root/Development/ray/src/ot/readobj2.c
Tue Sep 28 23:55:02 2004 UTC (21 years, 1 month ago) by greg
Increased read buffer size from 512 to 2048
Sat Mar 27 12:41:45 2004 UTC (21 years, 8 months ago) by schorsch
Changes since 2.8: +12 -8 lines
Mon Oct 27 10:29:29 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.7: +13 -8 lines
Various compatibility fixes.
Wed Oct 22 02:06:34 2003 UTC (22 years, 1 month ago) by greg
Thu Jun 26 00:58:10 2003 UTC (22 years, 5 months ago) by schorsch
Tue Mar 11 19:29:05 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.4: +2 -4 lines
Sat Feb 22 02:07:26 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.3: +6 -29 lines
Fri Jun 4 17:02:19 1993 UTC (32 years, 5 months ago) by greg
Fri Jan 29 09:01:28 1993 UTC (32 years, 10 months ago) by greg
Diff to previous 2.1
removed lastrno reference
Tue Nov 12 17:01:03 1991 UTC (34 years ago) by greg
Diff to previous 1.5 , to selected 2.2
Mon Jul 22 12:01:42 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +5 -3 lines
replaced fscanf() calls with fgetword()
Fri Jul 19 09:29:24 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.3: +1 -78 lines
Wed Jul 17 13:56:02 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.2: +5 -1 lines
eliminated call to savestr()
Wed May 29 17:44:18 1991 UTC (34 years, 6 months ago) by greg
bug fix in recursive call
Wed May 29 17:33:18 1991 UTC (34 years, 6 months ago) by greg
Diff to selected 2.2
