root/Development/ray/src/px/SConscript
Revision: 1.8
Committed: Sat Oct 23 18:55:52 2004 UTC (21 years, 1 month ago) by schorsch
CVS Tags: rad3R6P1
Changes since 1.7: +6 -2 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 #def radbin(name): return name
11 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
12
13 warp3d = env.Object(source="warp3d.c")
14 clrtab = env.Object(source="clrtab.c")
15 neuclrtab = env.Object(source="neuclrtab.c")
16 ciq = env.Object(source="ciq.c")
17 cut = env.Object(source="cut.c")
18 closest = env.Object(source="closest.c")
19
20 # standard targets
21 PROGS = (
22 # name files libs
23 ('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d],
24 ['rtpic','rtproc','rtpath','rtio','rtargs','rtcont','rtmem','rterror']),
25 ('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d],
26 ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtcont','rtmem','rterror']),
27 ('pfilt', Split('pfilt.c pf2.c pf3.c'),
28 ['rtlamps','rtpic','rtio','rtpath','rtargs','rtmath']),
29 ('pcwarp', ['pcwarp.c', warp3d],
30 ['rtpic','rtio','rtcont','rtmem','rterror']),
31 ('pvalue', ['pvalue.c'], ['rtpic','rtio','rtargs','rtmath']),
32 ('pcompos', ['pcompos.c'], ['rtpic','rtproc','rtpath','rtio','rterror']),
33 ('psign', ['psign.c'],
34 ['rtpic','rtscene','rtio','rtpath','rtargs','rtcont','rtmem','rterror']),
35 ('protate', ['protate.c'], ['rtpic','rtio']),
36 ('pextrem', ['pextrem.c'], ['rtpic','rtio']),
37 ('pflip', ['pflip.c'], ['rtpic','rtio']),
38 ('pcomb', ['pcomb.c'],
39 ['rtpic','rtproc','rtpath','rtio','rtfunc','rtargs','rtmath','rtcont','rtmem']),
40 ('pinterp', ['pinterp.c'],
41 ['rtproc','rtpic','rtio','rtpath','rtargs','rtmath','rtmem','rterror']),
42
43 ('oki20c', ['oki20c.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']),
44 ('oki20', ['oki20.c'], ['rtpic','rtproc','rtpath','rtio','rtmem','rterror']),
45
46 ('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
47 ('ra_pr', Split('ra_pr.c biq.c')+ [ciq, cut, closest],
48 ['rtpic','rtio','rtmem']),
49 ('ra_pr24', ['ra_pr24.c'], ['rtpic','rtio','rtmem']),
50 ('ra_avs', ['ra_avs.c'], ['rtpic','rtio','rtmem']),
51 ('ra_ps', ['ra_ps.c'], ['rtpic','rtio','rtargs','rtmem']),
52 ('ra_ppm', ['ra_ppm.c'], ['rtpic','rtio','rtmem']),
53 ('ra_bmp', ['ra_bmp.c'], ['rtpic','rtproc','rtio','rtmem']),
54 ('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
55 ('ra_t16', ['ra_t16.c'], ['rtpic','rtio','rtmem']),
56 ('ra_bn', ['ra_bn.c'], ['rtpic','rtio','rtmem']),
57 ('ra_rgbe', ['ra_rgbe.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']),
58 ('ra_pict', ['ra_pict.c'], ['rtpic','rtio','rtmem']),
59 ('ra_hexbit',['ra_hexbit.c'], ['rtpic','rtio','rtmem']),
60 ('ra_xyze', ['ra_xyze.c'], ['rtpic','rtio','rtmem']),
61
62 ('ttyimage', ['ttyimage.c'], ['rtpic','rtio','rtmem']),
63 )
64 for p in PROGS:
65 prog = env.Program(target=radbin(p[0]), source=p[1],
66 LIBS=p[2]+mlib)
67 progs.append(prog)
68
69
70 # special targets not normally built
71 SPECIAL = (
72 # name files libs
73 ('psum', ['psum.c'], ['rtpic','rtio']),
74 #('panim', ['panim.c'], ['client','rpcsvc']),# missing externals
75
76 ('ra_im', ['ra_im.c'], ['rtproc','rtpath','rtio','rterror']),
77
78 #('aedimage', Split('aedimage.c')+[ciq, cut, closest],[]),# missing externals
79 ('t4027', ['t4027.c'], ['rtpic']),
80 ('paintjet', ['paintjet.c'], ['rtpic','rtio','rtmem']),
81 ('mt160r', ['mt160r.c'], ['rtpic','rtio','rtmem']),
82 ('greyscale', ['greyscale.c'], ['rtpic']),
83 ('colorscale', ['colorscale.c'], ['rtpic']),
84 ('d48c', ['d48c.c'], ['rtpic']),
85 )
86 specprogs = []
87 specinst = []
88 for p in SPECIAL:
89 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
90 specprogs.append(prog)
91 specinst.append(env.Install('$RAD_BINDIR', prog))
92 env.Alias('px_special', specprogs)
93 env.Alias('px_special_install', specinst)
94
95
96 # tiff library (unix-specific for the moment)
97 if os.name == 'posix':
98 cwd = os.getcwd()
99 libtiff = env.Command(radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']),
100 'tiff/config.local',
101 [('cd "%s"; '
102 'sh ./configure -quiet -noninteractive '
103 '-with-CC="$CC" -with-ENVOPTS="$CCFLAGS"; '
104 'cd libtiff; '
105 'make install;') % os.path.join(cwd, 'tiff')])
106
107 # tiff programs
108 ra_tiff = env.Program(target=radbin('ra_tiff'), source=Split('ra_tiff.c'),
109 LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
110 progs.append(ra_tiff)
111
112 normtiff = env.Program(target=radbin('normtiff'), source=Split('normtiff.c'),
113 LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
114 progs.append(normtiff)
115
116
117 # pixar format requires extra lib
118 if env.has_key('PIXAR_LIB'):
119 ra_pixar = env.Program(radbin('ra_pixar'), source=['ra_pixar.c'],
120 LIBS=['rtpic', '$PIXAR_LIB'])
121 progs.append(ra_pixar)
122
123
124 # X11 targets
125 if env.has_key('X11LIB'):
126 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
127 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
128 xlibs = ['X11','rtpic','rtio','rtmath','rtargs','rtmem']
129 x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice
130 CPPPATH=xincl)
131
132 ximage = env.Program(target=radbin('ximage'),
133 source=Split('x11image.c x11raster.c')+[clrtab],
134 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
135 progs.append(ximage)
136
137 xshowtrace = env.Program(target=radbin('xshowtrace'),
138 source=Split('xshowtrace.c') + [x11findwind],
139 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
140 progs.append(xshowtrace)
141
142 # NeWS ?!?
143 # if env.has_key('OGL'):
144 # glimage = env.Program(target=radbin('glimage'),
145 # CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']],
146 # source=Split('glimage.c'),
147 # LIBS=['gl_s']+env['LIBS'],)
148 # progs.append(glimage)
149
150
151 if os.name == 'posix': # XXX ignoring trad.wsh
152 for s in Split('''normpat falsecolor pdfblur
153 pmblur xyzimage phisto pdelta pgblur'''):
154 Default(env.InstallCsh(radbin(s), s + '.csh'))
155 # XXX probably needs fixing
156 #else:
157 # for s in Split('''falsecolor'''):
158 # Default(env.InstallCsh(radbin(s), s + '.csh'))
159
160 Default('#src/px')
161 env.Install('$RAD_BINDIR', progs)
162
