--- ray/src/ot/wfconv.c 2014/01/24 02:22:49 2.12 +++ ray/src/ot/wfconv.c 2014/06/10 23:19:00 2.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: wfconv.c,v 2.12 2014/01/24 02:22:49 greg Exp $"; +static const char RCSid[] = "$Id: wfconv.c,v 2.13 2014/06/10 23:19:00 greg Exp $"; #endif /* * Load Wavefront .OBJ file and convert to triangles with mesh info. @@ -32,15 +32,15 @@ static char group[256]; /* current group name */ static int lineno; /* current line number */ static int faceno; /* current face number */ -static int getstmt(char *av[MAXARG], FILE *fp); -static int cvtndx(VNDX vi, char *vs); -static int putface(int ac, char **av); +static int getstmt(char *av[MAXARG], FILE *fp); +static int cvtndx(VNDX vi, char *vs); +static int putface(int ac, char **av); static OBJECT getmod(void); -static int puttri(char *v1, char *v2, char *v3); +static int puttri(char *v1, char *v2, char *v3); static void freeverts(void); -static int newv(double x, double y, double z); -static int newvn(double x, double y, double z); -static int newvt(double x, double y); +static int newv(double x, double y, double z); +static int newvn(double x, double y, double z); +static int newvt(double x, double y); static void syntax(char *er); @@ -304,8 +304,10 @@ putface( /* put out an N-sided polygon */ poly->v[i].mY = vlist[vi[0]][ay]; } /* break into triangles & output */ - if (!polyTriangulate(poly, &tri_out)) - error(WARNING, "self-intersecting face"); + if (!polyTriangulate(poly, &tri_out)) { + sprintf(errmsg, "self-intersecting face with %d vertices", ac); + error(WARNING, errmsg); + } polyFree(poly); return(1); }
