root/radiance/ray/src/ot/sphere.c
Wed Apr 20 18:51:35 2016 UTC (9 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 2.5: +8 -6 lines
Diff to previous 2.5 , to selected 1.4
Changed zero-radius sphere from error to warning
Tue Mar 30 16:13:00 2004 UTC (21 years, 4 months ago) by schorsch
Diff to previous 2.4 , to selected 1.4
Sat Mar 27 12:41:45 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.3: +7 -4 lines
Diff to previous 2.3 , to selected 1.4
Thu Jun 26 00:58:10 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.2 , to selected 1.4
Sat Feb 22 02:07:26 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.1: +1 -4 lines
Diff to previous 2.1 , to selected 1.4
Tue Nov 12 17:00:46 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.4
Revision 1.4 - (view) (download) (annotate) - [selected]
Wed Oct 23 13:43:34 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.3
Wed May 22 17:01:43 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.2: +9 -2 lines
Diff to previous 1.2 , to selected 1.4
change sphere with negative radii into bubbles
Sat Oct 14 11:19:36 1989 UTC (35 years, 9 months ago) by greg
Changes since 1.1: +5 -5 lines
Diff to previous 1.1 , to selected 1.4
Thu Feb 2 10:33:06 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 1.4
