| 1 | PICTURE FILTERS AND TRANSLATORS |
| 2 | SCCSid "$SunId$ LBL" |
| 3 |  |
| 4 | This directory contains special and general purpose filters for RADIANCE |
| 5 | picture files and converters to and from other image formats. |
| 6 |  |
| 7 | ciq.h           header file for color quantization routines |
| 8 | pic.h           header file for reading and writing pictures |
| 9 | pict.h          header file defining Macintosh PICT format |
| 10 | x11icon.h       icon for ximage program |
| 11 | x11raster.h     header file for X11 routines using images |
| 12 | xraster.h       header file for X10 routines using images |
| 13 | biq.c           simple greyscale quantization |
| 14 | ciq.c           color quantization routine |
| 15 | closest.c       color quantization - find closest color |
| 16 | colorscale.c    program to produce color pallets |
| 17 | cut.c           color quantization - median cut algorithm |
| 18 | falsecolor.csh  C-shell script to produce false color pictures |
| 19 | getinfo.c       program to read info. header from file |
| 20 | greyscale.c     program to produce grey test levels |
| 21 | mt160r.c        program to dump pixel file to Mannesman-Tally 160 |
| 22 | normpat.csh     C-shell script to normalize pictures for tiling patterns |
| 23 | oki20c.c        program to dump pixel file to OkiMate 20 color printer |
| 24 | paintjet.c      program to dump pixel file to HP PaintJet color printer |
| 25 | pcomb.c         combine picture files according to calcomp functions |
| 26 | pcompos.c       program to composite pictures |
| 27 | pf2.c           routines used by pfilt |
| 28 | pf3.c           routines for gaussian and box filtering |
| 29 | pfilt.c         program to post-process picture file |
| 30 | pflip.c         flip picture file horizontally and/or vertically |
| 31 | pinterp.c       interpolate and extrapolate pictures with different views |
| 32 | prot.c          program to rotate picture file 90 degrees clockwise |
| 33 | psign.c         produce picture from text |
| 34 | psum.c          program to sum pictures |
| 35 | pvalue.c        program to print pixel values |
| 36 | ra_bn.c         convert between RADIANCE and barneyscan picture format |
| 37 | ra_pict.c       from RADIANCE image file to PIXAR image file.  (or vice versa) |
| 38 | ra_ppm.c        program to convert between RADIANCE and Poskanzer Pixmaps |
| 39 | ra_pr.c         program to convert between RADIANCE and Sun 8-bit rasterfile |
| 40 | ra_pr24.c       program to convert between RADIANCE and 24-bit rasterfile |
| 41 | ra_rgbe.c       program to convert from RADIANCE RLE to flat format |
| 42 | ra_t16.c        program to convert between RADIANCE and Targa 15+ bit formats |
| 43 | ra_t8.c         program to convert between RADIANCE and Targa 8 bit format |
| 44 | ra_tiff.c       program to convert between RADIANCE and 24-bit TIFF files |
| 45 | t4027.c         program to dump pixel file to Tektronix 4027 |
| 46 | ttyimage.c      program to dump pixel file to dumb terminal |
| 47 | x11image.c      driver for X11 |
| 48 | xraster.c       routines to handle images for X10 |
| 49 | xshowtrace.c    display an image and watch the rays get traced |
