--- ray/src/px/README 1996/10/22 13:19:14 2.8 +++ ray/src/px/README 2004/11/08 18:49:18 2.11 @@ -1,32 +1,18 @@ PICTURE FILTERS AND TRANSLATORS - SCCSid "$SunId$ LBL" + SCCSid "@(#)README 2.8 10/22/96 LBL" This directory contains special and general purpose filters for RADIANCE picture files and converters to and from other image formats. pcond.h header file for picture conditioning program pcond pic.h header file for reading and writing pictures -ciq.h header file for color quantization routines pict.h header file defining Macintosh PICT format rasterfile.h header description for Sun rasterfiles -x11icon.h icon for ximage (X10) program x11raster.h header file for X11 routines using images -xraster.h header file for X10 routines using images aedimage.c display program for AED 512 color graphics terminal -biq.c simple greyscale quantization -ciq.c color quantization routine -closest.c color quantization - find closest color -clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c -colorscale.c program to produce color pallets -cut.c color quantization - median cut algorithm -glimage.c simple program to display image on SGI -greyscale.c program to produce grey test levels +clrtab.c median-cut color quantization routines for 8-bit output macbethcal.c program to calibrate image conversion using Macbeth chart -mt160r.c program to dump pixel file to Mannesman-Tally 160 neuclrtab.c neural network color quantization code -oki20.c program to dump pixel file to OkiMate 20 monochrome printer -oki20c.c program to dump pixel file to OkiMate 20 color printer -paintjet.c program to dump pixel file to HP PaintJet color printer pcomb.c combine picture files according to calcomp functions pcompos.c program to composite pictures pcond.c condition Radiance picture for display/output @@ -42,36 +28,25 @@ pinterp.c interpolate and extrapolate pictures with di pmapgen.c affine transformation for image mapping used by macbethcal protate.c program to rotate picture file 90 degrees clockwise psign.c produce picture from text -psum.c program to sum pictures pvalue.c program to print pixel values -ra_avs.c program to convert between RADIANCE and AVS picture format -ra_bn.c convert between RADIANCE and barneyscan picture format ra_gif.c program to convert from RADIANCE to GIF format ra_pict.c convert to Macintosh PICT file -ra_pixar.c convert to/from PIXAR image file. ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps -ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile -ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile ra_ps.c program to convert to greyscale PostScript file ra_rgbe.c program to convert from RADIANCE RLE to flat format ra_skel.c skeletal converter between RADIANCE and generic 24-bit format ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats ra_t8.c program to convert between RADIANCE and Targa 8 bit format ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files -ra_xim.c program to convert to X11 dump file -t4027.c program to dump pixel file to Tektronix 4027 ttyimage.c program to dump pixel file to dumb terminal vgaimage.c program to display pixel file on VGA or SVGA card x11findwind.c function to find X11 window by name x11image.c picture display driver for X11 x11raster.c routines to handle images for X11 -xdebugamb.c program for debugging ambient files (experimental) -ximage.c picture display driver for X10R4 -xraster.c routines to handle images for X10 xshowtrace.c display a picture under X11 and watch the rays get traced falsecolor.csh C-shell script to produce false color pictures normpat.csh C-shell script to normalize pictures for tiling patterns pdfblur.csh compute views for depth of field blurring pmblur.csh compute views for motion blurring xyzimage.csh display images correctly for a particular monitor's primaries -libtiff/ TIFF image library +tiff/ TIFF image library
