root/Development/ray/src/ot/wfconv.c
Fri Apr 30 16:40:10 2021 UTC (4 years, 6 months ago) by greg
Changes since 2.17: +18 -5 lines
Diff to previous 2.17 , to selected 2.3
fix(obj2mesh): fixed normal reversal during some face triangulation
Thu Mar 11 17:00:58 2021 UTC (4 years, 8 months ago) by greg
Changes since 2.16: +6 -5 lines
Diff to previous 2.16 , to selected 2.3
fix: plugged memory leak for degenerate faces
Sun Jun 14 04:18:09 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 2.15 , to selected 2.3
Fixed issue with removing faces that aren't really that small
Fri May 3 18:00:50 2019 UTC (6 years, 6 months ago) by greg
Diff to previous 2.14 , to selected 2.3
Eliminated stray newline in syntax()
Wed Jun 11 00:08:30 2014 UTC (11 years, 5 months ago) by greg
Diff to previous 2.13 , to selected 2.3
Fixed bug in small polygon triangulation
Tue Jun 10 23:19:00 2014 UTC (11 years, 5 months ago) by greg
Changes since 2.12: +12 -10 lines
Diff to previous 2.12 , to selected 2.3
Added message about number of vertices in self-intersecting faces
Fri Jan 24 02:22:49 2014 UTC (11 years, 10 months ago) by greg
Changes since 2.11: +8 -6 lines
Diff to previous 2.11 , to selected 2.3
Fixed bug in triangulation code
Fri Jan 24 01:26:44 2014 UTC (11 years, 10 months ago) by greg
Changes since 2.10: +53 -11 lines
Diff to previous 2.10 , to selected 2.3
Fri Nov 8 16:49:04 2013 UTC (12 years ago) by greg
Changes since 2.9: +10 -10 lines
Diff to previous 2.9 , to selected 2.3
Increased maximum identifier name length from 64 to 256
Fri Apr 23 16:20:56 2004 UTC (21 years, 7 months ago) by greg
Changes since 2.8: +9 -3 lines
Sat Mar 27 12:41:45 2004 UTC (21 years, 8 months ago) by schorsch
Changes since 2.7: +50 -35 lines
Thu Jan 29 22:21:34 2004 UTC (21 years, 9 months ago) by greg
Changes since 2.6: +4 -3 lines
Sun Jul 27 22:12:03 2003 UTC (22 years, 4 months ago) by schorsch
Thu Jun 26 00:58:10 2003 UTC (22 years, 5 months ago) by schorsch
Wed Apr 23 00:52:34 2003 UTC (22 years, 7 months ago) by greg
Fri Mar 14 21:27:46 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.2: +78 -20 lines
Wed Mar 12 04:59:04 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.1: +16 -30 lines
Tue Mar 11 17:08:55 2003 UTC (22 years, 8 months ago) by greg
Diff to selected 2.3
