--- ray/src/px/README 1991/11/11 16:14:20 1.1 +++ ray/src/px/README 2005/09/17 05:14:14 2.12 @@ -1,49 +1,55 @@ PICTURE FILTERS AND TRANSLATORS - SCCSid "$SunId$ LBL" + SCCSid "@(#)README 2.8 10/22/96 LBL" This directory contains special and general purpose filters for RADIANCE picture files and converters to and from other image formats. -ciq.h header file for color quantization routines +pcond.h header file for picture conditioning program pcond pic.h header file for reading and writing pictures pict.h header file defining Macintosh PICT format -x11icon.h icon for ximage program +rasterfile.h header description for Sun rasterfiles x11raster.h header file for X11 routines using images -xraster.h header file for X10 routines using images -biq.c simple greyscale quantization -ciq.c color quantization routine -closest.c color quantization - find closest color -colorscale.c program to produce color pallets -cut.c color quantization - median cut algorithm -falsecolor.csh C-shell script to produce false color pictures -getinfo.c program to read info. header from file -greyscale.c program to produce grey test levels -mt160r.c program to dump pixel file to Mannesman-Tally 160 -normpat.csh C-shell script to normalize pictures for tiling patterns -oki20c.c program to dump pixel file to OkiMate 20 color printer -paintjet.c program to dump pixel file to HP PaintJet color printer +aedimage.c display program for AED 512 color graphics terminal +clrtab.c median-cut color quantization routines for 8-bit output +macbethcal.c program to calibrate image conversion using Macbeth chart +neuclrtab.c neural network color quantization code pcomb.c combine picture files according to calcomp functions pcompos.c program to composite pictures +pcond.c condition Radiance picture for display/output +pcond2.c pcond input and output conditioning routines for pcond. +pcond3.c pcond routines for computing and applying brightness mapping. +pcond4.c pcond routines for veiling glare and loss of acuity. +pextrem.c program to find min and max values in picture pf2.c routines used by pfilt pf3.c routines for gaussian and box filtering pfilt.c program to post-process picture file pflip.c flip picture file horizontally and/or vertically pinterp.c interpolate and extrapolate pictures with different views -prot.c program to rotate picture file 90 degrees clockwise +pmapgen.c affine transformation for image mapping used by macbethcal +protate.c program to rotate picture file 90 degrees clockwise psign.c produce picture from text -psum.c program to sum pictures pvalue.c program to print pixel values -ra_bn.c convert between RADIANCE and barneyscan picture format -ra_pict.c from RADIANCE image file to PIXAR image file. (or vice versa) +ra_gif.c program to convert from RADIANCE to GIF format +ra_pict.c convert to Macintosh PICT file ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps -ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile -ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile +ra_ps.c program to convert to greyscale PostScript file ra_rgbe.c program to convert from RADIANCE RLE to flat format +ra_skel.c skeletal converter between RADIANCE and generic 24-bit format ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats ra_t8.c program to convert between RADIANCE and Targa 8 bit format ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files -t4027.c program to dump pixel file to Tektronix 4027 ttyimage.c program to dump pixel file to dumb terminal -x11image.c driver for X11 -xraster.c routines to handle images for X10 -xshowtrace.c display an image and watch the rays get traced +vgaimage.c program to display pixel file on VGA or SVGA card +x11findwind.c function to find X11 window by name +x11image.c picture display driver for X11 +x11raster.c routines to handle images for X11 +xshowtrace.c display a picture under X11 and watch the rays get traced +falsecolor.csh C-shell script to produce false color pictures +normpat.csh C-shell script to normalize pictures for tiling patterns +pdfblur.csh compute views for depth of field blurring +pgblur.csh Gaussian blur function +pmblur.csh compute views for motion blurring +pmdblur.csh compute views for combined motion and depth-of-field blurring +ran2tiff.csh expose and convert animation frames using pcond and ra_tiff +xyzimage.csh display images correctly for a particular monitor's primaries +tiff/ TIFF image library
