1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: wfconv.c,v 2.8 2004/03/27 12:41:45 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Load Wavefront .OBJ file and convert to triangles with mesh info. |
6 |
* Code borrowed largely from obj2rad.c |
7 |
8 |
9 |
#include "copyright.h" |
10 |
#include "standard.h" |
11 |
#include "cvmesh.h" |
12 |
#include <ctype.h> |
13 |
14 |
typedef int VNDX[3]; /* vertex index (point,map,normal) */ |
15 |
16 |
#define CHUNKSIZ 1024 /* vertex allocation chunk size */ |
17 |
18 |
#define MAXARG 512 /* maximum # arguments in a statement */ |
19 |
20 |
static FVECT *vlist; /* our vertex list */ |
21 |
static int nvs; /* number of vertices in our list */ |
22 |
static FVECT *vnlist; /* vertex normal list */ |
23 |
static int nvns; |
24 |
static RREAL (*vtlist)[2]; /* map vertex list */ |
25 |
static int nvts; |
26 |
27 |
static char *inpfile; /* input file name */ |
28 |
static int havemats; /* materials available? */ |
29 |
static char material[64]; /* current material name */ |
30 |
static char group[64]; /* current group name */ |
31 |
static int lineno; /* current line number */ |
32 |
static int faceno; /* current face number */ |
33 |
34 |
static int getstmt(char *av[MAXARG], FILE *fp); |
35 |
static int cvtndx(VNDX vi, char *vs); |
36 |
static int putface(int ac, char **av); |
37 |
static OBJECT getmod(void); |
38 |
static int puttri(char *v1, char *v2, char *v3); |
39 |
static void freeverts(void); |
40 |
static int newv(double x, double y, double z); |
41 |
static int newvn(double x, double y, double z); |
42 |
static int newvt(double x, double y); |
43 |
static void syntax(char *er); |
44 |
45 |
46 |
void |
47 |
wfreadobj( /* read in .OBJ file and convert */ |
48 |
char *objfn |
49 |
50 |
51 |
FILE *fp; |
52 |
char *argv[MAXARG]; |
53 |
int argc; |
54 |
int nstats, nunknown; |
55 |
56 |
if (objfn == NULL) { |
57 |
inpfile = "<stdin>"; |
58 |
fp = stdin; |
59 |
} else if ((fp = fopen(inpfile=objfn, "r")) == NULL) { |
60 |
sprintf(errmsg, "cannot open \"%s\"", inpfile); |
61 |
error(USER, errmsg); |
62 |
63 |
havemats = (nobjects > 0); |
64 |
nstats = nunknown = 0; |
65 |
material[0] = '\0'; |
66 |
group[0] = '\0'; |
67 |
lineno = 0; faceno = 0; |
68 |
/* scan until EOF */ |
69 |
while ( (argc = getstmt(argv, fp)) ) { |
70 |
switch (argv[0][0]) { |
71 |
case 'v': /* vertex */ |
72 |
switch (argv[0][1]) { |
73 |
case '\0': /* point */ |
74 |
if (badarg(argc-1,argv+1,"fff")) |
75 |
syntax("bad vertex"); |
76 |
newv(atof(argv[1]), atof(argv[2]), |
77 |
atof(argv[3])); |
78 |
break; |
79 |
case 'n': /* normal */ |
80 |
if (argv[0][2]) |
81 |
goto unknown; |
82 |
83 |
syntax("bad normal"); |
84 |
if (!newvn(atof(argv[1]), atof(argv[2]), |
85 |
atof(argv[3]))) |
86 |
syntax("zero normal"); |
87 |
break; |
88 |
case 't': /* coordinate */ |
89 |
if (argv[0][2]) |
90 |
goto unknown; |
91 |
if (badarg(argc-1,argv+1,"ff")) |
92 |
goto unknown; |
93 |
newvt(atof(argv[1]), atof(argv[2])); |
94 |
break; |
95 |
default: |
96 |
goto unknown; |
97 |
98 |
break; |
99 |
case 'f': /* face */ |
100 |
if (argv[0][1]) |
101 |
goto unknown; |
102 |
faceno++; |
103 |
switch (argc-1) { |
104 |
case 0: case 1: case 2: |
105 |
syntax("too few vertices"); |
106 |
break; |
107 |
case 3: |
108 |
if (!puttri(argv[1], argv[2], argv[3])) |
109 |
syntax("bad triangle"); |
110 |
break; |
111 |
default: |
112 |
if (!putface(argc-1, argv+1)) |
113 |
syntax("bad face"); |
114 |
break; |
115 |
116 |
break; |
117 |
case 'u': /* usemtl/usemap */ |
118 |
if (!strcmp(argv[0], "usemap")) |
119 |
break; |
120 |
if (strcmp(argv[0], "usemtl")) |
121 |
goto unknown; |
122 |
if (argc > 1) |
123 |
strcpy(material, argv[1]); |
124 |
else |
125 |
126 |
break; |
127 |
case 'o': /* object name */ |
128 |
if (argv[0][1]) |
129 |
goto unknown; |
130 |
break; |
131 |
case 'g': /* group name */ |
132 |
if (argv[0][1]) |
133 |
goto unknown; |
134 |
if (argc > 1) |
135 |
strcpy(group, argv[1]); |
136 |
else |
137 |
group[0] = '\0'; |
138 |
break; |
139 |
case '#': /* comment */ |
140 |
break; |
141 |
default:; /* something we don't deal with */ |
142 |
unknown: |
143 |
nunknown++; |
144 |
break; |
145 |
146 |
nstats++; |
147 |
148 |
/* clean up */ |
149 |
freeverts(); |
150 |
fclose(fp); |
151 |
if (nunknown > 0) { |
152 |
sprintf(errmsg, "%d of %d statements unrecognized", |
153 |
nunknown, nstats); |
154 |
error(WARNING, errmsg); |
155 |
156 |
157 |
158 |
159 |
static int |
160 |
getstmt( /* read the next statement from fp */ |
161 |
register char *av[MAXARG], |
162 |
FILE *fp |
163 |
164 |
165 |
static char sbuf[MAXARG*16]; |
166 |
register char *cp; |
167 |
register int i; |
168 |
169 |
do { |
170 |
if (fgetline(cp=sbuf, sizeof(sbuf), fp) == NULL) |
171 |
return(0); |
172 |
i = 0; |
173 |
for ( ; ; ) { |
174 |
while (isspace(*cp) || *cp == '\\') { |
175 |
if (*cp == '\n') |
176 |
lineno++; |
177 |
*cp++ = '\0'; |
178 |
179 |
if (!*cp) |
180 |
break; |
181 |
if (i >= MAXARG-1) { |
182 |
sprintf(errmsg, |
183 |
"%s: too many arguments near line %d (limit %d)\n", |
184 |
inpfile, lineno+1, MAXARG-1); |
185 |
break; |
186 |
187 |
av[i++] = cp; |
188 |
while (*++cp && !isspace(*cp)) |
189 |
190 |
191 |
av[i] = NULL; |
192 |
lineno++; |
193 |
} while (!i); |
194 |
195 |
return(i); |
196 |
197 |
198 |
199 |
static int |
200 |
cvtndx( /* convert vertex string to index */ |
201 |
register VNDX vi, |
202 |
register char *vs |
203 |
204 |
205 |
/* get point */ |
206 |
vi[0] = atoi(vs); |
207 |
if (vi[0] > 0) { |
208 |
if (vi[0]-- > nvs) |
209 |
return(0); |
210 |
} else if (vi[0] < 0) { |
211 |
vi[0] += nvs; |
212 |
if (vi[0] < 0) |
213 |
return(0); |
214 |
} else |
215 |
return(0); |
216 |
/* get map coord. */ |
217 |
while (*vs) |
218 |
if (*vs++ == '/') |
219 |
break; |
220 |
vi[1] = atoi(vs); |
221 |
if (vi[1] > 0) { |
222 |
if (vi[1]-- > nvts) |
223 |
return(0); |
224 |
} else if (vi[1] < 0) { |
225 |
vi[1] += nvts; |
226 |
if (vi[1] < 0) |
227 |
return(0); |
228 |
} else |
229 |
vi[1] = -1; |
230 |
/* get normal */ |
231 |
while (*vs) |
232 |
if (*vs++ == '/') |
233 |
break; |
234 |
vi[2] = atoi(vs); |
235 |
if (vi[2] > 0) { |
236 |
if (vi[2]-- > nvns) |
237 |
return(0); |
238 |
} else if (vi[2] < 0) { |
239 |
vi[2] += nvns; |
240 |
if (vi[2] < 0) |
241 |
return(0); |
242 |
} else |
243 |
vi[2] = -1; |
244 |
return(1); |
245 |
246 |
247 |
248 |
static int |
249 |
putface( /* put out an N-sided polygon */ |
250 |
int ac, |
251 |
register char **av |
252 |
253 |
254 |
char *cp; |
255 |
register int i; |
256 |
257 |
while (ac > 3) { /* break into triangles */ |
258 |
if (!puttri(av[0], av[1], av[2])) |
259 |
return(0); |
260 |
ac--; /* remove vertex & rotate */ |
261 |
cp = av[0]; |
262 |
for (i = 0; i < ac-1; i++) |
263 |
av[i] = av[i+2]; |
264 |
av[i] = cp; |
265 |
266 |
return(puttri(av[0], av[1], av[2])); |
267 |
268 |
269 |
270 |
static OBJECT |
271 |
getmod(void) /* get current modifier ID */ |
272 |
273 |
char *mnam; |
274 |
OBJECT mod; |
275 |
276 |
if (!havemats) |
277 |
return(OVOID); |
278 |
if (!strcmp(material, VOIDID)) |
279 |
return(OVOID); |
280 |
if (material[0]) /* prefer usemtl statements */ |
281 |
mnam = material; |
282 |
else if (group[0]) /* else use group name */ |
283 |
mnam = group; |
284 |
else |
285 |
return(OVOID); |
286 |
mod = modifier(mnam); |
287 |
if (mod == OVOID) { |
288 |
sprintf(errmsg, "%s: undefined modifier \"%s\"", |
289 |
inpfile, mnam); |
290 |
291 |
292 |
return(mod); |
293 |
294 |
295 |
296 |
static int |
297 |
puttri( /* convert a triangle */ |
298 |
char *v1, |
299 |
char *v2, |
300 |
char *v3 |
301 |
302 |
303 |
VNDX v1i, v2i, v3i; |
304 |
RREAL *v1c, *v2c, *v3c; |
305 |
RREAL *v1n, *v2n, *v3n; |
306 |
307 |
if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) { |
308 |
error(WARNING, "bad vertex reference"); |
309 |
return(0); |
310 |
311 |
if (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0) { |
312 |
v1c = vtlist[v1i[1]]; |
313 |
v2c = vtlist[v2i[1]]; |
314 |
v3c = vtlist[v3i[1]]; |
315 |
} else |
316 |
v1c = v2c = v3c = NULL; |
317 |
318 |
if (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0) { |
319 |
v1n = vnlist[v1i[2]]; |
320 |
v2n = vnlist[v2i[2]]; |
321 |
v3n = vnlist[v3i[2]]; |
322 |
} else |
323 |
v1n = v2n = v3n = NULL; |
324 |
325 |
return(cvtri(getmod(), vlist[v1i[0]], vlist[v2i[0]], vlist[v3i[0]], |
326 |
v1n, v2n, v3n, v1c, v2c, v3c) >= 0); |
327 |
328 |
329 |
330 |
static void |
331 |
freeverts(void) /* free all vertices */ |
332 |
333 |
if (nvs) { |
334 |
free((void *)vlist); |
335 |
nvs = 0; |
336 |
337 |
if (nvts) { |
338 |
free((void *)vtlist); |
339 |
nvts = 0; |
340 |
341 |
if (nvns) { |
342 |
free((void *)vnlist); |
343 |
nvns = 0; |
344 |
345 |
346 |
347 |
348 |
static int |
349 |
newv( /* create a new vertex */ |
350 |
double x, |
351 |
double y, |
352 |
double z |
353 |
354 |
355 |
if (!(nvs%CHUNKSIZ)) { /* allocate next block */ |
356 |
if (nvs == 0) |
357 |
vlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT)); |
358 |
else |
359 |
vlist = (FVECT *)realloc((void *)vlist, |
360 |
(nvs+CHUNKSIZ)*sizeof(FVECT)); |
361 |
if (vlist == NULL) |
362 |
error(SYSTEM, "out of memory in newv"); |
363 |
364 |
/* assign new vertex */ |
365 |
vlist[nvs][0] = x; |
366 |
vlist[nvs][1] = y; |
367 |
vlist[nvs][2] = z; |
368 |
return(++nvs); |
369 |
370 |
371 |
372 |
static int |
373 |
newvn( /* create a new vertex normal */ |
374 |
double x, |
375 |
double y, |
376 |
double z |
377 |
378 |
379 |
if (!(nvns%CHUNKSIZ)) { /* allocate next block */ |
380 |
if (nvns == 0) |
381 |
vnlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT)); |
382 |
else |
383 |
vnlist = (FVECT *)realloc((void *)vnlist, |
384 |
(nvns+CHUNKSIZ)*sizeof(FVECT)); |
385 |
if (vnlist == NULL) |
386 |
error(SYSTEM, "out of memory in newvn"); |
387 |
388 |
/* assign new normal */ |
389 |
vnlist[nvns][0] = x; |
390 |
vnlist[nvns][1] = y; |
391 |
vnlist[nvns][2] = z; |
392 |
if (normalize(vnlist[nvns]) == 0.0) |
393 |
return(0); |
394 |
return(++nvns); |
395 |
396 |
397 |
398 |
static int |
399 |
newvt( /* create a new texture map vertex */ |
400 |
double x, |
401 |
double y |
402 |
403 |
404 |
if (!(nvts%CHUNKSIZ)) { /* allocate next block */ |
405 |
if (nvts == 0) |
406 |
vtlist = (RREAL (*)[2])malloc(CHUNKSIZ*2*sizeof(RREAL)); |
407 |
else |
408 |
vtlist = (RREAL (*)[2])realloc((void *)vtlist, |
409 |
(nvts+CHUNKSIZ)*2*sizeof(RREAL)); |
410 |
if (vtlist == NULL) |
411 |
error(SYSTEM, "out of memory in newvt"); |
412 |
413 |
414 |
vtlist[nvts][0] = x; |
415 |
vtlist[nvts][1] = y; |
416 |
return(++nvts); |
417 |
418 |
419 |
420 |
static void |
421 |
syntax( /* report syntax error and exit */ |
422 |
char *er |
423 |
424 |
425 |
sprintf(errmsg, "%s: Wavefront syntax error near line %d: %s\n", |
426 |
inpfile, lineno, er); |
427 |
428 |
