root/radiance/ray/src/ot/wfconv.c
Revision 2.16 - (view) (download) (annotate) - [selected]
Sun Jun 14 04:18:09 2020 UTC (3 years, 11 months ago) by greg
Diff to previous 2.15
Fixed issue with removing faces that aren't really that small
Fri May 3 18:00:50 2019 UTC (5 years ago) by greg
Diff to previous 2.14 , to selected 2.16
Eliminated stray newline in syntax()
Wed Jun 11 00:08:30 2014 UTC (9 years, 11 months ago) by greg
Diff to previous 2.13 , to selected 2.16
Fixed bug in small polygon triangulation
Tue Jun 10 23:19:00 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.12: +12 -10 lines
Diff to previous 2.12 , to selected 2.16
Added message about number of vertices in self-intersecting faces
Fri Jan 24 02:22:49 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.11: +8 -6 lines
Diff to previous 2.11 , to selected 2.16
Fixed bug in triangulation code
Fri Jan 24 01:26:44 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.10: +53 -11 lines
Diff to previous 2.10 , to selected 2.16
Fri Nov 8 16:49:04 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.9: +10 -10 lines
Diff to previous 2.9 , to selected 2.16
Increased maximum identifier name length from 64 to 256
Fri Apr 23 16:20:56 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.8: +9 -3 lines
Diff to previous 2.8 , to selected 2.16
Sat Mar 27 12:41:45 2004 UTC (20 years, 1 month ago) by schorsch
Changes since 2.7: +50 -35 lines
Diff to previous 2.7 , to selected 2.16
Thu Jan 29 22:21:34 2004 UTC (20 years, 3 months ago) by greg
Changes since 2.6: +4 -3 lines
Diff to previous 2.6 , to selected 2.16
Diff to previous 2.5 , to selected 2.16
Diff to previous 2.4 , to selected 2.16
Wed Apr 23 00:52:34 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.16
Fri Mar 14 21:27:46 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.2: +78 -20 lines
Diff to previous 2.2 , to selected 2.16
Wed Mar 12 04:59:04 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.1: +16 -30 lines
Diff to previous 2.1 , to selected 2.16
Diff to selected 2.16
