(target=radbin('normtiff'), source=Split('normtiff.c'), - LIBS=['tiff'] + px['LIBS']) - Default(normtiff) - env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], normtiff)]) + normtiff = env.Program(target=radbin('normtiff'), source=Split('normtiff.c'), + LIBS=['tiff','rtpic','rtio','rtmem'] + mlib) + progs.append(normtiff) -# pixar format requires extra lib -if px.has_key('PIXAR_LIB'): - ra_pixar = px.Program(radbin('ra_pixar'), source=['ra_pixar.c'], - LIBS=['rt', px['PIXAR_LIB']]) - Default(ra_pixar) - env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], ra_pixar)]) - - # X11 targets -if px.has_key('X11LIB'): - px.Append(CPPPATH=px['X11INCLUDE']) - px.Append(LIBS=['X11']) - px.Append(LIBPATH=px['X11LIB']) +if env.has_key('X11LIB'): + xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] + xlibp = env.get('LIBPATH', []) + ['$X11LIB'] + xlibs = ['X11','rtpic','rtio','rtmath','rtargs','rtmem'] + x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice + CPPPATH=xincl) - ximage = px.Program(target=radbin('ximage'), - source=Split('x11image.c x11raster.c clrtab.c'),) - Default(ximage) - env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], ximage)]) + ximage = env.Program(target=radbin('ximage'), + source=Split('x11image.c x11raster.c')+[clrtab], + CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib) + progs.append(ximage) - xshowtrace = px.Program(target=radbin('xshowtrace'), - source=Split('xshowtrace.c x11findwind.c'),) - Default(xshowtrace) - env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], xshowtrace)]) + xshowtrace = env.Program(target=radbin('xshowtrace'), + source=Split('xshowtrace.c') + [x11findwind], + CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib) + progs.append(xshowtrace) -# NeWS ?!? -# if px.has_key('OGL'): -# glimage = px.Program(target=radbin('glimage'), -# CPPFLAGS=px.get('CPPFLAGS', []) + [px['RAD_STEREO']], -# source=Split('glimage.c'), -# LIBS=['gl_s']+px['LIBS'],) -# Default(glimage) -# env.Append(RAD_BININSTALL=[px.Install(px['RAD_BINDIR'], glimage)]) +if os.name == 'posix': # XXX ignoring trad.wsh + for s in Split('''normpat falsecolor pdfblur + pmblur xyzimage phisto pdelta pgblur'''): + Default(env.InstallCsh(radbin(s), s + '.csh')) +# XXX probably needs fixing +#else: +# for s in Split('''falsecolor'''): +# Default(env.InstallCsh(radbin(s), s + '.csh')) + +Default('#src/px') +env.Install('$RAD_BINDIR', progs)
