root/Development/ray/src/px/README
Revision: 1.1
Committed: Mon Nov 11 16:14:20 1991 UTC (33 years, 10 months ago) by greg
1 PICTURE FILTERS AND TRANSLATORS
2 SCCSid "$SunId$ LBL"
3
4 This directory contains special and general purpose filters for RADIANCE
5 picture files and converters to and from other image formats.
6
7 ciq.h header file for color quantization routines
8 pic.h header file for reading and writing pictures
9 pict.h header file defining Macintosh PICT format
10 x11icon.h icon for ximage program
11 x11raster.h header file for X11 routines using images
12 xraster.h header file for X10 routines using images
13 biq.c simple greyscale quantization
14 ciq.c color quantization routine
15 closest.c color quantization - find closest color
16 colorscale.c program to produce color pallets
17 cut.c color quantization - median cut algorithm
18 falsecolor.csh C-shell script to produce false color pictures
19 getinfo.c program to read info. header from file
20 greyscale.c program to produce grey test levels
21 mt160r.c program to dump pixel file to Mannesman-Tally 160
22 normpat.csh C-shell script to normalize pictures for tiling patterns
23 oki20c.c program to dump pixel file to OkiMate 20 color printer
24 paintjet.c program to dump pixel file to HP PaintJet color printer
25 pcomb.c combine picture files according to calcomp functions
26 pcompos.c program to composite pictures
27 pf2.c routines used by pfilt
28 pf3.c routines for gaussian and box filtering
29 pfilt.c program to post-process picture file
30 pflip.c flip picture file horizontally and/or vertically
31 pinterp.c interpolate and extrapolate pictures with different views
32 prot.c program to rotate picture file 90 degrees clockwise
33 psign.c produce picture from text
34 psum.c program to sum pictures
35 pvalue.c program to print pixel values
36 ra_bn.c convert between RADIANCE and barneyscan picture format
37 ra_pict.c from RADIANCE image file to PIXAR image file. (or vice versa)
38 ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps
39 ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile
40 ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile
41 ra_rgbe.c program to convert from RADIANCE RLE to flat format
42 ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats
43 ra_t8.c program to convert between RADIANCE and Targa 8 bit format
44 ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files
45 t4027.c program to dump pixel file to Tektronix 4027
46 ttyimage.c program to dump pixel file to dumb terminal
47 x11image.c driver for X11
48 xraster.c routines to handle images for X10
49 xshowtrace.c display an image and watch the rays get traced
