1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: wfconv.c,v 2.12 2014/01/24 02:22:49 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Load Wavefront .OBJ file and convert to triangles with mesh info. |
6 |
* Code borrowed largely from obj2rad.c |
7 |
8 |
9 |
#include "copyright.h" |
10 |
#include "standard.h" |
11 |
#include "cvmesh.h" |
12 |
#include "triangulate.h" |
13 |
#include <ctype.h> |
14 |
15 |
typedef int VNDX[3]; /* vertex index (point,map,normal) */ |
16 |
17 |
#define CHUNKSIZ 1024 /* vertex allocation chunk size */ |
18 |
19 |
#define MAXARG 512 /* maximum # arguments in a statement */ |
20 |
21 |
static FVECT *vlist; /* our vertex list */ |
22 |
static int nvs; /* number of vertices in our list */ |
23 |
static FVECT *vnlist; /* vertex normal list */ |
24 |
static int nvns; |
25 |
static RREAL (*vtlist)[2]; /* map vertex list */ |
26 |
static int nvts; |
27 |
28 |
static char *inpfile; /* input file name */ |
29 |
static int havemats; /* materials available? */ |
30 |
static char material[256]; /* current material name */ |
31 |
static char group[256]; /* current group name */ |
32 |
static int lineno; /* current line number */ |
33 |
static int faceno; /* current face number */ |
34 |
35 |
static int getstmt(char *av[MAXARG], FILE *fp); |
36 |
static int cvtndx(VNDX vi, char *vs); |
37 |
static int putface(int ac, char **av); |
38 |
static OBJECT getmod(void); |
39 |
static int puttri(char *v1, char *v2, char *v3); |
40 |
static void freeverts(void); |
41 |
static int newv(double x, double y, double z); |
42 |
static int newvn(double x, double y, double z); |
43 |
static int newvt(double x, double y); |
44 |
static void syntax(char *er); |
45 |
46 |
47 |
void |
48 |
wfreadobj( /* read in .OBJ file and convert */ |
49 |
char *objfn |
50 |
51 |
52 |
FILE *fp; |
53 |
char *argv[MAXARG]; |
54 |
int argc; |
55 |
int nstats, nunknown; |
56 |
57 |
if (objfn == NULL) { |
58 |
inpfile = "<stdin>"; |
59 |
fp = stdin; |
60 |
} else if ((fp = fopen(inpfile=objfn, "r")) == NULL) { |
61 |
sprintf(errmsg, "cannot open \"%s\"", inpfile); |
62 |
error(USER, errmsg); |
63 |
64 |
havemats = (nobjects > 0); |
65 |
nstats = nunknown = 0; |
66 |
material[0] = '\0'; |
67 |
group[0] = '\0'; |
68 |
lineno = 0; faceno = 0; |
69 |
/* scan until EOF */ |
70 |
while ( (argc = getstmt(argv, fp)) ) { |
71 |
switch (argv[0][0]) { |
72 |
case 'v': /* vertex */ |
73 |
switch (argv[0][1]) { |
74 |
case '\0': /* point */ |
75 |
if (badarg(argc-1,argv+1,"fff")) |
76 |
syntax("bad vertex"); |
77 |
newv(atof(argv[1]), atof(argv[2]), |
78 |
atof(argv[3])); |
79 |
break; |
80 |
case 'n': /* normal */ |
81 |
if (argv[0][2]) |
82 |
goto unknown; |
83 |
84 |
syntax("bad normal"); |
85 |
if (!newvn(atof(argv[1]), atof(argv[2]), |
86 |
atof(argv[3]))) |
87 |
syntax("zero normal"); |
88 |
break; |
89 |
case 't': /* coordinate */ |
90 |
if (argv[0][2]) |
91 |
goto unknown; |
92 |
if (badarg(argc-1,argv+1,"ff")) |
93 |
goto unknown; |
94 |
newvt(atof(argv[1]), atof(argv[2])); |
95 |
break; |
96 |
default: |
97 |
goto unknown; |
98 |
99 |
break; |
100 |
case 'f': /* face */ |
101 |
if (argv[0][1]) |
102 |
goto unknown; |
103 |
faceno++; |
104 |
switch (argc-1) { |
105 |
case 0: case 1: case 2: |
106 |
syntax("too few vertices"); |
107 |
break; |
108 |
case 3: |
109 |
if (!puttri(argv[1], argv[2], argv[3])) |
110 |
syntax("bad triangle"); |
111 |
break; |
112 |
default: |
113 |
if (!putface(argc-1, argv+1)) |
114 |
syntax("bad face"); |
115 |
break; |
116 |
117 |
break; |
118 |
case 'u': /* usemtl/usemap */ |
119 |
if (!strcmp(argv[0], "usemap")) |
120 |
break; |
121 |
if (strcmp(argv[0], "usemtl")) |
122 |
goto unknown; |
123 |
if (argc > 1) |
124 |
strcpy(material, argv[1]); |
125 |
else |
126 |
127 |
break; |
128 |
case 'o': /* object name */ |
129 |
if (argv[0][1]) |
130 |
goto unknown; |
131 |
break; |
132 |
case 'g': /* group name */ |
133 |
if (argv[0][1]) |
134 |
goto unknown; |
135 |
if (argc > 1) |
136 |
strcpy(group, argv[1]); |
137 |
else |
138 |
group[0] = '\0'; |
139 |
break; |
140 |
case '#': /* comment */ |
141 |
break; |
142 |
default:; /* something we don't deal with */ |
143 |
unknown: |
144 |
nunknown++; |
145 |
break; |
146 |
147 |
nstats++; |
148 |
149 |
/* clean up */ |
150 |
freeverts(); |
151 |
fclose(fp); |
152 |
if (nunknown > 0) { |
153 |
sprintf(errmsg, "%d of %d statements unrecognized", |
154 |
nunknown, nstats); |
155 |
error(WARNING, errmsg); |
156 |
157 |
158 |
159 |
160 |
static int |
161 |
getstmt( /* read the next statement from fp */ |
162 |
char *av[MAXARG], |
163 |
FILE *fp |
164 |
165 |
166 |
static char sbuf[MAXARG*16]; |
167 |
char *cp; |
168 |
int i; |
169 |
170 |
do { |
171 |
if (fgetline(cp=sbuf, sizeof(sbuf), fp) == NULL) |
172 |
return(0); |
173 |
i = 0; |
174 |
for ( ; ; ) { |
175 |
while (isspace(*cp) || *cp == '\\') { |
176 |
if (*cp == '\n') |
177 |
lineno++; |
178 |
*cp++ = '\0'; |
179 |
180 |
if (!*cp) |
181 |
break; |
182 |
if (i >= MAXARG-1) { |
183 |
sprintf(errmsg, |
184 |
"%s: too many arguments near line %d (limit %d)\n", |
185 |
inpfile, lineno+1, MAXARG-1); |
186 |
break; |
187 |
188 |
av[i++] = cp; |
189 |
while (*++cp && !isspace(*cp)) |
190 |
191 |
192 |
av[i] = NULL; |
193 |
lineno++; |
194 |
} while (!i); |
195 |
196 |
return(i); |
197 |
198 |
199 |
200 |
static int |
201 |
cvtndx( /* convert vertex string to index */ |
202 |
VNDX vi, |
203 |
char *vs |
204 |
205 |
206 |
/* get point */ |
207 |
vi[0] = atoi(vs); |
208 |
if (vi[0] > 0) { |
209 |
if (vi[0]-- > nvs) |
210 |
return(0); |
211 |
} else if (vi[0] < 0) { |
212 |
vi[0] += nvs; |
213 |
if (vi[0] < 0) |
214 |
return(0); |
215 |
} else |
216 |
return(0); |
217 |
/* get map coord. */ |
218 |
while (*vs) |
219 |
if (*vs++ == '/') |
220 |
break; |
221 |
vi[1] = atoi(vs); |
222 |
if (vi[1] > 0) { |
223 |
if (vi[1]-- > nvts) |
224 |
return(0); |
225 |
} else if (vi[1] < 0) { |
226 |
vi[1] += nvts; |
227 |
if (vi[1] < 0) |
228 |
return(0); |
229 |
} else |
230 |
vi[1] = -1; |
231 |
/* get normal */ |
232 |
while (*vs) |
233 |
if (*vs++ == '/') |
234 |
break; |
235 |
vi[2] = atoi(vs); |
236 |
if (vi[2] > 0) { |
237 |
if (vi[2]-- > nvns) |
238 |
return(0); |
239 |
} else if (vi[2] < 0) { |
240 |
vi[2] += nvns; |
241 |
if (vi[2] < 0) |
242 |
return(0); |
243 |
} else |
244 |
vi[2] = -1; |
245 |
return(1); |
246 |
247 |
248 |
/* determine dominant axis for triangle */ |
249 |
static int |
250 |
dominant_axis(char *v1, char *v2, char *v3) |
251 |
252 |
VNDX v1i, v2i, v3i; |
253 |
FVECT e1, e2, vn; |
254 |
int i, imax; |
255 |
256 |
if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) |
257 |
return(-1); |
258 |
VSUB(e1, vlist[v2i[0]], vlist[v1i[0]]); |
259 |
VSUB(e2, vlist[v3i[0]], vlist[v2i[0]]); |
260 |
VCROSS(vn, e1, e2); |
261 |
for (i = imax = 2; i--; ) |
262 |
if (vn[i]*vn[i] > vn[imax]*vn[imax]) |
263 |
imax = i; |
264 |
return(vn[imax]*vn[imax] > FTINY ? imax : -1); |
265 |
266 |
267 |
/* callback for triangle output from polygon */ |
268 |
static int |
269 |
tri_out(const Vert2_list *tp, int a, int b, int c) |
270 |
271 |
return( puttri( ((char **)tp->p)[a], |
272 |
((char **)tp->p)[b], |
273 |
((char **)tp->p)[c] ) ); |
274 |
275 |
276 |
static int |
277 |
putface( /* put out an N-sided polygon */ |
278 |
int ac, |
279 |
char **av |
280 |
281 |
282 |
Vert2_list *poly = polyAlloc(ac); |
283 |
int i, ax, ay; |
284 |
285 |
if (poly == NULL) |
286 |
return(0); |
287 |
poly->p = (void *)av; |
288 |
for (i = ac-3; i >= 0; i--) /* identify dominant axis */ |
289 |
if ((ax = dominant_axis(av[i], av[i+1], av[i+2])) >= 0) |
290 |
break; |
291 |
if (ax < 0) |
292 |
return(1); /* ignore degenerate face */ |
293 |
if (++ax >= 3) ax = 0; |
294 |
ay = ax; |
295 |
if (++ay >= 3) ay = 0; |
296 |
for (i = 0; i < ac; i++) { /* convert to 2-D polygon */ |
297 |
VNDX vi; |
298 |
if (!cvtndx(vi, av[i])) { |
299 |
error(WARNING, "bad vertex reference"); |
300 |
polyFree(poly); |
301 |
return(0); |
302 |
303 |
poly->v[i].mX = vlist[vi[0]][ax]; |
304 |
poly->v[i].mY = vlist[vi[0]][ay]; |
305 |
306 |
/* break into triangles & output */ |
307 |
if (!polyTriangulate(poly, &tri_out)) { |
308 |
sprintf(errmsg, "self-intersecting face with %d vertices", ac); |
309 |
310 |
311 |
polyFree(poly); |
312 |
return(1); |
313 |
314 |
315 |
316 |
static OBJECT |
317 |
getmod(void) /* get current modifier ID */ |
318 |
319 |
char *mnam; |
320 |
OBJECT mod; |
321 |
322 |
if (!havemats) |
323 |
return(OVOID); |
324 |
if (!strcmp(material, VOIDID)) |
325 |
return(OVOID); |
326 |
if (material[0]) /* prefer usemtl statements */ |
327 |
mnam = material; |
328 |
else if (group[0]) /* else use group name */ |
329 |
mnam = group; |
330 |
else |
331 |
return(OVOID); |
332 |
mod = modifier(mnam); |
333 |
if (mod == OVOID) { |
334 |
sprintf(errmsg, "%s: undefined modifier \"%s\"", |
335 |
inpfile, mnam); |
336 |
337 |
338 |
return(mod); |
339 |
340 |
341 |
342 |
static int |
343 |
puttri( /* convert a triangle */ |
344 |
char *v1, |
345 |
char *v2, |
346 |
char *v3 |
347 |
348 |
349 |
350 |
RREAL *v1c, *v2c, *v3c; |
351 |
RREAL *v1n, *v2n, *v3n; |
352 |
353 |
if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) { |
354 |
355 |
return(0); |
356 |
357 |
if (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0) { |
358 |
v1c = vtlist[v1i[1]]; |
359 |
v2c = vtlist[v2i[1]]; |
360 |
v3c = vtlist[v3i[1]]; |
361 |
} else |
362 |
v1c = v2c = v3c = NULL; |
363 |
364 |
if (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0) { |
365 |
v1n = vnlist[v1i[2]]; |
366 |
v2n = vnlist[v2i[2]]; |
367 |
v3n = vnlist[v3i[2]]; |
368 |
} else |
369 |
v1n = v2n = v3n = NULL; |
370 |
371 |
return(cvtri(getmod(), vlist[v1i[0]], vlist[v2i[0]], vlist[v3i[0]], |
372 |
v1n, v2n, v3n, v1c, v2c, v3c) >= 0); |
373 |
374 |
375 |
376 |
static void |
377 |
freeverts(void) /* free all vertices */ |
378 |
379 |
if (nvs) { |
380 |
free((void *)vlist); |
381 |
nvs = 0; |
382 |
383 |
if (nvts) { |
384 |
free((void *)vtlist); |
385 |
nvts = 0; |
386 |
387 |
if (nvns) { |
388 |
free((void *)vnlist); |
389 |
nvns = 0; |
390 |
391 |
392 |
393 |
394 |
static int |
395 |
newv( /* create a new vertex */ |
396 |
double x, |
397 |
double y, |
398 |
double z |
399 |
400 |
401 |
if (!(nvs%CHUNKSIZ)) { /* allocate next block */ |
402 |
if (nvs == 0) |
403 |
vlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT)); |
404 |
else |
405 |
vlist = (FVECT *)realloc((void *)vlist, |
406 |
(nvs+CHUNKSIZ)*sizeof(FVECT)); |
407 |
if (vlist == NULL) |
408 |
error(SYSTEM, "out of memory in newv"); |
409 |
410 |
/* assign new vertex */ |
411 |
vlist[nvs][0] = x; |
412 |
vlist[nvs][1] = y; |
413 |
vlist[nvs][2] = z; |
414 |
return(++nvs); |
415 |
416 |
417 |
418 |
static int |
419 |
newvn( /* create a new vertex normal */ |
420 |
double x, |
421 |
double y, |
422 |
double z |
423 |
424 |
425 |
if (!(nvns%CHUNKSIZ)) { /* allocate next block */ |
426 |
if (nvns == 0) |
427 |
vnlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT)); |
428 |
else |
429 |
vnlist = (FVECT *)realloc((void *)vnlist, |
430 |
(nvns+CHUNKSIZ)*sizeof(FVECT)); |
431 |
if (vnlist == NULL) |
432 |
error(SYSTEM, "out of memory in newvn"); |
433 |
434 |
/* assign new normal */ |
435 |
vnlist[nvns][0] = x; |
436 |
vnlist[nvns][1] = y; |
437 |
vnlist[nvns][2] = z; |
438 |
if (normalize(vnlist[nvns]) == 0.0) |
439 |
return(0); |
440 |
return(++nvns); |
441 |
442 |
443 |
444 |
static int |
445 |
newvt( /* create a new texture map vertex */ |
446 |
double x, |
447 |
double y |
448 |
449 |
450 |
if (!(nvts%CHUNKSIZ)) { /* allocate next block */ |
451 |
if (nvts == 0) |
452 |
vtlist = (RREAL (*)[2])malloc(CHUNKSIZ*2*sizeof(RREAL)); |
453 |
else |
454 |
vtlist = (RREAL (*)[2])realloc((void *)vtlist, |
455 |
(nvts+CHUNKSIZ)*2*sizeof(RREAL)); |
456 |
if (vtlist == NULL) |
457 |
error(SYSTEM, "out of memory in newvt"); |
458 |
459 |
460 |
vtlist[nvts][0] = x; |
461 |
vtlist[nvts][1] = y; |
462 |
return(++nvts); |
463 |
464 |
465 |
466 |
static void |
467 |
syntax( /* report syntax error and exit */ |
468 |
char *er |
469 |
470 |
471 |
sprintf(errmsg, "%s: Wavefront syntax error near line %d: %s\n", |
472 |
inpfile, lineno, er); |
473 |
474 |
