root/radiance/ray/src/ot/oconv.c
Revision: 2.9
Committed: Thu Apr 14 05:02:06 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.8: +0 -5 lines
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * oconv.c - main program for object to octree conversion.
9 *
10 * 7/29/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 #include "paths.h"
22
23 #define OMARGIN (10*FTINY) /* margin around global cube */
24
25 #define MAXOBJFIL 63 /* maximum number of scene files */
26
27 char *progname; /* argv[0] */
28
29 int nowarn = 0; /* supress warnings? */
30
31 int objlim = 5; /* # of objects before split */
32
33 int resolu = 1024; /* octree resolution limit */
34
35 CUBE thescene = {EMPTY, {0.0, 0.0, 0.0}, 0.0}; /* our scene */
36
37 char *ofname[MAXOBJFIL+1]; /* object file names */
38 int nfiles = 0; /* number of object files */
39
40 double mincusize; /* minimum cube size from resolu */
41
42 int (*addobjnotify[])() = {NULL}; /* new object notifier functions */
43
44
45 main(argc, argv) /* convert object files to an octree */
46 int argc;
47 char **argv;
48 {
49 extern char *getenv();
50 FVECT bbmin, bbmax;
51 char *infile = NULL;
52 int inpfrozen = 0;
53 int outflags = IO_ALL;
54 OBJECT startobj;
55 int i;
56
57 progname = argv[0] = fixargv0(argv[0]);
58
59 initotypes();
60
61 for (i = 1; i < argc && argv[i][0] == '-'; i++)
62 switch (argv[i][1]) {
63 case '\0': /* scene from stdin */
64 outflags &= ~IO_FILES;
65 goto breakopt;
66 case 'i': /* input octree */
67 infile = argv[++i];
68 break;
69 case 'b': /* bounding cube */
70 thescene.cuorg[0] = atof(argv[++i]) - OMARGIN;
71 thescene.cuorg[1] = atof(argv[++i]) - OMARGIN;
72 thescene.cuorg[2] = atof(argv[++i]) - OMARGIN;
73 thescene.cusize = atof(argv[++i]) + 2*OMARGIN;
74 break;
75 case 'n': /* set limit */
76 objlim = atoi(argv[++i]);
77 break;
78 case 'r': /* resolution limit */
79 resolu = atoi(argv[++i]);
80 break;
81 case 'f': /* freeze octree */
82 outflags &= ~IO_FILES;
83 break;
84 case 'w': /* supress warnings */
85 nowarn = 1;
86 break;
87 default:
88 sprintf(errmsg, "unknown option: '%s'", argv[i]);
89 error(USER, errmsg);
90 break;
91 }
92 breakopt:
93 #ifdef MSDOS
94 setmode(fileno(stdout), O_BINARY);
95 #endif
96 if (infile != NULL) { /* get old octree & objects */
97 if (thescene.cusize > FTINY)
98 error(USER, "only one of '-b' or '-i'");
99 nfiles = readoct(infile, IO_ALL, &thescene, ofname);
100 if (nfiles == 0)
101 inpfrozen++;
102 } else
103 newheader("RADIANCE", stdout); /* new binary file header */
104 printargs(argc, argv, stdout);
105 fputformat(OCTFMT, stdout);
106 printf("\n");
107
108 startobj = nobjects; /* previous objects already converted */
109
110 for ( ; i < argc; i++) /* read new scene descriptions */
111 if (!strcmp(argv[i], "-")) { /* from stdin */
112 readobj(NULL);
113 outflags &= ~IO_FILES;
114 } else { /* from file */
115 if (nfiles >= MAXOBJFIL)
116 error(INTERNAL, "too many scene files");
117 readobj(ofname[nfiles++] = argv[i]);
118 }
119
120 ofname[nfiles] = NULL;
121
122 if (inpfrozen && outflags & IO_FILES) {
123 error(WARNING, "frozen octree");
124 outflags &= ~IO_FILES;
125 }
126 /* find bounding box */
127 bbmin[0] = bbmin[1] = bbmin[2] = FHUGE;
128 bbmax[0] = bbmax[1] = bbmax[2] = -FHUGE;
129 for (i = startobj; i < nobjects; i++)
130 add2bbox(objptr(i), bbmin, bbmax);
131 /* set/check cube */
132 if (thescene.cusize == 0.0) {
133 if (bbmin[0] <= bbmax[0]) {
134 for (i = 0; i < 3; i++) {
135 bbmin[i] -= OMARGIN;
136 bbmax[i] += OMARGIN;
137 }
138 for (i = 0; i < 3; i++)
139 if (bbmax[i] - bbmin[i] > thescene.cusize)
140 thescene.cusize = bbmax[i] - bbmin[i];
141 for (i = 0; i < 3; i++)
142 thescene.cuorg[i] =
143 (bbmax[i]+bbmin[i]-thescene.cusize)*.5;
144 }
145 } else {
146 for (i = 0; i < 3; i++)
147 if (bbmin[i] < thescene.cuorg[i] ||
148 bbmax[i] > thescene.cuorg[i] + thescene.cusize)
149 error(USER, "boundary does not encompass scene");
150 }
151
152 mincusize = thescene.cusize / resolu - FTINY;
153
154 for (i = startobj; i < nobjects; i++) /* add new objects */
155 addobject(&thescene, i);
156
157 thescene.cutree = combine(thescene.cutree); /* optimize */
158
159 writeoct(outflags, &thescene, ofname); /* write structures to stdout */
160
161 quit(0);
162 }
163
164
165 quit(code) /* exit program */
166 int code;
167 {
168 exit(code);
169 }
170
171
172 cputs() /* interactive error */
173 {
174 /* referenced, but not used */
175 }
176
177
178 wputs(s) /* warning message */
179 char *s;
180 {
181 if (!nowarn)
182 eputs(s);
183 }
184
185
186 eputs(s) /* put string to stderr */
187 register char *s;
188 {
189 static int inln = 0;
190
191 if (!inln++) {
192 fputs(progname, stderr);
193 fputs(": ", stderr);
194 }
195 fputs(s, stderr);
196 if (*s && s[strlen(s)-1] == '\n')
197 inln = 0;
198 }
199
200
201 #define bitop(f,i,op) (f[((i)>>3)] op (1<<((i)&7)))
202 #define tstbit(f,i) bitop(f,i,&)
203 #define setbit(f,i) bitop(f,i,|=)
204 #define clrbit(f,i) bitop(f,i,&=~)
205 #define tglbit(f,i) bitop(f,i,^=)
206
207
208 addobject(cu, obj) /* add an object to a cube */
209 register CUBE *cu;
210 OBJECT obj;
211 {
212 CUBE cukid;
213 OCTREE ot;
214 OBJECT oset[MAXSET+1];
215 unsigned char inflg[(MAXSET+7)/8], volflg[(MAXSET+7)/8];
216 int in;
217 register int i, j;
218
219 in = (*ofun[objptr(obj)->otype].funp)(objptr(obj), cu);
220
221 if (in == O_MISS)
222 return; /* no intersection */
223
224 if (istree(cu->cutree)) {
225 /* do children */
226 cukid.cusize = cu->cusize * 0.5;
227 for (i = 0; i < 8; i++) {
228 cukid.cutree = octkid(cu->cutree, i);
229 for (j = 0; j < 3; j++) {
230 cukid.cuorg[j] = cu->cuorg[j];
231 if ((1<<j) & i)
232 cukid.cuorg[j] += cukid.cusize;
233 }
234 addobject(&cukid, obj);
235 octkid(cu->cutree, i) = cukid.cutree;
236 }
237 return;
238 }
239 if (isempty(cu->cutree)) {
240 /* singular set */
241 oset[0] = 1; oset[1] = obj;
242 cu->cutree = fullnode(oset);
243 return;
244 }
245 /* add to full node */
246 objset(oset, cu->cutree);
247 cukid.cusize = cu->cusize * 0.5;
248
249 if (in==O_IN || oset[0] < objlim || cukid.cusize < mincusize) {
250 /* add to set */
251 if (oset[0] >= MAXSET) {
252 sprintf(errmsg, "set overflow in addobject (%s)",
253 objptr(obj)->oname);
254 error(INTERNAL, errmsg);
255 }
256 insertelem(oset, obj);
257 cu->cutree = fullnode(oset);
258 return;
259 }
260 /* subdivide cube */
261 if ((ot = octalloc()) == EMPTY)
262 error(SYSTEM, "out of octree space");
263 /* mark volumes */
264 j = (oset[0]+7)>>3;
265 while (j--)
266 volflg[j] = inflg[j] = 0;
267 for (j = 1; j <= oset[0]; j++)
268 if (isvolume(objptr(oset[j])->otype)) {
269 setbit(volflg,j-1);
270 if ((*ofun[objptr(oset[j])->otype].funp)
271 (objptr(oset[j]), cu) == O_IN)
272 setbit(inflg,j-1);
273 }
274 /* assign subcubes */
275 for (i = 0; i < 8; i++) {
276 cukid.cutree = EMPTY;
277 for (j = 0; j < 3; j++) {
278 cukid.cuorg[j] = cu->cuorg[j];
279 if ((1<<j) & i)
280 cukid.cuorg[j] += cukid.cusize;
281 }
282 /* surfaces first */
283 for (j = 1; j <= oset[0]; j++)
284 if (!tstbit(volflg,j-1))
285 addobject(&cukid, oset[j]);
286 /* then this object */
287 addobject(&cukid, obj);
288 /* then partial volumes */
289 for (j = 1; j <= oset[0]; j++)
290 if (tstbit(volflg,j-1) &&
291 !tstbit(inflg,j-1))
292 addobject(&cukid, oset[j]);
293 /* full volumes last */
294 for (j = 1; j <= oset[0]; j++)
295 if (tstbit(inflg,j-1))
296 addobject(&cukid, oset[j]);
297 /* returned node */
298 octkid(ot, i) = cukid.cutree;
299 }
300 cu->cutree = ot;
301 }
