root/Development/ray/src/px/SConscript
Revision: 1.19
Committed: Tue Dec 23 15:04:00 2008 UTC (17 years ago) by schorsch
CVS Tags: rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0
Changes since 1.18: +35 -20 lines
# User Rev Content
1 schorsch 1.1 import os
2
3     Import('env') # inherit from parent
4
5 schorsch 1.7 mlib = ['$RAD_MLIB']
6     progs = []
7 schorsch 1.1
8     # compose paths
9 schorsch 1.7 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10     #def radbin(name): return name
11     def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
12 schorsch 1.2
13     warp3d = env.Object(source="warp3d.c")
14     clrtab = env.Object(source="clrtab.c")
15     neuclrtab = env.Object(source="neuclrtab.c")
16 schorsch 1.1
17     # standard targets
18     PROGS = (
19 schorsch 1.18 # name files libs
20 schorsch 1.2 ('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d],
21 schorsch 1.16 ['rtpic','rtproc','rtpath','rtargs','rtio','rtcont','rtmem','rterror']),
22 schorsch 1.2 ('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d],
23 schorsch 1.16 ['rtpic','rtproc','rtpath','rtargs','rtio','rtmath','rtcont','rtmem','rterror']),
24 schorsch 1.2 ('pfilt', Split('pfilt.c pf2.c pf3.c'),
25 schorsch 1.16 ['rtlamps','rtpic','rtpath','rtargs','rtio','rtmath']),
26 schorsch 1.10 ('pcwarp', ['pcwarp.c', warp3d],
27     ['rtpic','rtio','rtcont','rtmem','rterror']),
28 schorsch 1.16 ('pvalue', ['pvalue.c'], ['rtpic','rtargs','rtio','rtmath']),
29 schorsch 1.2 ('pcompos', ['pcompos.c'], ['rtpic','rtproc','rtpath','rtio','rterror']),
30     ('psign', ['psign.c'],
31 schorsch 1.16 ['rtpic','rtscene','rtpath','rtargs','rtio','rtcont','rtmem','rterror']),
32 schorsch 1.2 ('protate', ['protate.c'], ['rtpic','rtio']),
33     ('pextrem', ['pextrem.c'], ['rtpic','rtio']),
34     ('pflip', ['pflip.c'], ['rtpic','rtio']),
35     ('pcomb', ['pcomb.c'],
36 schorsch 1.16 ['rtpic','rtproc','rtpath','rtfunc','rtargs','rtio','rtmath','rtcont','rtmem']),
37 schorsch 1.2 ('pinterp', ['pinterp.c'],
38 schorsch 1.16 ['rtproc','rtpic','rtpath','rtargs','rtio','rtmath','rtmem','rterror']),
39 schorsch 1.2
40     ('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
41 schorsch 1.16 ('ra_ps', ['ra_ps.c'], ['rtpic','rtargs','rtio','rtmem']),
42 schorsch 1.2 ('ra_ppm', ['ra_ppm.c'], ['rtpic','rtio','rtmem']),
43 schorsch 1.18 ('ra_bmp', ['ra_bmp.c'],
44     ['rtpic','rtproc','rterror','rtpath','rtio','rtmem']),
45 schorsch 1.2 ('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
46     ('ra_t16', ['ra_t16.c'], ['rtpic','rtio','rtmem']),
47     ('ra_rgbe', ['ra_rgbe.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']),
48     ('ra_pict', ['ra_pict.c'], ['rtpic','rtio','rtmem']),
49     ('ra_hexbit',['ra_hexbit.c'], ['rtpic','rtio','rtmem']),
50     ('ra_xyze', ['ra_xyze.c'], ['rtpic','rtio','rtmem']),
51 schorsch 1.1
52 schorsch 1.2 ('ttyimage', ['ttyimage.c'], ['rtpic','rtio','rtmem']),
53 schorsch 1.1 )
54     for p in PROGS:
55 schorsch 1.2 prog = env.Program(target=radbin(p[0]), source=p[1],
56 schorsch 1.7 LIBS=p[2]+mlib)
57     progs.append(prog)
58 schorsch 1.1
59
60 schorsch 1.19 # tiff library (building it is unix-specific for the moment)
61     # If we haven't found one supporting LogLuv installed, build our own.
62     libtiff_fn = radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX'])
63     if os.name == 'posix' and not env.get('TIFFLIB_INSTALLED'):
64 schorsch 1.1 cwd = os.getcwd()
65 schorsch 1.12 upperdir = os.path.split(cwd)[0]
66 schorsch 1.19 libtiff = env.Command(libtiff_fn, None,
67 schorsch 1.12 [('cd "%(tiffdir)s"; '
68     'env CC="$CC" '
69 schorsch 1.15 './configure -C '
70 schorsch 1.13 '"libdir=%(upperdir)s/lib" '
71 schorsch 1.12 '--enable-static --disable-shared --disable-cxx '
72 schorsch 1.15 '--enable-logluv --disable-jpeg --disable-zlib --disable-pixarlog; '
73 schorsch 1.12 'cd %(portdir)s; make all;'
74 schorsch 1.13 'cd %(libtiffdir)s; make install-exec;' # don't install headers
75     ) % {
76 schorsch 1.12 'upperdir':upperdir,
77     'tiffdir':os.path.join(cwd, 'tiff'),
78     'portdir':os.path.join(cwd, 'tiff', 'port'),
79     'libtiffdir':os.path.join(cwd, 'tiff', 'libtiff')
80     }
81     ])
82
83 schorsch 1.19 env['TIFFLIB_INSTALLED'] = 1
84
85     if os.name == 'posix': # cleanup action for a previously built tifflib
86     Clean(libtiff_fn, [libtiff_fn, radlib(env['LIBPREFIX'] + 'tiff.la')])
87
88     if env.get('TIFFLIB_INSTALLED'):
89 schorsch 1.1 # tiff programs
90 schorsch 1.19 tiffi = env.get('RAD_TIFFINCLUDE')
91     if tiffi: tiffincl = [tiffi] + env.get('CPPPATH', [])
92     else: tiffincl = env.get('CPPPATH', [])
93     tiffl = env.get('RAD_TIFFLIB')
94     if tiffl: tifflib = [tiffl] + env.get('LIBPATH', [])
95     else: tifflib = env.get('LIBPATH', [])
96
97 schorsch 1.15 ra_tiff = env.Program(target=radbin('ra_tiff'), source=['ra_tiff.c'],
98 schorsch 1.19 CPPPATH = tiffincl, LIBPATH=tifflib,
99 schorsch 1.2 LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
100 schorsch 1.7 progs.append(ra_tiff)
101 schorsch 1.1
102 schorsch 1.15 normtiff = env.Program(target=radbin('normtiff'),source=['normtiff.c'],
103 schorsch 1.19 CPPPATH = tiffincl, LIBPATH=tifflib,
104 schorsch 1.2 LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
105 schorsch 1.7 progs.append(normtiff)
106 schorsch 1.1
107
108     # X11 targets
109 schorsch 1.2 if env.has_key('X11LIB'):
110 schorsch 1.19 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
111     xlibp = env.get('LIBPATH', []) + ['$X11LIB']
112     xlibs = ['X11','rtpic','rtargs','rtio','rtmath','rtmem']
113     env.x11findwind = env.Object(source='../common/x11findwind.c', # XXX remote magic
114     CPPPATH=xincl)
115
116     ximage = env.Program(target=radbin('ximage'),
117     source=Split('x11image.c x11raster.c')+[clrtab],
118     CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
119     progs.append(ximage)
120
121     xshowtrace = env.Program(target=radbin('xshowtrace'),
122     source=Split('xshowtrace.c') + [env.x11findwind], # XXX remote magic
123     CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
124     progs.append(xshowtrace)
125 schorsch 1.1
126 schorsch 1.7 if os.name == 'posix': # XXX ignoring trad.wsh
127 schorsch 1.17 for s in Split('''normpat falsecolor pdfblur pmblur pmdblur pbilat
128 schorsch 1.14 xyzimage phisto pdelta pgblur ra_pfm ran2tiff'''):
129 schorsch 1.7 Default(env.InstallCsh(radbin(s), s + '.csh'))
130 schorsch 1.8 # XXX probably needs fixing
131     #else:
132     # for s in Split('''falsecolor'''):
133     # Default(env.InstallCsh(radbin(s), s + '.csh'))
134 schorsch 1.14 # ignored by Rmakefile: pacuity phisteq psquish pveil vlpic
135 schorsch 1.7
136     Default('#src/px')
137     env.Install('$RAD_BINDIR', progs)
138
