root/radiance/ray/src/ot/wfconv.c
Revision: 2.14
Committed: Wed Jun 11 00:08:30 2014 UTC (9 years, 11 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1
Fixed bug in small polygon triangulation
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.14 static const char RCSid[] = "$Id: wfconv.c,v 2.13 2014/06/10 23:19:00 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Load Wavefront .OBJ file and convert to triangles with mesh info.
6     * Code borrowed largely from obj2rad.c
7     */
8
9     #include "copyright.h"
10     #include "standard.h"
11     #include "cvmesh.h"
12 greg 2.11 #include "triangulate.h"
13 greg 2.1 #include <ctype.h>
14
15     typedef int VNDX[3]; /* vertex index (point,map,normal) */
16
17     #define CHUNKSIZ 1024 /* vertex allocation chunk size */
18
19 greg 2.9 #define MAXARG 512 /* maximum # arguments in a statement */
20 greg 2.1
21 greg 2.3 static FVECT *vlist; /* our vertex list */
22     static int nvs; /* number of vertices in our list */
23     static FVECT *vnlist; /* vertex normal list */
24     static int nvns;
25 schorsch 2.5 static RREAL (*vtlist)[2]; /* map vertex list */
26 greg 2.3 static int nvts;
27
28     static char *inpfile; /* input file name */
29     static int havemats; /* materials available? */
30 greg 2.10 static char material[256]; /* current material name */
31     static char group[256]; /* current group name */
32 greg 2.3 static int lineno; /* current line number */
33     static int faceno; /* current face number */
34
35 greg 2.13 static int getstmt(char *av[MAXARG], FILE *fp);
36     static int cvtndx(VNDX vi, char *vs);
37     static int putface(int ac, char **av);
38 schorsch 2.8 static OBJECT getmod(void);
39 greg 2.13 static int puttri(char *v1, char *v2, char *v3);
40 schorsch 2.8 static void freeverts(void);
41 greg 2.13 static int newv(double x, double y, double z);
42     static int newvn(double x, double y, double z);
43     static int newvt(double x, double y);
44 schorsch 2.8 static void syntax(char *er);
45 greg 2.1
46
47 greg 2.3 void
48 schorsch 2.8 wfreadobj( /* read in .OBJ file and convert */
49     char *objfn
50     )
51 greg 2.1 {
52     FILE *fp;
53     char *argv[MAXARG];
54     int argc;
55     int nstats, nunknown;
56
57     if (objfn == NULL) {
58     inpfile = "<stdin>";
59     fp = stdin;
60     } else if ((fp = fopen(inpfile=objfn, "r")) == NULL) {
61     sprintf(errmsg, "cannot open \"%s\"", inpfile);
62     error(USER, errmsg);
63     }
64 greg 2.3 havemats = (nobjects > 0);
65 greg 2.1 nstats = nunknown = 0;
66 greg 2.3 material[0] = '\0';
67     group[0] = '\0';
68 greg 2.1 lineno = 0; faceno = 0;
69     /* scan until EOF */
70 schorsch 2.6 while ( (argc = getstmt(argv, fp)) ) {
71 greg 2.1 switch (argv[0][0]) {
72     case 'v': /* vertex */
73     switch (argv[0][1]) {
74     case '\0': /* point */
75     if (badarg(argc-1,argv+1,"fff"))
76 greg 2.2 syntax("bad vertex");
77 greg 2.1 newv(atof(argv[1]), atof(argv[2]),
78     atof(argv[3]));
79     break;
80     case 'n': /* normal */
81     if (argv[0][2])
82     goto unknown;
83     if (badarg(argc-1,argv+1,"fff"))
84 greg 2.2 syntax("bad normal");
85 greg 2.1 if (!newvn(atof(argv[1]), atof(argv[2]),
86     atof(argv[3])))
87 greg 2.2 syntax("zero normal");
88 greg 2.1 break;
89 greg 2.2 case 't': /* coordinate */
90 greg 2.1 if (argv[0][2])
91     goto unknown;
92     if (badarg(argc-1,argv+1,"ff"))
93     goto unknown;
94     newvt(atof(argv[1]), atof(argv[2]));
95     break;
96     default:
97     goto unknown;
98     }
99     break;
100     case 'f': /* face */
101     if (argv[0][1])
102     goto unknown;
103     faceno++;
104     switch (argc-1) {
105     case 0: case 1: case 2:
106 greg 2.2 syntax("too few vertices");
107 greg 2.1 break;
108     case 3:
109     if (!puttri(argv[1], argv[2], argv[3]))
110 greg 2.2 syntax("bad triangle");
111 greg 2.1 break;
112     default:
113     if (!putface(argc-1, argv+1))
114 greg 2.2 syntax("bad face");
115 greg 2.1 break;
116     }
117     break;
118 greg 2.3 case 'u': /* usemtl/usemap */
119     if (!strcmp(argv[0], "usemap"))
120     break;
121     if (strcmp(argv[0], "usemtl"))
122 greg 2.1 goto unknown;
123 greg 2.3 if (argc > 1)
124     strcpy(material, argv[1]);
125     else
126     material[0] = '\0';
127 greg 2.1 break;
128     case 'o': /* object name */
129     if (argv[0][1])
130     goto unknown;
131     break;
132 greg 2.3 case 'g': /* group name */
133 greg 2.1 if (argv[0][1])
134     goto unknown;
135 greg 2.3 if (argc > 1)
136     strcpy(group, argv[1]);
137     else
138     group[0] = '\0';
139 greg 2.1 break;
140     case '#': /* comment */
141     break;
142     default:; /* something we don't deal with */
143     unknown:
144     nunknown++;
145     break;
146     }
147     nstats++;
148     }
149     /* clean up */
150     freeverts();
151     fclose(fp);
152     if (nunknown > 0) {
153     sprintf(errmsg, "%d of %d statements unrecognized",
154     nunknown, nstats);
155     error(WARNING, errmsg);
156     }
157     }
158
159
160 greg 2.3 static int
161 schorsch 2.8 getstmt( /* read the next statement from fp */
162 greg 2.10 char *av[MAXARG],
163 schorsch 2.8 FILE *fp
164     )
165 greg 2.1 {
166 greg 2.3 static char sbuf[MAXARG*16];
167 greg 2.10 char *cp;
168     int i;
169 greg 2.1
170     do {
171     if (fgetline(cp=sbuf, sizeof(sbuf), fp) == NULL)
172     return(0);
173     i = 0;
174     for ( ; ; ) {
175     while (isspace(*cp) || *cp == '\\') {
176     if (*cp == '\n')
177     lineno++;
178     *cp++ = '\0';
179     }
180 greg 2.9 if (!*cp)
181 greg 2.1 break;
182 greg 2.9 if (i >= MAXARG-1) {
183     sprintf(errmsg,
184     "%s: too many arguments near line %d (limit %d)\n",
185     inpfile, lineno+1, MAXARG-1);
186     break;
187     }
188 greg 2.1 av[i++] = cp;
189     while (*++cp && !isspace(*cp))
190     ;
191     }
192     av[i] = NULL;
193     lineno++;
194     } while (!i);
195
196     return(i);
197     }
198
199
200 greg 2.3 static int
201 schorsch 2.8 cvtndx( /* convert vertex string to index */
202 greg 2.10 VNDX vi,
203     char *vs
204 schorsch 2.8 )
205 greg 2.1 {
206     /* get point */
207     vi[0] = atoi(vs);
208     if (vi[0] > 0) {
209     if (vi[0]-- > nvs)
210     return(0);
211     } else if (vi[0] < 0) {
212     vi[0] += nvs;
213     if (vi[0] < 0)
214     return(0);
215     } else
216     return(0);
217     /* get map coord. */
218     while (*vs)
219     if (*vs++ == '/')
220     break;
221     vi[1] = atoi(vs);
222     if (vi[1] > 0) {
223     if (vi[1]-- > nvts)
224     return(0);
225     } else if (vi[1] < 0) {
226     vi[1] += nvts;
227     if (vi[1] < 0)
228     return(0);
229     } else
230     vi[1] = -1;
231     /* get normal */
232     while (*vs)
233     if (*vs++ == '/')
234     break;
235     vi[2] = atoi(vs);
236     if (vi[2] > 0) {
237     if (vi[2]-- > nvns)
238     return(0);
239     } else if (vi[2] < 0) {
240     vi[2] += nvns;
241     if (vi[2] < 0)
242     return(0);
243     } else
244     vi[2] = -1;
245     return(1);
246     }
247
248 greg 2.11 /* determine dominant axis for triangle */
249     static int
250     dominant_axis(char *v1, char *v2, char *v3)
251     {
252 greg 2.12 VNDX v1i, v2i, v3i;
253 greg 2.11 FVECT e1, e2, vn;
254     int i, imax;
255
256 greg 2.12 if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3))
257     return(-1);
258     VSUB(e1, vlist[v2i[0]], vlist[v1i[0]]);
259     VSUB(e2, vlist[v3i[0]], vlist[v2i[0]]);
260 greg 2.11 VCROSS(vn, e1, e2);
261     for (i = imax = 2; i--; )
262     if (vn[i]*vn[i] > vn[imax]*vn[imax])
263     imax = i;
264 greg 2.14 return(vn[imax]*vn[imax] > FTINY*FTINY ? imax : -1);
265 greg 2.11 }
266
267     /* callback for triangle output from polygon */
268     static int
269     tri_out(const Vert2_list *tp, int a, int b, int c)
270     {
271     return( puttri( ((char **)tp->p)[a],
272     ((char **)tp->p)[b],
273     ((char **)tp->p)[c] ) );
274     }
275 greg 2.1
276 greg 2.3 static int
277 schorsch 2.8 putface( /* put out an N-sided polygon */
278     int ac,
279 greg 2.10 char **av
280 schorsch 2.8 )
281 greg 2.1 {
282 greg 2.11 Vert2_list *poly = polyAlloc(ac);
283     int i, ax, ay;
284 greg 2.1
285 greg 2.11 if (poly == NULL)
286     return(0);
287     poly->p = (void *)av;
288     for (i = ac-3; i >= 0; i--) /* identify dominant axis */
289     if ((ax = dominant_axis(av[i], av[i+1], av[i+2])) >= 0)
290     break;
291     if (ax < 0)
292 greg 2.12 return(1); /* ignore degenerate face */
293 greg 2.11 if (++ax >= 3) ax = 0;
294     ay = ax;
295     if (++ay >= 3) ay = 0;
296     for (i = 0; i < ac; i++) { /* convert to 2-D polygon */
297     VNDX vi;
298     if (!cvtndx(vi, av[i])) {
299     error(WARNING, "bad vertex reference");
300     polyFree(poly);
301 greg 2.1 return(0);
302 greg 2.11 }
303     poly->v[i].mX = vlist[vi[0]][ax];
304     poly->v[i].mY = vlist[vi[0]][ay];
305 greg 2.1 }
306 greg 2.11 /* break into triangles & output */
307 greg 2.13 if (!polyTriangulate(poly, &tri_out)) {
308     sprintf(errmsg, "self-intersecting face with %d vertices", ac);
309     error(WARNING, errmsg);
310     }
311 greg 2.11 polyFree(poly);
312     return(1);
313 greg 2.1 }
314
315
316 greg 2.3 static OBJECT
317 schorsch 2.8 getmod(void) /* get current modifier ID */
318 greg 2.3 {
319     char *mnam;
320     OBJECT mod;
321
322     if (!havemats)
323     return(OVOID);
324     if (!strcmp(material, VOIDID))
325     return(OVOID);
326     if (material[0]) /* prefer usemtl statements */
327     mnam = material;
328     else if (group[0]) /* else use group name */
329     mnam = group;
330     else
331     return(OVOID);
332     mod = modifier(mnam);
333     if (mod == OVOID) {
334     sprintf(errmsg, "%s: undefined modifier \"%s\"",
335     inpfile, mnam);
336     error(USER, errmsg);
337     }
338     return(mod);
339     }
340
341
342     static int
343 schorsch 2.8 puttri( /* convert a triangle */
344     char *v1,
345     char *v2,
346     char *v3
347     )
348 greg 2.1 {
349     VNDX v1i, v2i, v3i;
350 schorsch 2.5 RREAL *v1c, *v2c, *v3c;
351     RREAL *v1n, *v2n, *v3n;
352 greg 2.2
353 greg 2.7 if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) {
354     error(WARNING, "bad vertex reference");
355 greg 2.1 return(0);
356 greg 2.7 }
357 greg 2.1 if (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0) {
358     v1c = vtlist[v1i[1]];
359     v2c = vtlist[v2i[1]];
360     v3c = vtlist[v3i[1]];
361     } else
362     v1c = v2c = v3c = NULL;
363
364     if (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0) {
365     v1n = vnlist[v1i[2]];
366     v2n = vnlist[v2i[2]];
367     v3n = vnlist[v3i[2]];
368     } else
369     v1n = v2n = v3n = NULL;
370
371 greg 2.3 return(cvtri(getmod(), vlist[v1i[0]], vlist[v2i[0]], vlist[v3i[0]],
372 greg 2.1 v1n, v2n, v3n, v1c, v2c, v3c) >= 0);
373     }
374
375
376 greg 2.3 static void
377 schorsch 2.8 freeverts(void) /* free all vertices */
378 greg 2.1 {
379     if (nvs) {
380     free((void *)vlist);
381     nvs = 0;
382     }
383     if (nvts) {
384     free((void *)vtlist);
385     nvts = 0;
386     }
387     if (nvns) {
388     free((void *)vnlist);
389     nvns = 0;
390     }
391     }
392
393
394 greg 2.3 static int
395 schorsch 2.8 newv( /* create a new vertex */
396     double x,
397     double y,
398     double z
399     )
400 greg 2.1 {
401     if (!(nvs%CHUNKSIZ)) { /* allocate next block */
402     if (nvs == 0)
403     vlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT));
404     else
405 greg 2.4 vlist = (FVECT *)realloc((void *)vlist,
406 greg 2.1 (nvs+CHUNKSIZ)*sizeof(FVECT));
407 greg 2.2 if (vlist == NULL)
408     error(SYSTEM, "out of memory in newv");
409 greg 2.1 }
410     /* assign new vertex */
411     vlist[nvs][0] = x;
412     vlist[nvs][1] = y;
413     vlist[nvs][2] = z;
414     return(++nvs);
415     }
416
417
418 greg 2.3 static int
419 schorsch 2.8 newvn( /* create a new vertex normal */
420     double x,
421     double y,
422     double z
423     )
424 greg 2.1 {
425     if (!(nvns%CHUNKSIZ)) { /* allocate next block */
426     if (nvns == 0)
427     vnlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT));
428     else
429 greg 2.4 vnlist = (FVECT *)realloc((void *)vnlist,
430 greg 2.1 (nvns+CHUNKSIZ)*sizeof(FVECT));
431 greg 2.2 if (vnlist == NULL)
432     error(SYSTEM, "out of memory in newvn");
433 greg 2.1 }
434     /* assign new normal */
435     vnlist[nvns][0] = x;
436     vnlist[nvns][1] = y;
437     vnlist[nvns][2] = z;
438     if (normalize(vnlist[nvns]) == 0.0)
439     return(0);
440     return(++nvns);
441     }
442
443
444 greg 2.3 static int
445 schorsch 2.8 newvt( /* create a new texture map vertex */
446     double x,
447     double y
448     )
449 greg 2.1 {
450     if (!(nvts%CHUNKSIZ)) { /* allocate next block */
451     if (nvts == 0)
452 schorsch 2.5 vtlist = (RREAL (*)[2])malloc(CHUNKSIZ*2*sizeof(RREAL));
453 greg 2.1 else
454 schorsch 2.5 vtlist = (RREAL (*)[2])realloc((void *)vtlist,
455     (nvts+CHUNKSIZ)*2*sizeof(RREAL));
456 greg 2.2 if (vtlist == NULL)
457     error(SYSTEM, "out of memory in newvt");
458 greg 2.1 }
459     /* assign new vertex */
460     vtlist[nvts][0] = x;
461     vtlist[nvts][1] = y;
462     return(++nvts);
463     }
464
465
466 greg 2.3 static void
467 schorsch 2.8 syntax( /* report syntax error and exit */
468     char *er
469     )
470 greg 2.1 {
471 greg 2.2 sprintf(errmsg, "%s: Wavefront syntax error near line %d: %s\n",
472 greg 2.1 inpfile, lineno, er);
473 greg 2.2 error(USER, errmsg);
474 greg 2.1 }
