root/radiance/ray/src/ot/sphere.c
Tue Mar 30 16:13:00 2004 UTC (21 years, 2 months ago) by schorsch
Sat Mar 27 12:41:45 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.3: +7 -4 lines
Thu Jun 26 00:58:10 2003 UTC (21 years, 11 months ago) by schorsch
Sat Feb 22 02:07:26 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.1: +1 -4 lines
Tue Nov 12 17:00:46 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 2.3
Wed Oct 23 13:43:34 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.3 , to selected 2.3
Wed May 22 17:01:43 1991 UTC (34 years ago) by greg
Changes since 1.2: +9 -2 lines
Diff to previous 1.2 , to selected 2.3
change sphere with negative radii into bubbles
Sat Oct 14 11:19:36 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.1: +5 -5 lines
Diff to previous 1.1 , to selected 2.3
Thu Feb 2 10:33:06 1989 UTC (36 years, 4 months ago) by greg
Diff to selected 2.3
