root/radiance/ray/src/px/SConscript
Thu Feb 10 16:43:08 2005 UTC (20 years, 2 months ago) by schorsch
Diff to previous 1.10 , to selected 1.5
Install ra_pvm.csh on posix systems.
Mon Nov 8 19:24:46 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 1.9: +2 -3 lines
Diff to previous 1.9 , to selected 1.5
Fri Nov 5 22:15:43 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 1.8: +0 -51 lines
Diff to previous 1.8 , to selected 1.5
Sat Oct 23 18:55:52 2004 UTC (20 years, 6 months ago) by schorsch
CVS Tags: rad3R6P1
Changes since 1.7: +6 -2 lines
Diff to previous 1.7 , to selected 1.5
Thu Oct 21 15:47:12 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.6: +27 -24 lines
Diff to previous 1.6 , to selected 1.5
SCons build simplifications.
Tue Jul 6 11:49:09 2004 UTC (20 years, 9 months ago) by schorsch
Changes since 1.5: +5 -4 lines
Diff to previous 1.5
Sun Jul 4 12:08:48 2004 UTC (20 years, 9 months ago) by schorsch
Diff to previous 1.4
Fri Mar 26 21:32:01 2004 UTC (21 years ago) by schorsch
Added new ra_bmp.c.
Fri Jan 2 23:27:43 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 1.2: +5 -4 lines
Made tifflib compile a bit more robust.
Mon Oct 27 10:35:43 2003 UTC (21 years, 5 months ago) by schorsch
Changes since 1.1: +98 -83 lines
Tue Oct 21 19:27:29 2003 UTC (21 years, 6 months ago) by schorsch
Diff to selected 1.5
