--- ray/src/ot/wfconv.c 2021/03/11 17:00:58 2.17 +++ ray/src/ot/wfconv.c 2021/04/30 16:40:10 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: wfconv.c,v 2.17 2021/03/11 17:00:58 greg Exp $"; +static const char RCSid[] = "$Id: wfconv.c,v 2.18 2021/04/30 16:40:10 greg Exp $"; #endif /* * Load Wavefront .OBJ file and convert to triangles with mesh info. @@ -264,13 +264,22 @@ dominant_axis(char *v1, char *v2, char *v3) return(vn[imax]*vn[imax] > FTINY*FTINY*FTINY*FTINY ? imax : -1); } +/* struct needed for triangulation callback */ +typedef struct { + char **avl; + int rev; +} WFpoly; + /* callback for triangle output from polygon */ static int tri_out(const Vert2_list *tp, int a, int b, int c) { - return( puttri( ((char **)tp->p)[a], - ((char **)tp->p)[b], - ((char **)tp->p)[c] ) ); + WFpoly * wp = (WFpoly *)tp->p; + + if (wp->rev) + return( puttri(wp->avl[c], wp->avl[b], wp->avl[a]) ); + + return( puttri(wp->avl[a], wp->avl[b], wp->avl[c]) ); } static int @@ -280,6 +289,7 @@ putface( /* put out an N-sided polygon */ ) { Vert2_list *poly; + WFpoly myps; int i, ax, ay; for (i = ac-3; i >= 0; i--) /* identify dominant axis */ @@ -290,7 +300,8 @@ putface( /* put out an N-sided polygon */ poly = polyAlloc(ac); if (poly == NULL) return(0); - poly->p = (void *)av; + myps.avl = av; + poly->p = &myps; if (++ax >= 3) ax = 0; ay = ax; if (++ay >= 3) ay = 0; @@ -304,6 +315,8 @@ putface( /* put out an N-sided polygon */ poly->v[i].mX = vlist[vi[0]][ax]; poly->v[i].mY = vlist[vi[0]][ay]; } + /* flag for order reversal */ + myps.rev = (polyArea(poly) < .0); /* break into triangles & output */ if (!polyTriangulate(poly, &tri_out)) { sprintf(errmsg, "self-intersecting face with %d vertices", ac);
