root/radiance/ray/src/px/README
Revision: 2.9
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 6 months ago) by greg
1 PICTURE FILTERS AND TRANSLATORS
2 SCCSid "@(#)README 2.8 10/22/96 LBL"
3
4 This directory contains special and general purpose filters for RADIANCE
5 picture files and converters to and from other image formats.
6
7 pcond.h header file for picture conditioning program pcond
8 pic.h header file for reading and writing pictures
9 ciq.h header file for color quantization routines
10 pict.h header file defining Macintosh PICT format
11 rasterfile.h header description for Sun rasterfiles
12 x11icon.h icon for ximage (X10) program
13 x11raster.h header file for X11 routines using images
14 xraster.h header file for X10 routines using images
15 aedimage.c display program for AED 512 color graphics terminal
16 biq.c simple greyscale quantization
17 ciq.c color quantization routine
18 closest.c color quantization - find closest color
19 clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c
20 colorscale.c program to produce color pallets
21 cut.c color quantization - median cut algorithm
22 glimage.c simple program to display image on SGI
23 greyscale.c program to produce grey test levels
24 macbethcal.c program to calibrate image conversion using Macbeth chart
25 mt160r.c program to dump pixel file to Mannesman-Tally 160
26 neuclrtab.c neural network color quantization code
27 oki20.c program to dump pixel file to OkiMate 20 monochrome printer
28 oki20c.c program to dump pixel file to OkiMate 20 color printer
29 paintjet.c program to dump pixel file to HP PaintJet color printer
30 pcomb.c combine picture files according to calcomp functions
31 pcompos.c program to composite pictures
32 pcond.c condition Radiance picture for display/output
33 pcond2.c pcond input and output conditioning routines for pcond.
34 pcond3.c pcond routines for computing and applying brightness mapping.
35 pcond4.c pcond routines for veiling glare and loss of acuity.
36 pextrem.c program to find min and max values in picture
37 pf2.c routines used by pfilt
38 pf3.c routines for gaussian and box filtering
39 pfilt.c program to post-process picture file
40 pflip.c flip picture file horizontally and/or vertically
41 pinterp.c interpolate and extrapolate pictures with different views
42 pmapgen.c affine transformation for image mapping used by macbethcal
43 protate.c program to rotate picture file 90 degrees clockwise
44 psign.c produce picture from text
45 psum.c program to sum pictures
46 pvalue.c program to print pixel values
47 ra_avs.c program to convert between RADIANCE and AVS picture format
48 ra_bn.c convert between RADIANCE and barneyscan picture format
49 ra_gif.c program to convert from RADIANCE to GIF format
50 ra_pict.c convert to Macintosh PICT file
51 ra_pixar.c convert to/from PIXAR image file.
52 ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps
53 ra_pr.c program to convert between RADIANCE and Sun 8-bit rasterfile
54 ra_pr24.c program to convert between RADIANCE and 24-bit rasterfile
55 ra_ps.c program to convert to greyscale PostScript file
56 ra_rgbe.c program to convert from RADIANCE RLE to flat format
57 ra_skel.c skeletal converter between RADIANCE and generic 24-bit format
58 ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats
59 ra_t8.c program to convert between RADIANCE and Targa 8 bit format
60 ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files
61 ra_xim.c program to convert to X11 dump file
62 t4027.c program to dump pixel file to Tektronix 4027
63 ttyimage.c program to dump pixel file to dumb terminal
64 vgaimage.c program to display pixel file on VGA or SVGA card
65 x11findwind.c function to find X11 window by name
66 x11image.c picture display driver for X11
67 x11raster.c routines to handle images for X11
68 xdebugamb.c program for debugging ambient files (experimental)
69 ximage.c picture display driver for X10R4
70 xraster.c routines to handle images for X10
71 xshowtrace.c display a picture under X11 and watch the rays get traced
72 falsecolor.csh C-shell script to produce false color pictures
73 normpat.csh C-shell script to normalize pictures for tiling patterns
74 pdfblur.csh compute views for depth of field blurring
75 pmblur.csh compute views for motion blurring
76 xyzimage.csh display images correctly for a particular monitor's primaries
77 libtiff/ TIFF image library
