root/radiance/ray/src/ot/sphere.c
Revision: 2.2
Committed: Sat Feb 22 02:07:26 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.1: +1 -4 lines
5 * sphere.c - routines for creating octrees for spheres.
6 *
7 * 7/28/85
8 */
9
10 #include "standard.h"
11
12 #include "octree.h"
13
14 #include "object.h"
15
16 #include "otypes.h"
17
18 #define ROOT3 1.732050808
19
20 /*
21 * Regrettably, the algorithm for determining a cube's location
22 * with respect to a sphere is not simple. First, a quick test is
23 * made to determine if the sphere and the bounding sphere of the cube
24 * are disjoint. This of course means no intersection. Failing this,
25 * we determine if the cube lies inside the sphere. The cube is
26 * entirely inside if the bounding sphere on the cube is
27 * contained within our sphere. This means no intersection. Otherwise,
28 * if the cube radius is smaller than the sphere's and the cube center is
29 * inside the sphere, we assume intersection. If these tests fail,
30 * we proceed as follows.
31 * The sphere center is located in relation to the 6 cube faces,
32 * and one of four things is done depending on the number of
33 * planes the center lies between:
34 *
35 * 0: The sphere is closest to a cube corner, find the
36 * distance to that corner.
37 *
38 * 1: The sphere is closest to a cube edge, find this
39 * distance.
40 *
41 * 2: The sphere is closest to a cube face, find the distance.
42 *
43 * 3: The sphere has its center inside the cube.
44 *
45 * In cases 0-2, if the closest part of the cube is within
46 * the radius distance from the sphere center, we have intersection.
47 * If it is not, the cube must be outside the sphere.
48 * In case 3, there must be intersection, and no further
49 * tests are necessary.
50 */
51
52
53 o_sphere(o, cu) /* determine if sphere intersects cube */
54 OBJREC *o;
55 register CUBE *cu;
56 {
57 FVECT v1;
58 double d1, d2;
59 register FLOAT *fa;
60 register int i;
61 #define cent fa
62 #define rad fa[3]
63 /* get arguments */
64 if (o->oargs.nfargs != 4)
65 objerror(o, USER, "bad # arguments");
66 fa = o->oargs.farg;
67 if (rad < -FTINY) {
68 objerror(o, WARNING, "negative radius");
69 o->otype = o->otype == OBJ_SPHERE ?
70 OBJ_BUBBLE : OBJ_SPHERE;
71 rad = -rad;
72 } else if (rad <= FTINY)
73 objerror(o, USER, "zero radius");
74
75 d1 = ROOT3/2.0 * cu->cusize; /* bounding radius for cube */
76
77 d2 = cu->cusize * 0.5; /* get distance between centers */
78 for (i = 0; i < 3; i++)
79 v1[i] = cu->cuorg[i] + d2 - cent[i];
80 d2 = DOT(v1,v1);
81
82 if (d2 > (rad+d1+FTINY)*(rad+d1+FTINY)) /* quick test */
83 return(O_MISS); /* cube outside */
84
85 /* check sphere interior */
86 if (d1 < rad) {
87 if (d2 < (rad-d1-FTINY)*(rad-d1-FTINY))
88 return(O_MISS); /* cube inside sphere */
89 if (d2 < (rad+FTINY)*(rad+FTINY))
90 return(O_HIT); /* cube center inside */
91 }
92 /* find closest distance */
93 for (i = 0; i < 3; i++)
94 if (cent[i] < cu->cuorg[i])
95 v1[i] = cu->cuorg[i] - cent[i];
96 else if (cent[i] > cu->cuorg[i] + cu->cusize)
97 v1[i] = cent[i] - (cu->cuorg[i] + cu->cusize);
98 else
99 v1[i] = 0;
100 /* final intersection check */
101 if (DOT(v1,v1) <= (rad+FTINY)*(rad+FTINY))
102 return(O_HIT);
103 else
104 return(O_MISS);
105 }
