root/Development/ray/src/ot/readobj2.c
Tue Apr 22 14:51:29 2025 UTC (5 months ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.13 , to selected 1.4
fix: Changed some errors to warnings for pclose()
Tue Apr 22 04:45:25 2025 UTC (5 months ago) by greg
Changes since 2.12: +7 -4 lines
Diff to previous 2.12 , to selected 1.4
fix: Added check to return value of pclose() in several tools
Wed Jul 29 18:11:23 2020 UTC (5 years, 1 month ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.11: +1 -2 lines
Diff to previous 2.11 , to selected 1.4
style: removed redundant declaration of fgetline()
Tue Feb 2 18:02:32 2016 UTC (9 years, 7 months ago) by greg
CVS Tags: rad5R1, rad5R2
Diff to previous 2.10 , to selected 1.4
Tue Sep 28 23:55:02 2004 UTC (20 years, 11 months ago) by greg
Diff to previous 2.9 , to selected 1.4
Increased read buffer size from 512 to 2048
Sat Mar 27 12:41:45 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.8: +12 -8 lines
Diff to previous 2.8 , to selected 1.4
Mon Oct 27 10:29:29 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.7: +13 -8 lines
Diff to previous 2.7 , to selected 1.4
Various compatibility fixes.
Wed Oct 22 02:06:34 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 1.4
Thu Jun 26 00:58:10 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 2.5 , to selected 1.4
Tue Mar 11 19:29:05 2003 UTC (22 years, 6 months ago) by greg
Changes since 2.4: +2 -4 lines
Diff to previous 2.4 , to selected 1.4
Sat Feb 22 02:07:26 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.3: +6 -29 lines
Diff to previous 2.3 , to selected 1.4
Fri Jun 4 17:02:19 1993 UTC (32 years, 3 months ago) by greg
Diff to previous 2.2 , to selected 1.4
Fri Jan 29 09:01:28 1993 UTC (32 years, 8 months ago) by greg
Diff to previous 2.1 , to selected 1.4
removed lastrno reference
Tue Nov 12 17:01:03 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.5 , to selected 1.4
Mon Jul 22 12:01:42 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.4: +5 -3 lines
Diff to previous 1.4
replaced fscanf() calls with fgetword()
Revision 1.4 - (view) (download) (annotate) - [selected]
Fri Jul 19 09:29:24 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.3: +1 -78 lines
Diff to previous 1.3
Wed Jul 17 13:56:02 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.2: +5 -1 lines
Diff to previous 1.2 , to selected 1.4
eliminated call to savestr()
Wed May 29 17:44:18 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.1 , to selected 1.4
bug fix in recursive call
Wed May 29 17:33:18 1991 UTC (34 years, 4 months ago) by greg
Diff to selected 1.4
