Fixed bug in small polygon triangulation
Added message about number of vertices in self-intersecting faces
Fixed bug in triangulation code
Increased maximum identifier name length from 64 to 256
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
