--- ray/src/px/README 1991/11/12 16:05:49 2.1 +++ ray/src/px/README 1996/03/15 21:10:43 2.6 @@ -4,47 +4,70 @@ This directory contains special and general purpose filters for RADIANCE picture files and converters to and from other image formats. -ciq.h header file for color quantization routines pic.h header file for reading and writing pictures +ciq.h header file for color quantization routines pict.h header file defining Macintosh PICT format -x11icon.h icon for ximage program +rasterfile.h header description for Sun rasterfiles +x11icon.h icon for ximage (X10) program x11raster.h header file for X11 routines using images xraster.h header file for X10 routines using images +aedimage.c display program for AED 512 color graphics terminal biq.c simple greyscale quantization ciq.c color quantization routine closest.c color quantization - find closest color +clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c colorscale.c program to produce color pallets cut.c color quantization - median cut algorithm -falsecolor.csh C-shell script to produce false color pictures getinfo.c program to read info. header from file +glimage.c simple program to display image on SGI greyscale.c program to produce grey test levels +macbethcal.c program to calibrate image conversion using Macbeth chart mt160r.c program to dump pixel file to Mannesman-Tally 160 -normpat.csh C-shell script to normalize pictures for tiling patterns +neuclrtab.c neural network color quantization code +oki20.c program to dump pixel file to OkiMate 20 monochrome printer oki20c.c program to dump pixel file to OkiMate 20 color printer paintjet.c program to dump pixel file to HP PaintJet color printer pcomb.c combine picture files according to calcomp functions pcompos.c program to composite pictures +pextrem.c program to find min and max values in picture pf2.c routines used by pfilt pf3.c routines for gaussian and box filtering pfilt.c program to post-process picture file pflip.c flip picture file horizontally and/or vertically pinterp.c interpolate and extrapolate pictures with different views -prot.c program to rotate picture file 90 degrees clockwise +pmapgen.c affine transformation for image mapping used by macbethcal +protate.c program to rotate picture file 90 degrees clockwise psign.c produce picture from text psum.c program to sum pictures pvalue.c program to print pixel values +ra_avs.c program to convert between RADIANCE and AVS picture format ra_bn.c convert between RADIANCE and barneyscan picture format -ra_pict.c from RADIANCE image file to PIXAR image file. (or vice versa) +ra_gif.c program to convert from RADIANCE to GIF format +ra_pict.c convert to Macintosh PICT file +ra_pixar.c convert to/from PIXAR image file. ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile +ra_ps.c program to convert to greyscale PostScript file ra_rgbe.c program to convert from RADIANCE RLE to flat format ra_skel.c skeletal converter between RADIANCE and generic 24-bit format ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats ra_t8.c program to convert between RADIANCE and Targa 8 bit format ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files +ra_xim.c program to convert to X11 dump file t4027.c program to dump pixel file to Tektronix 4027 ttyimage.c program to dump pixel file to dumb terminal -x11image.c driver for X11 +vgaimage.c program to display pixel file on VGA or SVGA card +x11findwind.c function to find X11 window by name +x11image.c picture display driver for X11 +x11raster.c routines to handle images for X11 +xdebugamb.c program for debugging ambient files (experimental) +ximage.c picture display driver for X10R4 xraster.c routines to handle images for X10 -xshowtrace.c display an image and watch the rays get traced +xshowtrace.c display a picture under X11 and watch the rays get traced +falsecolor.csh C-shell script to produce false color pictures +normpat.csh C-shell script to normalize pictures for tiling patterns +pdfblur.csh compute views for depth of field blurring +pmblur.csh compute views for motion blurring +xyzimage.csh display images correctly for a particular monitor's primaries +libtiff/ TIFF image library
