root/radiance/ray/src/px/README
Revision: 2.5
Committed: Fri Sep 15 18:37:48 1995 UTC (29 years, 10 months ago) by greg
added pdfview.csh
1 PICTURE FILTERS AND TRANSLATORS
2 SCCSid "$SunId$ LBL"
3
4 This directory contains special and general purpose filters for RADIANCE
5 picture files and converters to and from other image formats.
6
7 pic.h header file for reading and writing pictures
8 ciq.h header file for color quantization routines
9 pict.h header file defining Macintosh PICT format
10 rasterfile.h header description for Sun rasterfiles
11 x11icon.h icon for ximage (X10) program
12 x11raster.h header file for X11 routines using images
13 xraster.h header file for X10 routines using images
14 aedimage.c display program for AED 512 color graphics terminal
15 biq.c simple greyscale quantization
16 ciq.c color quantization routine
17 closest.c color quantization - find closest color
18 clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c
19 colorscale.c program to produce color pallets
20 cut.c color quantization - median cut algorithm
21 getinfo.c program to read info. header from file
22 glimage.c simple program to display image on SGI
23 greyscale.c program to produce grey test levels
24 mt160r.c program to dump pixel file to Mannesman-Tally 160
25 neuclrtab.c neural network color quantization code
26 oki20.c program to dump pixel file to OkiMate 20 monochrome printer
27 oki20c.c program to dump pixel file to OkiMate 20 color printer
28 paintjet.c program to dump pixel file to HP PaintJet color printer
29 pcomb.c combine picture files according to calcomp functions
30 pcompos.c program to composite pictures
31 pextrem.c program to find min and max values in picture
32 pf2.c routines used by pfilt
33 pf3.c routines for gaussian and box filtering
34 pfilt.c program to post-process picture file
35 pflip.c flip picture file horizontally and/or vertically
36 pinterp.c interpolate and extrapolate pictures with different views
37 protate.c program to rotate picture file 90 degrees clockwise
38 psign.c produce picture from text
39 psum.c program to sum pictures
40 pvalue.c program to print pixel values
41 ra_avs.c program to convert between RADIANCE and AVS picture format
42 ra_bn.c convert between RADIANCE and barneyscan picture format
43 ra_gif.c program to convert from RADIANCE to GIF format
44 ra_pict.c convert to Macintosh PICT file
45 ra_pixar.c convert to/from PIXAR image file.
46 ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps
47 ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile
48 ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile
49 ra_ps.c program to convert to greyscale PostScript file
50 ra_rgbe.c program to convert from RADIANCE RLE to flat format
51 ra_skel.c skeletal converter between RADIANCE and generic 24-bit format
52 ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats
53 ra_t8.c program to convert between RADIANCE and Targa 8 bit format
54 ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files
55 ra_xim.c program to convert to X11 dump file
56 t4027.c program to dump pixel file to Tektronix 4027
57 ttyimage.c program to dump pixel file to dumb terminal
58 vgaimage.c program to display pixel file on VGA or SVGA card
59 x11findwind.c function to find X11 window by name
60 x11image.c picture display driver for X11
61 x11raster.c routines to handle images for X11
62 xdebugamb.c program for debugging ambient files (experimental)
63 ximage.c picture display driver for X10R4
64 xraster.c routines to handle images for X10
65 xshowtrace.c display a picture under X11 and watch the rays get traced
66 falsecolor.csh C-shell script to produce false color pictures
67 normpat.csh C-shell script to normalize pictures for tiling patterns
68 pdfview.csh post-process picture and depth map to simulate depth of field
69 libtiff/ TIFF image library
