1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* sphere.c - routines for creating octrees for spheres. |
9 |
10 |
* 7/28/85 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "octree.h" |
16 |
17 |
#include "object.h" |
18 |
19 |
#include "otypes.h" |
20 |
21 |
#define ROOT3 1.732050808 |
22 |
23 |
24 |
* Regrettably, the algorithm for determining a cube's location |
25 |
* with respect to a sphere is not simple. First, a quick test is |
26 |
* made to determine if the sphere and the bounding sphere of the cube |
27 |
* are disjoint. This of course means no intersection. Failing this, |
28 |
* we determine if the cube lies inside the sphere. The cube is |
29 |
* entirely inside if the bounding sphere on the cube is |
30 |
* contained within our sphere. This means no intersection. Otherwise, |
31 |
* if the cube radius is smaller than the sphere's and the cube center is |
32 |
* inside the sphere, we assume intersection. If these tests fail, |
33 |
* we proceed as follows. |
34 |
* The sphere center is located in relation to the 6 cube faces, |
35 |
* and one of four things is done depending on the number of |
36 |
* planes the center lies between: |
37 |
38 |
* 0: The sphere is closest to a cube corner, find the |
39 |
* distance to that corner. |
40 |
41 |
* 1: The sphere is closest to a cube edge, find this |
42 |
* distance. |
43 |
44 |
* 2: The sphere is closest to a cube face, find the distance. |
45 |
46 |
* 3: The sphere has its center inside the cube. |
47 |
48 |
* In cases 0-2, if the closest part of the cube is within |
49 |
* the radius distance from the sphere center, we have intersection. |
50 |
* If it is not, the cube must be outside the sphere. |
51 |
* In case 3, there must be intersection, and no further |
52 |
* tests are necessary. |
53 |
54 |
55 |
56 |
o_sphere(o, cu) /* determine if sphere intersects cube */ |
57 |
OBJREC *o; |
58 |
register CUBE *cu; |
59 |
60 |
FVECT v1; |
61 |
double d1, d2; |
62 |
register double *fa; |
63 |
register int i; |
64 |
#define cent fa |
65 |
#define rad fa[3] |
66 |
/* get arguments */ |
67 |
if (o->oargs.nfargs != 4) |
68 |
objerror(o, USER, "bad # arguments"); |
69 |
fa = o->oargs.farg; |
70 |
if (rad < -FTINY) { |
71 |
objerror(o, WARNING, "negative radius"); |
72 |
o->otype = o->otype == OBJ_SPHERE ? |
73 |
OBJ_BUBBLE : OBJ_SPHERE; |
74 |
rad = -rad; |
75 |
} else if (rad <= FTINY) |
76 |
objerror(o, USER, "zero radius"); |
77 |
78 |
d1 = ROOT3/2.0 * cu->cusize; /* bounding radius for cube */ |
79 |
80 |
d2 = cu->cusize * 0.5; /* get distance between centers */ |
81 |
for (i = 0; i < 3; i++) |
82 |
v1[i] = cu->cuorg[i] + d2 - cent[i]; |
83 |
d2 = DOT(v1,v1); |
84 |
85 |
if (d2 > (rad+d1+FTINY)*(rad+d1+FTINY)) /* quick test */ |
86 |
return(O_MISS); /* cube outside */ |
87 |
88 |
/* check sphere interior */ |
89 |
if (d1 < rad) { |
90 |
if (d2 < (rad-d1-FTINY)*(rad-d1-FTINY)) |
91 |
return(O_MISS); /* cube inside sphere */ |
92 |
if (d2 < (rad+FTINY)*(rad+FTINY)) |
93 |
return(O_HIT); /* cube center inside */ |
94 |
95 |
/* find closest distance */ |
96 |
97 |
if (cent[i] < cu->cuorg[i]) |
98 |
v1[i] = cu->cuorg[i] - cent[i]; |
99 |
else if (cent[i] > cu->cuorg[i] + cu->cusize) |
100 |
v1[i] = cent[i] - (cu->cuorg[i] + cu->cusize); |
101 |
else |
102 |
v1[i] = 0; |
103 |
/* final intersection check */ |
104 |
if (DOT(v1,v1) <= (rad+FTINY)*(rad+FTINY)) |
105 |
return(O_HIT); |
106 |
else |
107 |
return(O_MISS); |
108 |
