root/Development/ray/src/px/Rmakefile
Wed Nov 21 17:52:05 2007 UTC (18 years, 1 month ago) by greg
Diff to previous 2.64 , to selected 2.59
Mon Oct 22 18:05:43 2007 UTC (18 years, 2 months ago) by greg
Changes since 2.63: +5 -3 lines
Diff to previous 2.63 , to selected 2.59
Simple bilateral filter implementation
Fri Mar 10 19:40:13 2006 UTC (19 years, 10 months ago) by schorsch
Changes since 2.62: +28 -28 lines
Diff to previous 2.62 , to selected 2.59
Sat Sep 17 05:14:14 2005 UTC (20 years, 3 months ago) by greg
Changes since 2.61: +4 -3 lines
Diff to previous 2.61 , to selected 2.59
Fri Sep 2 04:15:42 2005 UTC (20 years, 4 months ago) by greg
Diff to previous 2.60 , to selected 2.59
Tue Jul 26 15:33:13 2005 UTC (20 years, 5 months ago) by greg
Changes since 2.59: +2 -5 lines
Diff to previous 2.59
Revision 2.59 - (view) (download) (annotate) - [selected]
Tue Jul 26 03:48:47 2005 UTC (20 years, 5 months ago) by greg
Diff to previous 2.58
Fixed call to configure for accounts w/o '.' in $PATH
Fri Jul 8 16:04:57 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.57: +9 -4 lines
Diff to previous 2.57 , to selected 2.59
Upgraded to TIFF 3.7.3 library
Tue Jan 18 03:59:41 2005 UTC (20 years, 11 months ago) by greg
Diff to previous 2.56 , to selected 2.59
Thu Nov 25 14:47:03 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.55: +3 -2 lines
Diff to previous 2.55 , to selected 2.59
Mon Nov 8 18:49:18 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.54: +4 -6 lines
Diff to previous 2.54 , to selected 2.59
Removed unused modules I missed last time
Fri Nov 5 03:31:38 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.53: +17 -97 lines
Diff to previous 2.53 , to selected 2.59
Wed Oct 27 23:23:47 2004 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.52 , to selected 2.59
Mon May 24 21:03:34 2004 UTC (21 years, 7 months ago) by greg
Changes since 2.51: +5 -4 lines
Diff to previous 2.51 , to selected 2.59
Updated dependencies for ra_bmp
Fri Mar 26 03:11:50 2004 UTC (21 years, 9 months ago) by greg
Changes since 2.50: +9 -4 lines
Diff to previous 2.50 , to selected 2.59
Tue Feb 17 21:57:45 2004 UTC (21 years, 10 months ago) by greg
Changes since 2.49: +2 -3 lines
Diff to previous 2.49 , to selected 2.59
Removed pbilat.csh until we're ready to distribute it
Thu Jan 29 22:18:26 2004 UTC (21 years, 11 months ago) by greg
Changes since 2.48: +6 -5 lines
Diff to previous 2.48 , to selected 2.59
Mon Jul 7 17:21:51 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 2.47 , to selected 2.59
Fri Jun 27 06:53:22 2003 UTC (22 years, 6 months ago) by greg
Changes since 2.46: +7 -3 lines
Diff to previous 2.46 , to selected 2.59
Tue Apr 29 19:09:43 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.45 , to selected 2.59
Call sh configure instead of ./configure to avoid problems with execution bit
Sat Feb 22 02:07:27 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.44: +24 -18 lines
Diff to previous 2.44 , to selected 2.59
Thu Nov 12 09:44:07 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.43: +6 -6 lines
Diff to previous 2.43 , to selected 2.59
added -lm to programs that needed ldexp and frexp
Mon Oct 26 17:39:53 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.42: +11 -3 lines
Diff to previous 2.42 , to selected 2.59
added normtiff program
Wed Sep 9 12:56:38 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 2.41: +3 -2 lines
Diff to previous 2.41 , to selected 2.59
added OPT flags to libtiff compiles
Thu Sep 3 10:48:57 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 2.40: +1 -1 lines
Diff to previous 2.40 , to selected 2.59
Wed Jul 8 18:00:22 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 2.39: +5 -3 lines
Diff to previous 2.39 , to selected 2.59
created ra_hexbit program to generate bitmaps for hexbit4x1.fnt
Tue Jun 9 16:46:57 1998 UTC (27 years, 7 months ago) by gwlarson
Changes since 2.38: +6 -4 lines
Diff to previous 2.38 , to selected 2.59
fixes for TIFF library
Tue May 26 09:04:55 1998 UTC (27 years, 7 months ago) by gwlarson
Changes since 2.37: +1 -1 lines
Diff to previous 2.37 , to selected 2.59
added ra_tiff to default list
Thu Mar 12 15:47:05 1998 UTC (27 years, 10 months ago) by gwlarson
Diff to previous 2.36 , to selected 2.59
created phisto script
Fri Aug 29 15:35:28 1997 UTC (28 years, 4 months ago) by gregl
Changes since 2.35: +2 -0 lines
Diff to previous 2.35 , to selected 2.59
minor fix
Fri Aug 22 12:12:14 1997 UTC (28 years, 4 months ago) by gregl
Changes since 2.34: +8 -8 lines
Diff to previous 2.34 , to selected 2.59
added needed links to -lm for ldexp() and frexp()
Thu Jul 24 11:47:42 1997 UTC (28 years, 5 months ago) by gregl
Changes since 2.33: +8 -11 lines
Diff to previous 2.33 , to selected 2.59
incorporated new TIFF library (3.4beta) and Luv image types for ra_tiff
Tue Apr 15 16:56:28 1997 UTC (28 years, 8 months ago) by greg
Changes since 2.32: +2 -0 lines
Diff to previous 2.32 , to selected 2.59
added tone mapping to ximage
Wed Feb 5 17:29:44 1997 UTC (28 years, 11 months ago) by greg
Changes since 2.31: +12 -5 lines
Diff to previous 2.31 , to selected 2.59
created pcwarp program
Thu Jan 30 19:26:28 1997 UTC (28 years, 11 months ago) by greg
Changes since 2.30: +1 -5 lines
Diff to previous 2.30 , to selected 2.59
removed psquish, pacuity and pveil, which are now handled by pcond
Thu Jan 9 13:56:37 1997 UTC (29 years ago) by greg
Changes since 2.29: +0 -2 lines
Diff to previous 2.29 , to selected 2.59
Thu Oct 3 16:53:17 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.28: +10 -1 lines
Diff to previous 2.28 , to selected 2.59
created pcond command
Fri Sep 20 16:46:32 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.27: +5 -1 lines
Diff to previous 2.27 , to selected 2.59
added psquish, pveil and pacuity scripts
Wed Jul 24 16:46:25 1996 UTC (29 years, 5 months ago) by greg
Changes since 2.26: +1 -4 lines
Diff to previous 2.26 , to selected 2.59
Mon Apr 1 17:24:41 1996 UTC (29 years, 9 months ago) by greg
Diff to previous 2.25 , to selected 2.59
Thu Feb 15 10:49:05 1996 UTC (29 years, 10 months ago) by greg
Diff to previous 2.24 , to selected 2.59
added xyzimage program for display of XYZE and corrected RGBE pictures
Wed Dec 13 14:07:08 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.23: +5 -2 lines
Diff to previous 2.23 , to selected 2.59
added pmblur script for motion blur
Mon Oct 16 11:43:30 1995 UTC (30 years, 2 months ago) by greg
Diff to previous 2.22 , to selected 2.59
added missing dependencies for macbethcal.o
Sun Oct 15 14:07:26 1995 UTC (30 years, 2 months ago) by greg
Diff to previous 2.21 , to selected 2.59
added ra_xyze program
Wed Oct 11 10:52:33 1995 UTC (30 years, 3 months ago) by greg
Changes since 2.20: +9 -1 lines
Diff to previous 2.20 , to selected 2.59
added macbethcal program
Fri Sep 15 15:52:55 1995 UTC (30 years, 3 months ago) by greg
Diff to previous 2.19 , to selected 2.59
added pdfblur C-shell script
Fri Jun 10 12:51:12 1994 UTC (31 years, 7 months ago) by greg
Changes since 2.18: +13 -7 lines
Diff to previous 2.18 , to selected 2.59
Thu Apr 14 04:53:51 1994 UTC (31 years, 9 months ago) by greg
Diff to previous 2.17 , to selected 2.59
Wed Mar 30 14:25:08 1994 UTC (31 years, 9 months ago) by greg
Diff to previous 2.16 , to selected 2.59
created ra_gif program
Thu Dec 9 17:30:40 1993 UTC (32 years, 1 month ago) by greg
Changes since 2.15: +29 -28 lines
Diff to previous 2.15 , to selected 2.59
Tue Oct 19 17:18:13 1993 UTC (32 years, 2 months ago) by greg
Diff to previous 2.14 , to selected 2.59
removed -n option from compiles
Fri Jun 25 16:35:29 1993 UTC (32 years, 6 months ago) by greg
Diff to previous 2.13 , to selected 2.59
dependency changes for pfilt modules
Thu Jun 10 16:09:04 1993 UTC (32 years, 7 months ago) by greg
Diff to previous 2.12 , to selected 2.59
added ra_avs
Thu Apr 29 13:20:50 1993 UTC (32 years, 8 months ago) by greg
Diff to previous 2.11 , to selected 2.59
dependency change for pcomb.o
Thu Feb 4 21:00:12 1993 UTC (32 years, 11 months ago) by greg
Diff to previous 2.10 , to selected 2.59
added pextrem compile
Tue Nov 3 16:52:22 1992 UTC (33 years, 2 months ago) by greg
Diff to previous 2.9 , to selected 2.59
Tue Oct 13 11:36:17 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.8: +4 -5 lines
Diff to previous 2.8 , to selected 2.59
changed ra_t8 to use clrtab.c
Tue Sep 8 15:33:11 1992 UTC (33 years, 4 months ago) by greg
Diff to previous 2.7 , to selected 2.59
Tue Sep 8 10:33:56 1992 UTC (33 years, 4 months ago) by greg
Diff to previous 2.6 , to selected 2.59
portability fixes
Fri Aug 21 13:49:10 1992 UTC (33 years, 4 months ago) by greg
Diff to previous 2.5 , to selected 2.59
added pextrem program
Mon Jul 13 11:54:29 1992 UTC (33 years, 6 months ago) by greg
Changes since 2.4: +6 -3 lines
Diff to previous 2.4 , to selected 2.59
added ra_ps PostScript translator
Wed Jul 1 15:09:12 1992 UTC (33 years, 6 months ago) by greg
Changes since 2.3: +40 -39 lines
Diff to previous 2.3 , to selected 2.59
Wed Jun 24 09:17:45 1992 UTC (33 years, 6 months ago) by greg
Diff to previous 2.2 , to selected 2.59
Sat Apr 11 16:31:34 1992 UTC (33 years, 9 months ago) by greg
Diff to previous 2.1 , to selected 2.59
added oki20
Wed Nov 13 11:08:32 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.56: +2 -2 lines
Diff to previous 1.56 , to selected 2.59
final changes for release 2.0
Mon Nov 11 14:32:57 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.55: +6 -6 lines
Diff to previous 1.55 , to selected 2.59
changed name prot -> protate
Mon Nov 11 14:01:11 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.54: +9 -4 lines
Diff to previous 1.54 , to selected 2.59
Thu Nov 7 16:36:21 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.53: +6 -3 lines
Diff to previous 1.53 , to selected 2.59
added sgi compile of glimage
Thu Nov 7 11:06:03 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.52: +1 -1 lines
Diff to previous 1.52 , to selected 2.59
removed STRUCTASSIGN macro
Mon Oct 28 16:39:21 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.51: +1 -1 lines
Diff to previous 1.51 , to selected 2.59
compatibility fixes
Mon Oct 28 09:43:19 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.50: +3 -2 lines
Diff to previous 1.50 , to selected 2.59
added SPECIAL macro
Wed Oct 23 09:33:13 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.49: +9 -3 lines
Diff to previous 1.49 , to selected 2.59
added ra_pict program
Fri Aug 23 17:37:26 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.48: +5 -1 lines
Diff to previous 1.48 , to selected 2.59
added ra_rgbe program
Thu Aug 22 09:16:37 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.47: +37 -37 lines
Diff to previous 1.47 , to selected 2.59
moved libraries to ../lib
Fri Aug 16 13:40:12 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.46: +9 -5 lines
Diff to previous 1.46 , to selected 2.59
made installation of ra_tiff automatic
Fri Aug 16 12:42:13 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.45: +4 -1 lines
Diff to previous 1.45 , to selected 2.59
added ra_ppm program
Thu Aug 15 14:32:51 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.44 , to selected 2.59
made ra_tiff compilation optional
Thu Aug 15 13:35:10 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.43: +11 -1 lines
Diff to previous 1.43 , to selected 2.59
added ra_tiff
Thu Aug 8 08:24:06 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.42: +4 -5 lines
Diff to previous 1.42 , to selected 2.59
*** empty log message ***
Thu Jul 18 11:19:19 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.41: +1 -1 lines
Diff to previous 1.41 , to selected 2.59
Mon Jul 15 13:09:05 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.40: +3 -15 lines
Diff to previous 1.40 , to selected 2.59
moved calcomp routines to library
Mon Jul 15 12:33:16 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.39: +77 -100 lines
Diff to previous 1.39 , to selected 2.59
moved a lot of routines into a common library
Thu May 30 08:24:01 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.38: +2 -2 lines
Diff to previous 1.38 , to selected 2.59
added dependency on header.o to psign
Thu May 23 13:45:42 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.37 , to selected 2.59
added falsecolor
Fri May 10 08:54:38 1991 UTC (34 years, 8 months ago) by greg
Diff to previous 1.36 , to selected 2.59
added gamma correction to pvalue
Fri May 3 10:22:05 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.35: +2 -2 lines
Diff to previous 1.35 , to selected 2.59
Thu May 2 17:25:27 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.34: +0 -2 lines
Diff to previous 1.34 , to selected 2.59
x11image.o no longer depends on x11icon.h
Mon Apr 22 12:21:38 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.33: +8 -8 lines
Diff to previous 1.33 , to selected 2.59
changed ximage to x10image, x11image to ximage
Fri Apr 19 13:43:58 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.32: +2 -0 lines
Diff to previous 1.32 , to selected 2.59
added icon for x11image
Thu Apr 11 09:21:26 1991 UTC (34 years, 9 months ago) by greg
Diff to previous 1.31 , to selected 2.59
Wed Mar 20 16:43:33 1991 UTC (34 years, 9 months ago) by greg
Changes since 1.30: +1 -1 lines
Diff to previous 1.30 , to selected 2.59
readded ra_pr and ra_pr24
Thu Mar 7 15:30:53 1991 UTC (34 years, 10 months ago) by greg
Diff to previous 1.29 , to selected 2.59
specialization of Makefile
Wed Mar 6 15:58:22 1991 UTC (34 years, 10 months ago) by greg
Changes since 1.28: +11 -3 lines
Diff to previous 1.28 , to selected 2.59
added special targets for x10, aed and sun
Wed Mar 6 10:14:01 1991 UTC (34 years, 10 months ago) by greg
Changes since 1.27: +11 -3 lines
Diff to previous 1.27 , to selected 2.59
Makefile normalization
Wed Jan 9 12:21:11 1991 UTC (35 years ago) by greg
Changes since 1.26: +1 -1 lines
Diff to previous 1.26 , to selected 2.59
got rid of unnecessary use of standard.h
Wed Jan 9 11:15:26 1991 UTC (35 years ago) by greg
Changes since 1.25: +7 -3 lines
Diff to previous 1.25 , to selected 2.59
added pflip program
Fri Jan 4 23:35:00 1991 UTC (35 years ago) by greg
Diff to previous 1.24 , to selected 2.59
added normpat.csh
Sat Dec 15 15:18:07 1990 UTC (35 years, 1 month ago) by greg
Changes since 1.23: +4 -2 lines
Diff to previous 1.23 , to selected 2.59
added mat4.h dependencies
Sat Dec 8 10:14:31 1990 UTC (35 years, 1 month ago) by greg
Changes since 1.22: +6 -4 lines
Diff to previous 1.22 , to selected 2.59
Tue Dec 4 11:25:41 1990 UTC (35 years, 1 month ago) by greg
Diff to previous 1.21 , to selected 2.59
added standard.h to take care of bcopy() incompatibilities
Sun Oct 21 10:43:48 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.20: +38 -30 lines
Diff to previous 1.20 , to selected 2.59
broke color.c and colrops.c
Fri Oct 19 16:33:30 1990 UTC (35 years, 2 months ago) by greg
Diff to previous 1.19 , to selected 2.59
made conversion from colr scanlines to gamma-corrected bytes
Thu Oct 18 12:25:19 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.18: +5 -2 lines
Diff to previous 1.18 , to selected 2.59
added ra_pr24
Sat Sep 22 11:02:40 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.17: +62 -56 lines
Diff to previous 1.17 , to selected 2.59
added xshowtrace and separated resolu.c from color.c
Tue Mar 6 08:45:24 1990 UTC (35 years, 10 months ago) by greg
Changes since 1.16: +9 -2 lines
Diff to previous 1.16 , to selected 2.59
added x11image
Thu Jan 25 11:47:55 1990 UTC (35 years, 11 months ago) by greg
Changes since 1.15: +4 -1 lines
Diff to previous 1.15 , to selected 2.59
added glimage for Iris
Thu Jan 25 08:28:38 1990 UTC (35 years, 11 months ago) by greg
Diff to previous 1.14 , to selected 2.59
Thu Jan 18 23:58:11 1990 UTC (35 years, 11 months ago) by greg
Diff to previous 1.13 , to selected 2.59
Wed Jan 17 15:12:44 1990 UTC (35 years, 11 months ago) by greg
Diff to previous 1.12 , to selected 2.59
removed vfork() dependency and added -DBSD to Makefile
Fri Jan 5 18:14:26 1990 UTC (36 years ago) by greg
Diff to previous 1.11 , to selected 2.59
fixed missing dependency for ximage.o
Fri Dec 22 10:08:31 1989 UTC (36 years ago) by greg
Diff to previous 1.10 , to selected 2.59
Changed calls to rayview() and pixelview() to matrix transform
Sun Dec 10 17:36:10 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.9: +7 -4 lines
Diff to previous 1.9 , to selected 2.59
added program pinterp
Fri Oct 20 16:55:46 1989 UTC (36 years, 2 months ago) by greg
Diff to previous 1.8 , to selected 2.59
Sat Oct 14 11:36:03 1989 UTC (36 years, 3 months ago) by greg
Diff to previous 1.7 , to selected 2.59
Fri Oct 6 13:33:09 1989 UTC (36 years, 3 months ago) by greg
Changes since 1.6: +4 -1 lines
Diff to previous 1.6 , to selected 2.59
added paintjet
Fri Sep 15 09:10:26 1989 UTC (36 years, 4 months ago) by greg
Diff to previous 1.5 , to selected 2.59
added call to getheader in aedimage
Tue Sep 12 17:53:09 1989 UTC (36 years, 4 months ago) by greg
Diff to previous 1.4 , to selected 2.59
fixed dependencies
Mon Jul 24 08:43:23 1989 UTC (36 years, 5 months ago) by greg
Diff to previous 1.3 , to selected 2.59
added entries for non-automatic creation of ra_pixar
Sat Jul 22 18:20:57 1989 UTC (36 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 2.59
added random dithering
Tue May 9 10:06:45 1989 UTC (36 years, 8 months ago) by greg
Diff to previous 1.1 , to selected 2.59
psum superceded by pcomb
Thu Feb 2 10:48:56 1989 UTC (36 years, 11 months ago) by greg
Diff to selected 2.59
