1 |
PICTURE FILTERS AND TRANSLATORS |
2 |
SCCSid "$SunId$ LBL" |
3 |
4 |
This directory contains special and general purpose filters for RADIANCE |
5 |
picture files and converters to and from other image formats. |
6 |
7 |
pic.h header file for reading and writing pictures |
8 |
ciq.h header file for color quantization routines |
9 |
pict.h header file defining Macintosh PICT format |
10 |
rasterfile.h header description for Sun rasterfiles |
11 |
x11icon.h icon for ximage (X10) program |
12 |
x11raster.h header file for X11 routines using images |
13 |
xraster.h header file for X10 routines using images |
14 |
aedimage.c display program for AED 512 color graphics terminal |
15 |
biq.c simple greyscale quantization |
16 |
ciq.c color quantization routine |
17 |
closest.c color quantization - find closest color |
18 |
clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c |
19 |
colorscale.c program to produce color pallets |
20 |
cut.c color quantization - median cut algorithm |
21 |
getinfo.c program to read info. header from file |
22 |
glimage.c simple program to display image on SGI |
23 |
greyscale.c program to produce grey test levels |
24 |
mt160r.c program to dump pixel file to Mannesman-Tally 160 |
25 |
neuclrtab.c neural network color quantization code |
26 |
oki20.c program to dump pixel file to OkiMate 20 monochrome printer |
27 |
oki20c.c program to dump pixel file to OkiMate 20 color printer |
28 |
paintjet.c program to dump pixel file to HP PaintJet color printer |
29 |
pcomb.c combine picture files according to calcomp functions |
30 |
pcompos.c program to composite pictures |
31 |
pextrem.c program to find min and max values in picture |
32 |
pf2.c routines used by pfilt |
33 |
pf3.c routines for gaussian and box filtering |
34 |
pfilt.c program to post-process picture file |
35 |
pflip.c flip picture file horizontally and/or vertically |
36 |
pinterp.c interpolate and extrapolate pictures with different views |
37 |
protate.c program to rotate picture file 90 degrees clockwise |
38 |
psign.c produce picture from text |
39 |
psum.c program to sum pictures |
40 |
pvalue.c program to print pixel values |
41 |
ra_avs.c program to convert between RADIANCE and AVS picture format |
42 |
ra_bn.c convert between RADIANCE and barneyscan picture format |
43 |
ra_gif.c program to convert from RADIANCE to GIF format |
44 |
ra_pict.c convert to Macintosh PICT file |
45 |
ra_pixar.c convert to/from PIXAR image file. |
46 |
ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps |
47 |
ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile |
48 |
ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile |
49 |
ra_ps.c program to convert to greyscale PostScript file |
50 |
ra_rgbe.c program to convert from RADIANCE RLE to flat format |
51 |
ra_skel.c skeletal converter between RADIANCE and generic 24-bit format |
52 |
ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats |
53 |
ra_t8.c program to convert between RADIANCE and Targa 8 bit format |
54 |
ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files |
55 |
ra_xim.c program to convert to X11 dump file |
56 |
t4027.c program to dump pixel file to Tektronix 4027 |
57 |
ttyimage.c program to dump pixel file to dumb terminal |
58 |
vgaimage.c program to display pixel file on VGA or SVGA card |
59 |
x11findwind.c function to find X11 window by name |
60 |
x11image.c picture display driver for X11 |
61 |
x11raster.c routines to handle images for X11 |
62 |
xdebugamb.c program for debugging ambient files (experimental) |
63 |
ximage.c picture display driver for X10R4 |
64 |
xraster.c routines to handle images for X10 |
65 |
xshowtrace.c display a picture under X11 and watch the rays get traced |
66 |
falsecolor.csh C-shell script to produce false color pictures |
67 |
normpat.csh C-shell script to normalize pictures for tiling patterns |
68 |
libtiff/ TIFF image library |
