root/radiance/ray/src/px/SConscript
Revision: 1.11
Committed: Thu Feb 10 16:43:08 2005 UTC (20 years, 5 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1
Install ra_pvm.csh on posix systems.
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 #def radbin(name): return name
11 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
12
13 warp3d = env.Object(source="warp3d.c")
14 clrtab = env.Object(source="clrtab.c")
15 neuclrtab = env.Object(source="neuclrtab.c")
16
17 # standard targets
18 PROGS = (
19 # name files libs
20 ('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d],
21 ['rtpic','rtproc','rtpath','rtio','rtargs','rtcont','rtmem','rterror']),
22 ('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d],
23 ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtcont','rtmem','rterror']),
24 ('pfilt', Split('pfilt.c pf2.c pf3.c'),
25 ['rtlamps','rtpic','rtio','rtpath','rtargs','rtmath']),
26 ('pcwarp', ['pcwarp.c', warp3d],
27 ['rtpic','rtio','rtcont','rtmem','rterror']),
28 ('pvalue', ['pvalue.c'], ['rtpic','rtio','rtargs','rtmath']),
29 ('pcompos', ['pcompos.c'], ['rtpic','rtproc','rtpath','rtio','rterror']),
30 ('psign', ['psign.c'],
31 ['rtpic','rtscene','rtio','rtpath','rtargs','rtcont','rtmem','rterror']),
32 ('protate', ['protate.c'], ['rtpic','rtio']),
33 ('pextrem', ['pextrem.c'], ['rtpic','rtio']),
34 ('pflip', ['pflip.c'], ['rtpic','rtio']),
35 ('pcomb', ['pcomb.c'],
36 ['rtpic','rtproc','rtpath','rtio','rtfunc','rtargs','rtmath','rtcont','rtmem']),
37 ('pinterp', ['pinterp.c'],
38 ['rtproc','rtpic','rtio','rtpath','rtargs','rtmath','rtmem','rterror']),
39
40 ('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
41 ('ra_ps', ['ra_ps.c'], ['rtpic','rtio','rtargs','rtmem']),
42 ('ra_ppm', ['ra_ppm.c'], ['rtpic','rtio','rtmem']),
43 ('ra_bmp', ['ra_bmp.c'], ['rtpic','rtproc','rtio','rtmem']),
44 ('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtpic','rtio','rtmem']),
45 ('ra_t16', ['ra_t16.c'], ['rtpic','rtio','rtmem']),
46 ('ra_rgbe', ['ra_rgbe.c'],['rtpic','rtproc','rtpath','rtio','rtmem','rterror']),
47 ('ra_pict', ['ra_pict.c'], ['rtpic','rtio','rtmem']),
48 ('ra_hexbit',['ra_hexbit.c'], ['rtpic','rtio','rtmem']),
49 ('ra_xyze', ['ra_xyze.c'], ['rtpic','rtio','rtmem']),
50
51 ('ttyimage', ['ttyimage.c'], ['rtpic','rtio','rtmem']),
52 )
53 for p in PROGS:
54 prog = env.Program(target=radbin(p[0]), source=p[1],
55 LIBS=p[2]+mlib)
56 progs.append(prog)
57
58
59 # tiff library (unix-specific for the moment)
60 if os.name == 'posix':
61 cwd = os.getcwd()
62 libtiff = env.Command(radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']),
63 'tiff/config.local',
64 [('cd "%s"; '
65 'sh ./configure -quiet -noninteractive '
66 '-with-CC="$CC" -with-ENVOPTS="$CCFLAGS"; '
67 'cd libtiff; '
68 'make install;') % os.path.join(cwd, 'tiff')])
69
70 # tiff programs
71 ra_tiff = env.Program(target=radbin('ra_tiff'), source=Split('ra_tiff.c'),
72 LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
73 progs.append(ra_tiff)
74
75 normtiff = env.Program(target=radbin('normtiff'), source=Split('normtiff.c'),
76 LIBS=['tiff','rtpic','rtio','rtmem'] + mlib)
77 progs.append(normtiff)
78
79
80 # X11 targets
81 if env.has_key('X11LIB'):
82 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
83 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
84 xlibs = ['X11','rtpic','rtio','rtmath','rtargs','rtmem']
85 x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice
86 CPPPATH=xincl)
87
88 ximage = env.Program(target=radbin('ximage'),
89 source=Split('x11image.c x11raster.c')+[clrtab],
90 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
91 progs.append(ximage)
92
93 xshowtrace = env.Program(target=radbin('xshowtrace'),
94 source=Split('xshowtrace.c') + [x11findwind],
95 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
96 progs.append(xshowtrace)
97
98
99 if os.name == 'posix': # XXX ignoring trad.wsh
100 for s in Split('''normpat falsecolor pdfblur
101 pmblur xyzimage phisto pdelta pgblur ra_pfm'''):
102 Default(env.InstallCsh(radbin(s), s + '.csh'))
103 # XXX probably needs fixing
104 #else:
105 # for s in Split('''falsecolor'''):
106 # Default(env.InstallCsh(radbin(s), s + '.csh'))
107
108 Default('#src/px')
109 env.Install('$RAD_BINDIR', progs)
110
