Increased maximum number of scene files from 127 to 255
Fixed some conflicting definitions
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
increased maximum number of files from 63 to 127
minor changes
fixed duplicate header ID for -i option
made it so reading from stdin avoids "frozen octree" warning
Changes for 32-bit PC port
Changes for PC port
fixed bug in array size for volflg and inflg
added define for DEFPATH
added format to output header
the final solution (hopefully) to volumes
improved conversion speed for instances
inline will be reserved word
Improved performance for overlapping instances
added notifier capability to insertobject()
Defined return values for intersection functions. Changed order of call to addobject to rotate O_IN objects.
changed option processing switch slightly
Added ability to read scene from stdin
Centered cube on bounding box
extended margin around bounding cube
