--- ray/src/ot/wfconv.c 2003/04/23 00:52:34 2.4 +++ ray/src/ot/wfconv.c 2021/04/30 16:40:10 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: wfconv.c,v 2.4 2003/04/23 00:52:34 greg Exp $"; +static const char RCSid[] = "$Id: wfconv.c,v 2.18 2021/04/30 16:40:10 greg Exp $"; #endif /* * Load Wavefront .OBJ file and convert to triangles with mesh info. @@ -9,49 +9,50 @@ static const char RCSid[] = "$Id: wfconv.c,v 2.4 2003/ #include "copyright.h" #include "standard.h" #include "cvmesh.h" +#include "triangulate.h" #include typedef int VNDX[3]; /* vertex index (point,map,normal) */ #define CHUNKSIZ 1024 /* vertex allocation chunk size */ -#define MAXARG 64 /* maximum # arguments in a statement */ +#define MAXARG 512 /* maximum # arguments in a statement */ static FVECT *vlist; /* our vertex list */ static int nvs; /* number of vertices in our list */ static FVECT *vnlist; /* vertex normal list */ static int nvns; -static FLOAT (*vtlist)[2]; /* map vertex list */ +static RREAL (*vtlist)[2]; /* map vertex list */ static int nvts; static char *inpfile; /* input file name */ static int havemats; /* materials available? */ -static char material[64]; /* current material name */ -static char group[64]; /* current group name */ +static char material[256]; /* current material name */ +static char group[256]; /* current group name */ static int lineno; /* current line number */ static int faceno; /* current face number */ -static int getstmt(); -static int cvtndx(); -static OBJECT getmod(); -static int putface(); -static int puttri(); -static void freeverts(); -static int newv(); -static int newvn(); -static int newvt(); -static void syntax(); +static int getstmt(char *av[MAXARG], FILE *fp); +static int cvtndx(VNDX vi, char *vs); +static int putface(int ac, char **av); +static OBJECT getmod(void); +static int puttri(char *v1, char *v2, char *v3); +static void freeverts(void); +static int newv(double x, double y, double z); +static int newvn(double x, double y, double z); +static int newvt(double x, double y); +static void syntax(char *er); void -wfreadobj(objfn) /* read in .OBJ file and convert */ -char *objfn; +wfreadobj( /* read in .OBJ file and convert */ + char *objfn +) { FILE *fp; char *argv[MAXARG]; int argc; int nstats, nunknown; - int i; if (objfn == NULL) { inpfile = ""; @@ -66,7 +67,7 @@ char *objfn; group[0] = '\0'; lineno = 0; faceno = 0; /* scan until EOF */ - while (argc = getstmt(argv, fp)) { + while ( (argc = getstmt(argv, fp)) ) { switch (argv[0][0]) { case 'v': /* vertex */ switch (argv[0][1]) { @@ -157,13 +158,14 @@ char *objfn; static int -getstmt(av, fp) /* read the next statement from fp */ -register char *av[MAXARG]; -FILE *fp; +getstmt( /* read the next statement from fp */ + char *av[MAXARG], + FILE *fp +) { static char sbuf[MAXARG*16]; - register char *cp; - register int i; + char *cp; + int i; do { if (fgetline(cp=sbuf, sizeof(sbuf), fp) == NULL) @@ -175,8 +177,14 @@ FILE *fp; lineno++; *cp++ = '\0'; } - if (!*cp || i >= MAXARG-1) + if (!*cp) break; + if (i >= MAXARG-1) { + sprintf(errmsg, + "%s: too many arguments near line %d (limit %d)\n", + inpfile, lineno+1, MAXARG-1); + break; + } av[i++] = cp; while (*++cp && !isspace(*cp)) ; @@ -190,9 +198,10 @@ FILE *fp; static int -cvtndx(vi, vs) /* convert vertex string to index */ -register VNDX vi; -register char *vs; +cvtndx( /* convert vertex string to index */ + VNDX vi, + char *vs +) { /* get point */ vi[0] = atoi(vs); @@ -236,30 +245,90 @@ register char *vs; return(1); } +/* determine dominant axis for triangle */ +static int +dominant_axis(char *v1, char *v2, char *v3) +{ + VNDX v1i, v2i, v3i; + FVECT e1, e2, vn; + int i, imax; + if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) + return(-1); + VSUB(e1, vlist[v2i[0]], vlist[v1i[0]]); + VSUB(e2, vlist[v3i[0]], vlist[v2i[0]]); + VCROSS(vn, e1, e2); + for (i = imax = 2; i--; ) + if (vn[i]*vn[i] > vn[imax]*vn[imax]) + imax = i; + return(vn[imax]*vn[imax] > FTINY*FTINY*FTINY*FTINY ? imax : -1); +} + +/* struct needed for triangulation callback */ +typedef struct { + char **avl; + int rev; +} WFpoly; + +/* callback for triangle output from polygon */ static int -putface(ac, av) /* put out an N-sided polygon */ -int ac; -register char **av; +tri_out(const Vert2_list *tp, int a, int b, int c) { - char *cp; - register int i; + WFpoly * wp = (WFpoly *)tp->p; - while (ac > 3) { /* break into triangles */ - if (!puttri(av[0], av[1], av[2])) + if (wp->rev) + return( puttri(wp->avl[c], wp->avl[b], wp->avl[a]) ); + + return( puttri(wp->avl[a], wp->avl[b], wp->avl[c]) ); +} + +static int +putface( /* put out an N-sided polygon */ + int ac, + char **av +) +{ + Vert2_list *poly; + WFpoly myps; + int i, ax, ay; + + for (i = ac-3; i >= 0; i--) /* identify dominant axis */ + if ((ax = dominant_axis(av[i], av[i+1], av[i+2])) >= 0) + break; + if (ax < 0) + return(1); /* ignore degenerate face */ + poly = polyAlloc(ac); + if (poly == NULL) + return(0); + myps.avl = av; + poly->p = &myps; + if (++ax >= 3) ax = 0; + ay = ax; + if (++ay >= 3) ay = 0; + for (i = 0; i < ac; i++) { /* convert to 2-D polygon */ + VNDX vi; + if (!cvtndx(vi, av[i])) { + error(WARNING, "bad vertex reference"); + polyFree(poly); return(0); - ac--; /* remove vertex & rotate */ - cp = av[0]; - for (i = 0; i < ac-1; i++) - av[i] = av[i+2]; - av[i] = cp; + } + poly->v[i].mX = vlist[vi[0]][ax]; + poly->v[i].mY = vlist[vi[0]][ay]; } - return(puttri(av[0], av[1], av[2])); + /* flag for order reversal */ + myps.rev = (polyArea(poly) < .0); + /* break into triangles & output */ + if (!polyTriangulate(poly, &tri_out)) { + sprintf(errmsg, "self-intersecting face with %d vertices", ac); + error(WARNING, errmsg); + } + polyFree(poly); + return(1); } static OBJECT -getmod() /* get current modifier ID */ +getmod(void) /* get current modifier ID */ { char *mnam; OBJECT mod; @@ -285,16 +354,20 @@ getmod() /* get current modifier ID */ static int -puttri(v1, v2, v3) /* convert a triangle */ -char *v1, *v2, *v3; +puttri( /* convert a triangle */ + char *v1, + char *v2, + char *v3 +) { VNDX v1i, v2i, v3i; - FLOAT *v1c, *v2c, *v3c; - FLOAT *v1n, *v2n, *v3n; + RREAL *v1c, *v2c, *v3c; + RREAL *v1n, *v2n, *v3n; - if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) + if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) { + error(WARNING, "bad vertex reference"); return(0); - + } if (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0) { v1c = vtlist[v1i[1]]; v2c = vtlist[v2i[1]]; @@ -315,7 +388,7 @@ char *v1, *v2, *v3; static void -freeverts() /* free all vertices */ +freeverts(void) /* free all vertices */ { if (nvs) { free((void *)vlist); @@ -333,8 +406,11 @@ freeverts() /* free all vertices */ static int -newv(x, y, z) /* create a new vertex */ -double x, y, z; +newv( /* create a new vertex */ + double x, + double y, + double z +) { if (!(nvs%CHUNKSIZ)) { /* allocate next block */ if (nvs == 0) @@ -354,8 +430,11 @@ double x, y, z; static int -newvn(x, y, z) /* create a new vertex normal */ -double x, y, z; +newvn( /* create a new vertex normal */ + double x, + double y, + double z +) { if (!(nvns%CHUNKSIZ)) { /* allocate next block */ if (nvns == 0) @@ -377,15 +456,17 @@ double x, y, z; static int -newvt(x, y) /* create a new texture map vertex */ -double x, y; +newvt( /* create a new texture map vertex */ + double x, + double y +) { if (!(nvts%CHUNKSIZ)) { /* allocate next block */ if (nvts == 0) - vtlist = (FLOAT (*)[2])malloc(CHUNKSIZ*2*sizeof(FLOAT)); + vtlist = (RREAL (*)[2])malloc(CHUNKSIZ*2*sizeof(RREAL)); else - vtlist = (FLOAT (*)[2])realloc((void *)vtlist, - (nvts+CHUNKSIZ)*2*sizeof(FLOAT)); + vtlist = (RREAL (*)[2])realloc((void *)vtlist, + (nvts+CHUNKSIZ)*2*sizeof(RREAL)); if (vtlist == NULL) error(SYSTEM, "out of memory in newvt"); } @@ -397,10 +478,11 @@ double x, y; static void -syntax(er) /* report syntax error and exit */ -char *er; +syntax( /* report syntax error and exit */ + char *er +) { - sprintf(errmsg, "%s: Wavefront syntax error near line %d: %s\n", + sprintf(errmsg, "%s: Wavefront syntax error near line %d: %s", inpfile, lineno, er); error(USER, errmsg); }
