--- ray/src/ot/wfconv.c 2003/03/14 21:27:46 2.3 +++ ray/src/ot/wfconv.c 2003/07/27 22:12:03 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: wfconv.c,v 2.3 2003/03/14 21:27:46 greg Exp $"; +static const char RCSid[] = "$Id: wfconv.c,v 2.6 2003/07/27 22:12:03 schorsch Exp $"; #endif /* * Load Wavefront .OBJ file and convert to triangles with mesh info. @@ -21,7 +21,7 @@ static FVECT *vlist; /* our vertex list */ static int nvs; /* number of vertices in our list */ static FVECT *vnlist; /* vertex normal list */ static int nvns; -static FLOAT (*vtlist)[2]; /* map vertex list */ +static RREAL (*vtlist)[2]; /* map vertex list */ static int nvts; static char *inpfile; /* input file name */ @@ -66,7 +66,7 @@ char *objfn; group[0] = '\0'; lineno = 0; faceno = 0; /* scan until EOF */ - while (argc = getstmt(argv, fp)) { + while ( (argc = getstmt(argv, fp)) ) { switch (argv[0][0]) { case 'v': /* vertex */ switch (argv[0][1]) { @@ -289,8 +289,8 @@ puttri(v1, v2, v3) /* convert a triangle */ char *v1, *v2, *v3; { VNDX v1i, v2i, v3i; - FLOAT *v1c, *v2c, *v3c; - FLOAT *v1n, *v2n, *v3n; + RREAL *v1c, *v2c, *v3c; + RREAL *v1n, *v2n, *v3n; if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) return(0); @@ -340,7 +340,7 @@ double x, y, z; if (nvs == 0) vlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT)); else - vlist = (FVECT *)realloc((char *)vlist, + vlist = (FVECT *)realloc((void *)vlist, (nvs+CHUNKSIZ)*sizeof(FVECT)); if (vlist == NULL) error(SYSTEM, "out of memory in newv"); @@ -361,7 +361,7 @@ double x, y, z; if (nvns == 0) vnlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT)); else - vnlist = (FVECT *)realloc((char *)vnlist, + vnlist = (FVECT *)realloc((void *)vnlist, (nvns+CHUNKSIZ)*sizeof(FVECT)); if (vnlist == NULL) error(SYSTEM, "out of memory in newvn"); @@ -382,10 +382,10 @@ double x, y; { if (!(nvts%CHUNKSIZ)) { /* allocate next block */ if (nvts == 0) - vtlist = (FLOAT (*)[2])malloc(CHUNKSIZ*2*sizeof(FLOAT)); + vtlist = (RREAL (*)[2])malloc(CHUNKSIZ*2*sizeof(RREAL)); else - vtlist = (FLOAT (*)[2])realloc((char *)vtlist, - (nvts+CHUNKSIZ)*2*sizeof(FLOAT)); + vtlist = (RREAL (*)[2])realloc((void *)vtlist, + (nvts+CHUNKSIZ)*2*sizeof(RREAL)); if (vtlist == NULL) error(SYSTEM, "out of memory in newvt"); }
