root/radiance/ray/src/px/README
Revision: 2.9
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
# User Rev Content
1 greg 1.1 PICTURE FILTERS AND TRANSLATORS
2 greg 2.9 SCCSid "@(#)README 2.8 10/22/96 LBL"
3 greg 1.1
4     This directory contains special and general purpose filters for RADIANCE
5     picture files and converters to and from other image formats.
6
7 greg 2.8 pcond.h header file for picture conditioning program pcond
8 greg 2.4 pic.h header file for reading and writing pictures
9 greg 1.1 ciq.h header file for color quantization routines
10     pict.h header file defining Macintosh PICT format
11 greg 2.2 rasterfile.h header description for Sun rasterfiles
12 greg 2.4 x11icon.h icon for ximage (X10) program
13 greg 1.1 x11raster.h header file for X11 routines using images
14     xraster.h header file for X10 routines using images
15 greg 2.2 aedimage.c display program for AED 512 color graphics terminal
16 greg 1.1 biq.c simple greyscale quantization
17     ciq.c color quantization routine
18     closest.c color quantization - find closest color
19 greg 2.4 clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c
20 greg 1.1 colorscale.c program to produce color pallets
21     cut.c color quantization - median cut algorithm
22 greg 2.2 glimage.c simple program to display image on SGI
23 greg 1.1 greyscale.c program to produce grey test levels
24 greg 2.6 macbethcal.c program to calibrate image conversion using Macbeth chart
25 greg 1.1 mt160r.c program to dump pixel file to Mannesman-Tally 160
26 greg 2.4 neuclrtab.c neural network color quantization code
27 greg 2.2 oki20.c program to dump pixel file to OkiMate 20 monochrome printer
28 greg 1.1 oki20c.c program to dump pixel file to OkiMate 20 color printer
29     paintjet.c program to dump pixel file to HP PaintJet color printer
30     pcomb.c combine picture files according to calcomp functions
31     pcompos.c program to composite pictures
32 greg 2.8 pcond.c condition Radiance picture for display/output
33     pcond2.c pcond input and output conditioning routines for pcond.
34     pcond3.c pcond routines for computing and applying brightness mapping.
35     pcond4.c pcond routines for veiling glare and loss of acuity.
36 greg 2.2 pextrem.c program to find min and max values in picture
37 greg 1.1 pf2.c routines used by pfilt
38     pf3.c routines for gaussian and box filtering
39     pfilt.c program to post-process picture file
40     pflip.c flip picture file horizontally and/or vertically
41     pinterp.c interpolate and extrapolate pictures with different views
42 greg 2.6 pmapgen.c affine transformation for image mapping used by macbethcal
43 greg 2.2 protate.c program to rotate picture file 90 degrees clockwise
44 greg 1.1 psign.c produce picture from text
45     psum.c program to sum pictures
46     pvalue.c program to print pixel values
47 greg 2.4 ra_avs.c program to convert between RADIANCE and AVS picture format
48 greg 1.1 ra_bn.c convert between RADIANCE and barneyscan picture format
49 greg 2.4 ra_gif.c program to convert from RADIANCE to GIF format
50 greg 2.2 ra_pict.c convert to Macintosh PICT file
51     ra_pixar.c convert to/from PIXAR image file.
52 greg 1.1 ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps
53     ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile
54     ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile
55 greg 2.2 ra_ps.c program to convert to greyscale PostScript file
56 greg 1.1 ra_rgbe.c program to convert from RADIANCE RLE to flat format
57 greg 2.1 ra_skel.c skeletal converter between RADIANCE and generic 24-bit format
58 greg 1.1 ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats
59     ra_t8.c program to convert between RADIANCE and Targa 8 bit format
60     ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files
61 greg 2.2 ra_xim.c program to convert to X11 dump file
62 greg 1.1 t4027.c program to dump pixel file to Tektronix 4027
63     ttyimage.c program to dump pixel file to dumb terminal
64 greg 2.3 vgaimage.c program to display pixel file on VGA or SVGA card
65 greg 2.2 x11findwind.c function to find X11 window by name
66     x11image.c picture display driver for X11
67 greg 2.4 x11raster.c routines to handle images for X11
68     xdebugamb.c program for debugging ambient files (experimental)
69 greg 2.2 ximage.c picture display driver for X10R4
70 greg 1.1 xraster.c routines to handle images for X10
71 greg 2.2 xshowtrace.c display a picture under X11 and watch the rays get traced
72 greg 2.4 falsecolor.csh C-shell script to produce false color pictures
73     normpat.csh C-shell script to normalize pictures for tiling patterns
74 greg 2.6 pdfblur.csh compute views for depth of field blurring
75     pmblur.csh compute views for motion blurring
76     xyzimage.csh display images correctly for a particular monitor's primaries
77 greg 2.4 libtiff/ TIFF image library
