root/Development/ray/src/px/SConscript
Thu Mar 10 21:43:23 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.22: +28 -36 lines
Diff to previous 1.22 , to selected 1.14
Thu Mar 10 17:36:18 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.21: +3 -2 lines
Diff to previous 1.21 , to selected 1.14
Tifflib support and sleeker binaries on Windows
Sat Mar 5 13:24:58 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.20: +4 -3 lines
Diff to previous 1.20 , to selected 1.14
Sat Mar 5 00:29:28 2016 UTC (9 years, 6 months ago) by schorsch
Diff to previous 1.19 , to selected 1.14
update SCons
Tue Dec 23 15:04:00 2008 UTC (16 years, 9 months ago) by schorsch
Changes since 1.18: +35 -20 lines
Diff to previous 1.18 , to selected 1.14
Sun Apr 27 17:22:49 2008 UTC (17 years, 5 months ago) by schorsch
Diff to previous 1.17 , to selected 1.14
Thu Apr 24 10:28:25 2008 UTC (17 years, 5 months ago) by schorsch
Diff to previous 1.16 , to selected 1.14
Mon Apr 21 07:31:29 2008 UTC (17 years, 5 months ago) by schorsch
Changes since 1.15: +9 -9 lines
Diff to previous 1.15 , to selected 1.14
Scons update for mingw.
Fri Mar 10 19:40:13 2006 UTC (19 years, 6 months ago) by schorsch
Changes since 1.14: +4 -13 lines
Diff to previous 1.14
Revision 1.14 - (view) (download) (annotate) - [selected]
Sat Sep 17 07:45:11 2005 UTC (20 years ago) by schorsch
Diff to previous 1.13
Added pmdblur.csh and ran2tiff.csh install for SCons.
Wed Sep 14 09:26:25 2005 UTC (20 years ago) by schorsch
Diff to previous 1.12 , to selected 1.14
Cleaned up tifflib support (don't copy header files to common during build).
Mon Sep 12 14:44:09 2005 UTC (20 years ago) by schorsch
Changes since 1.11: +27 -6 lines
Diff to previous 1.11 , to selected 1.14
Updates to SConscripts for 3R7.
Thu Feb 10 16:43:08 2005 UTC (20 years, 7 months ago) by schorsch
Diff to previous 1.10 , to selected 1.14
Install ra_pvm.csh on posix systems.
Mon Nov 8 19:24:46 2004 UTC (20 years, 10 months ago) by schorsch
Changes since 1.9: +2 -3 lines
Diff to previous 1.9 , to selected 1.14
Fri Nov 5 22:15:43 2004 UTC (20 years, 10 months ago) by schorsch
Changes since 1.8: +0 -51 lines
Diff to previous 1.8 , to selected 1.14
Sat Oct 23 18:55:52 2004 UTC (20 years, 11 months ago) by schorsch
CVS Tags: rad3R6P1
Changes since 1.7: +6 -2 lines
Diff to previous 1.7 , to selected 1.14
Thu Oct 21 15:47:12 2004 UTC (20 years, 11 months ago) by schorsch
Changes since 1.6: +27 -24 lines
Diff to previous 1.6 , to selected 1.14
SCons build simplifications.
Tue Jul 6 11:49:09 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 1.5: +5 -4 lines
Diff to previous 1.5 , to selected 1.14
Sun Jul 4 12:08:48 2004 UTC (21 years, 2 months ago) by schorsch
Diff to previous 1.4 , to selected 1.14
Fri Mar 26 21:32:01 2004 UTC (21 years, 6 months ago) by schorsch
Diff to previous 1.3 , to selected 1.14
Added new ra_bmp.c.
Fri Jan 2 23:27:43 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 1.2: +5 -4 lines
Diff to previous 1.2 , to selected 1.14
Made tifflib compile a bit more robust.
Mon Oct 27 10:35:43 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 1.1: +98 -83 lines
Diff to previous 1.1 , to selected 1.14
Tue Oct 21 19:27:29 2003 UTC (21 years, 11 months ago) by schorsch
Diff to selected 1.14
