--- ray/src/px/README 1992/09/30 11:41:24 2.2 +++ ray/src/px/README 1996/07/24 16:47:26 2.7 @@ -4,25 +4,25 @@ This directory contains special and general purpose filters for RADIANCE picture files and converters to and from other image formats. -ciq.h header file for color quantization routines pic.h header file for reading and writing pictures +ciq.h header file for color quantization routines pict.h header file defining Macintosh PICT format rasterfile.h header description for Sun rasterfiles -x11icon.h icon for ximage program +x11icon.h icon for ximage (X10) program x11raster.h header file for X11 routines using images xraster.h header file for X10 routines using images aedimage.c display program for AED 512 color graphics terminal biq.c simple greyscale quantization ciq.c color quantization routine closest.c color quantization - find closest color +clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c colorscale.c program to produce color pallets cut.c color quantization - median cut algorithm -falsecolor.csh C-shell script to produce false color pictures -getinfo.c program to read info. header from file glimage.c simple program to display image on SGI greyscale.c program to produce grey test levels +macbethcal.c program to calibrate image conversion using Macbeth chart mt160r.c program to dump pixel file to Mannesman-Tally 160 -normpat.csh C-shell script to normalize pictures for tiling patterns +neuclrtab.c neural network color quantization code oki20.c program to dump pixel file to OkiMate 20 monochrome printer oki20c.c program to dump pixel file to OkiMate 20 color printer paintjet.c program to dump pixel file to HP PaintJet color printer @@ -34,11 +34,14 @@ pf3.c routines for gaussian and box filtering pfilt.c program to post-process picture file pflip.c flip picture file horizontally and/or vertically pinterp.c interpolate and extrapolate pictures with different views +pmapgen.c affine transformation for image mapping used by macbethcal protate.c program to rotate picture file 90 degrees clockwise psign.c produce picture from text psum.c program to sum pictures pvalue.c program to print pixel values +ra_avs.c program to convert between RADIANCE and AVS picture format ra_bn.c convert between RADIANCE and barneyscan picture format +ra_gif.c program to convert from RADIANCE to GIF format ra_pict.c convert to Macintosh PICT file ra_pixar.c convert to/from PIXAR image file. ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps @@ -53,8 +56,17 @@ ra_tiff.c program to convert between RADIANCE and 24-b ra_xim.c program to convert to X11 dump file t4027.c program to dump pixel file to Tektronix 4027 ttyimage.c program to dump pixel file to dumb terminal +vgaimage.c program to display pixel file on VGA or SVGA card x11findwind.c function to find X11 window by name x11image.c picture display driver for X11 +x11raster.c routines to handle images for X11 +xdebugamb.c program for debugging ambient files (experimental) ximage.c picture display driver for X10R4 xraster.c routines to handle images for X10 xshowtrace.c display a picture under X11 and watch the rays get traced +falsecolor.csh C-shell script to produce false color pictures +normpat.csh C-shell script to normalize pictures for tiling patterns +pdfblur.csh compute views for depth of field blurring +pmblur.csh compute views for motion blurring +xyzimage.csh display images correctly for a particular monitor's primaries +libtiff/ TIFF image library
