| 1 |
PICTURE FILTERS AND TRANSLATORS
| 2 |
SCCSid "$SunId$ LBL"
| 3 |
| 4 |
This directory contains special and general purpose filters for RADIANCE
| 5 |
picture files and converters to and from other image formats.
| 6 |
| 7 |
pcond.h header file for picture conditioning program pcond
| 8 |
pic.h header file for reading and writing pictures
| 9 |
ciq.h header file for color quantization routines
| 10 |
pict.h header file defining Macintosh PICT format
| 11 |
rasterfile.h header description for Sun rasterfiles
| 12 |
x11icon.h icon for ximage (X10) program
| 13 |
x11raster.h header file for X11 routines using images
| 14 |
xraster.h header file for X10 routines using images
| 15 |
aedimage.c display program for AED 512 color graphics terminal
| 16 |
biq.c simple greyscale quantization
| 17 |
ciq.c color quantization routine
| 18 |
closest.c color quantization - find closest color
| 19 |
clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c
| 20 |
colorscale.c program to produce color pallets
| 21 |
cut.c color quantization - median cut algorithm
| 22 |
glimage.c simple program to display image on SGI
| 23 |
greyscale.c program to produce grey test levels
| 24 |
macbethcal.c program to calibrate image conversion using Macbeth chart
| 25 |
mt160r.c program to dump pixel file to Mannesman-Tally 160
| 26 |
neuclrtab.c neural network color quantization code
| 27 |
oki20.c program to dump pixel file to OkiMate 20 monochrome printer
| 28 |
oki20c.c program to dump pixel file to OkiMate 20 color printer
| 29 |
paintjet.c program to dump pixel file to HP PaintJet color printer
| 30 |
pcomb.c combine picture files according to calcomp functions
| 31 |
pcompos.c program to composite pictures
| 32 |
pcond.c condition Radiance picture for display/output
| 33 |
pcond2.c pcond input and output conditioning routines for pcond.
| 34 |
pcond3.c pcond routines for computing and applying brightness mapping.
| 35 |
pcond4.c pcond routines for veiling glare and loss of acuity.
| 36 |
pextrem.c program to find min and max values in picture
| 37 |
pf2.c routines used by pfilt
| 38 |
pf3.c routines for gaussian and box filtering
| 39 |
pfilt.c program to post-process picture file
| 40 |
pflip.c flip picture file horizontally and/or vertically
| 41 |
pinterp.c interpolate and extrapolate pictures with different views
| 42 |
pmapgen.c affine transformation for image mapping used by macbethcal
| 43 |
protate.c program to rotate picture file 90 degrees clockwise
| 44 |
psign.c produce picture from text
| 45 |
psum.c program to sum pictures
| 46 |
pvalue.c program to print pixel values
| 47 |
ra_avs.c program to convert between RADIANCE and AVS picture format
| 48 |
ra_bn.c convert between RADIANCE and barneyscan picture format
| 49 |
ra_gif.c program to convert from RADIANCE to GIF format
| 50 |
ra_pict.c convert to Macintosh PICT file
| 51 |
ra_pixar.c convert to/from PIXAR image file.
| 52 |
ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps
| 53 |
ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile
| 54 |
ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile
| 55 |
ra_ps.c program to convert to greyscale PostScript file
| 56 |
ra_rgbe.c program to convert from RADIANCE RLE to flat format
| 57 |
ra_skel.c skeletal converter between RADIANCE and generic 24-bit format
| 58 |
ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats
| 59 |
ra_t8.c program to convert between RADIANCE and Targa 8 bit format
| 60 |
ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files
| 61 |
ra_xim.c program to convert to X11 dump file
| 62 |
t4027.c program to dump pixel file to Tektronix 4027
| 63 |
ttyimage.c program to dump pixel file to dumb terminal
| 64 |
vgaimage.c program to display pixel file on VGA or SVGA card
| 65 |
x11findwind.c function to find X11 window by name
| 66 |
x11image.c picture display driver for X11
| 67 |
x11raster.c routines to handle images for X11
| 68 |
xdebugamb.c program for debugging ambient files (experimental)
| 69 |
ximage.c picture display driver for X10R4
| 70 |
xraster.c routines to handle images for X10
| 71 |
xshowtrace.c display a picture under X11 and watch the rays get traced
| 72 |
falsecolor.csh C-shell script to produce false color pictures
| 73 |
normpat.csh C-shell script to normalize pictures for tiling patterns
| 74 |
pdfblur.csh compute views for depth of field blurring
| 75 |
pmblur.csh compute views for motion blurring
| 76 |
xyzimage.csh display images correctly for a particular monitor's primaries
| 77 |
libtiff/ TIFF image library
