--- ray/src/ot/wfconv.c 2014/01/24 01:26:44 2.11 +++ ray/src/ot/wfconv.c 2014/01/24 02:22:49 2.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: wfconv.c,v 2.11 2014/01/24 01:26:44 greg Exp $"; +static const char RCSid[] = "$Id: wfconv.c,v 2.12 2014/01/24 02:22:49 greg Exp $"; #endif /* * Load Wavefront .OBJ file and convert to triangles with mesh info. @@ -249,12 +249,14 @@ cvtndx( /* convert vertex string to index */ static int dominant_axis(char *v1, char *v2, char *v3) { - int v1i = atoi(v1), v2i = atoi(v2), v3i = atoi(v3); + VNDX v1i, v2i, v3i; FVECT e1, e2, vn; int i, imax; - VSUB(e1, vlist[v2i], vlist[v1i]); - VSUB(e2, vlist[v3i], vlist[v2i]); + if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) + return(-1); + VSUB(e1, vlist[v2i[0]], vlist[v1i[0]]); + VSUB(e2, vlist[v3i[0]], vlist[v2i[0]]); VCROSS(vn, e1, e2); for (i = imax = 2; i--; ) if (vn[i]*vn[i] > vn[imax]*vn[imax]) @@ -287,7 +289,7 @@ putface( /* put out an N-sided polygon */ if ((ax = dominant_axis(av[i], av[i+1], av[i+2])) >= 0) break; if (ax < 0) - return(0); + return(1); /* ignore degenerate face */ if (++ax >= 3) ax = 0; ay = ax; if (++ay >= 3) ay = 0; @@ -303,7 +305,7 @@ putface( /* put out an N-sided polygon */ } /* break into triangles & output */ if (!polyTriangulate(poly, &tri_out)) - return(0); + error(WARNING, "self-intersecting face"); polyFree(poly); return(1); }
