Simple bilateral filter implementation
Fixed call to configure for accounts w/o '.' in $PATH
Upgraded to TIFF 3.7.3 library
Removed unused modules I missed last time
Updated dependencies for ra_bmp
Removed pbilat.csh until we're ready to distribute it
Call sh configure instead of ./configure to avoid problems with execution bit
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -lm to programs that needed ldexp and frexp
added normtiff program
added OPT flags to libtiff compiles
created ra_hexbit program to generate bitmaps for hexbit4x1.fnt
fixes for TIFF library
added ra_tiff to default list
created phisto script
minor fix
added needed links to -lm for ldexp() and frexp()
incorporated new TIFF library (3.4beta) and Luv image types for ra_tiff
added tone mapping to ximage
created pcwarp program
removed psquish, pacuity and pveil, which are now handled by pcond
changed to histogram truncation made veiling reflection modify FOV sample image
created pcond command
added psquish, pveil and pacuity scripts
added xyzimage program for display of XYZE and corrected RGBE pictures
added pmblur script for motion blur
added missing dependencies for macbethcal.o
added ra_xyze program
added macbethcal program
added pdfblur C-shell script
created ra_gif program
removed -n option from compiles
dependency changes for pfilt modules
added ra_avs
dependency change for pcomb.o
added pextrem compile
changed ra_t8 to use clrtab.c
portability fixes
added pextrem program
added ra_ps PostScript translator
added oki20
final changes for release 2.0
changed name prot -> protate
added sgi compile of glimage
removed STRUCTASSIGN macro
compatibility fixes
added SPECIAL macro
added ra_pict program
added ra_rgbe program
moved libraries to ../lib
made installation of ra_tiff automatic
added ra_ppm program
made ra_tiff compilation optional
added ra_tiff
*** empty log message ***
moved calcomp routines to library
moved a lot of routines into a common library
added dependency on header.o to psign
added falsecolor
added gamma correction to pvalue
x11image.o no longer depends on x11icon.h
changed ximage to x10image, x11image to ximage
added icon for x11image
readded ra_pr and ra_pr24
specialization of Makefile
added special targets for x10, aed and sun
Makefile normalization
got rid of unnecessary use of standard.h
added pflip program
added normpat.csh
added mat4.h dependencies
added standard.h to take care of bcopy() incompatibilities
broke color.c and colrops.c
made conversion from colr scanlines to gamma-corrected bytes
added ra_pr24
added xshowtrace and separated resolu.c from color.c
added x11image
added glimage for Iris
removed vfork() dependency and added -DBSD to Makefile
fixed missing dependency for ximage.o
Changed calls to rayview() and pixelview() to matrix transform
added program pinterp
added paintjet
added call to getheader in aedimage
fixed dependencies
added entries for non-automatic creation of ra_pixar
added random dithering
psum superceded by pcomb
