| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* oconv.c - main program for object to octree conversion.
| 9 |
| 10 |
* 7/29/85
| 11 |
| 12 |
| 13 |
#include "standard.h"
| 14 |
| 15 |
#include "octree.h"
| 16 |
| 17 |
#include "object.h"
| 18 |
| 19 |
#include "otypes.h"
| 20 |
| 21 |
#include "paths.h"
| 22 |
| 23 |
#define OMARGIN (10*FTINY) /* margin around global cube */
| 24 |
| 25 |
#define MAXOBJFIL 63 /* maximum number of scene files */
| 26 |
| 27 |
char *progname; /* argv[0] */
| 28 |
| 29 |
char *libpath; /* library search path */
| 30 |
| 31 |
int nowarn = 0; /* supress warnings? */
| 32 |
| 33 |
int objlim = 5; /* # of objects before split */
| 34 |
| 35 |
int resolu = 1024; /* octree resolution limit */
| 36 |
| 37 |
CUBE thescene = {EMPTY, {0.0, 0.0, 0.0}, 0.0}; /* our scene */
| 38 |
| 39 |
char *ofname[MAXOBJFIL+1]; /* object file names */
| 40 |
int nfiles = 0; /* number of object files */
| 41 |
| 42 |
double mincusize; /* minimum cube size from resolu */
| 43 |
| 44 |
int (*addobjnotify[])() = {NULL}; /* new object notifier functions */
| 45 |
| 46 |
| 47 |
main(argc, argv) /* convert object files to an octree */
| 48 |
int argc;
| 49 |
char **argv;
| 50 |
| 51 |
extern char *getenv();
| 52 |
FVECT bbmin, bbmax;
| 53 |
char *infile = NULL;
| 54 |
int inpfrozen = 0;
| 55 |
int outflags = IO_ALL;
| 56 |
OBJECT startobj;
| 57 |
int i;
| 58 |
| 59 |
progname = argv[0] = fixargv0(argv[0]);
| 60 |
| 61 |
if ((libpath = getenv(ULIBVAR)) == NULL)
| 62 |
libpath = DEFPATH;
| 63 |
| 64 |
initotypes();
| 65 |
| 66 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 67 |
switch (argv[i][1]) {
| 68 |
case '\0': /* scene from stdin */
| 69 |
outflags &= ~IO_FILES;
| 70 |
goto breakopt;
| 71 |
case 'i': /* input octree */
| 72 |
infile = argv[++i];
| 73 |
break;
| 74 |
case 'b': /* bounding cube */
| 75 |
thescene.cuorg[0] = atof(argv[++i]) - OMARGIN;
| 76 |
thescene.cuorg[1] = atof(argv[++i]) - OMARGIN;
| 77 |
thescene.cuorg[2] = atof(argv[++i]) - OMARGIN;
| 78 |
thescene.cusize = atof(argv[++i]) + 2*OMARGIN;
| 79 |
break;
| 80 |
case 'n': /* set limit */
| 81 |
objlim = atoi(argv[++i]);
| 82 |
break;
| 83 |
case 'r': /* resolution limit */
| 84 |
resolu = atoi(argv[++i]);
| 85 |
break;
| 86 |
case 'f': /* freeze octree */
| 87 |
| 88 |
break;
| 89 |
case 'w': /* supress warnings */
| 90 |
nowarn = 1;
| 91 |
break;
| 92 |
default:
| 93 |
sprintf(errmsg, "unknown option: '%s'", argv[i]);
| 94 |
error(USER, errmsg);
| 95 |
break;
| 96 |
| 97 |
breakopt:
| 98 |
#ifdef MSDOS
| 99 |
setmode(fileno(stdout), O_BINARY);
| 100 |
#endif
| 101 |
if (infile != NULL) { /* get old octree & objects */
| 102 |
if (thescene.cusize > FTINY)
| 103 |
error(USER, "only one of '-b' or '-i'");
| 104 |
nfiles = readoct(infile, IO_ALL, &thescene, ofname);
| 105 |
if (nfiles == 0)
| 106 |
inpfrozen++;
| 107 |
| 108 |
| 109 |
newheader("RADIANCE", stdout); /* new binary file header */
| 110 |
printargs(argc, argv, stdout);
| 111 |
fputformat(OCTFMT, stdout);
| 112 |
printf("\n");
| 113 |
| 114 |
startobj = nobjects; /* previous objects already converted */
| 115 |
| 116 |
for ( ; i < argc; i++) /* read new scene descriptions */
| 117 |
if (!strcmp(argv[i], "-")) { /* from stdin */
| 118 |
readobj(NULL);
| 119 |
| 120 |
} else { /* from file */
| 121 |
if (nfiles >= MAXOBJFIL)
| 122 |
error(INTERNAL, "too many scene files");
| 123 |
readobj(ofname[nfiles++] = argv[i]);
| 124 |
| 125 |
| 126 |
ofname[nfiles] = NULL;
| 127 |
| 128 |
if (inpfrozen && outflags & IO_FILES) {
| 129 |
error(WARNING, "frozen octree");
| 130 |
| 131 |
| 132 |
/* find bounding box */
| 133 |
bbmin[0] = bbmin[1] = bbmin[2] = FHUGE;
| 134 |
bbmax[0] = bbmax[1] = bbmax[2] = -FHUGE;
| 135 |
for (i = startobj; i < nobjects; i++)
| 136 |
add2bbox(objptr(i), bbmin, bbmax);
| 137 |
/* set/check cube */
| 138 |
if (thescene.cusize == 0.0) {
| 139 |
if (bbmin[0] <= bbmax[0]) {
| 140 |
for (i = 0; i < 3; i++) {
| 141 |
bbmin[i] -= OMARGIN;
| 142 |
bbmax[i] += OMARGIN;
| 143 |
| 144 |
| 145 |
if (bbmax[i] - bbmin[i] > thescene.cusize)
| 146 |
thescene.cusize = bbmax[i] - bbmin[i];
| 147 |
| 148 |
thescene.cuorg[i] =
| 149 |
(bbmax[i]+bbmin[i]-thescene.cusize)*.5;
| 150 |
| 151 |
} else {
| 152 |
| 153 |
if (bbmin[i] < thescene.cuorg[i] ||
| 154 |
bbmax[i] > thescene.cuorg[i] + thescene.cusize)
| 155 |
error(USER, "boundary does not encompass scene");
| 156 |
| 157 |
| 158 |
mincusize = thescene.cusize / resolu - FTINY;
| 159 |
| 160 |
for (i = startobj; i < nobjects; i++) /* add new objects */
| 161 |
addobject(&thescene, i);
| 162 |
| 163 |
thescene.cutree = combine(thescene.cutree); /* optimize */
| 164 |
| 165 |
writeoct(outflags, &thescene, ofname); /* write structures to stdout */
| 166 |
| 167 |
quit(0);
| 168 |
| 169 |
| 170 |
| 171 |
quit(code) /* exit program */
| 172 |
int code;
| 173 |
| 174 |
exit(code);
| 175 |
| 176 |
| 177 |
| 178 |
cputs() /* interactive error */
| 179 |
| 180 |
/* referenced, but not used */
| 181 |
| 182 |
| 183 |
| 184 |
wputs(s) /* warning message */
| 185 |
char *s;
| 186 |
| 187 |
if (!nowarn)
| 188 |
eputs(s);
| 189 |
| 190 |
| 191 |
| 192 |
eputs(s) /* put string to stderr */
| 193 |
register char *s;
| 194 |
| 195 |
static int inln = 0;
| 196 |
| 197 |
if (!inln++) {
| 198 |
fputs(progname, stderr);
| 199 |
fputs(": ", stderr);
| 200 |
| 201 |
fputs(s, stderr);
| 202 |
if (*s && s[strlen(s)-1] == '\n')
| 203 |
inln = 0;
| 204 |
| 205 |
| 206 |
| 207 |
#define bitop(f,i,op) (f[((i)>>3)] op (1<<((i)&7)))
| 208 |
#define tstbit(f,i) bitop(f,i,&)
| 209 |
#define setbit(f,i) bitop(f,i,|=)
| 210 |
#define clrbit(f,i) bitop(f,i,&=~)
| 211 |
#define tglbit(f,i) bitop(f,i,^=)
| 212 |
| 213 |
| 214 |
addobject(cu, obj) /* add an object to a cube */
| 215 |
register CUBE *cu;
| 216 |
OBJECT obj;
| 217 |
| 218 |
CUBE cukid;
| 219 |
OCTREE ot;
| 220 |
OBJECT oset[MAXSET+1];
| 221 |
unsigned char inflg[(MAXSET+7)/8], volflg[(MAXSET+7)/8];
| 222 |
int in;
| 223 |
register int i, j;
| 224 |
| 225 |
in = (*ofun[objptr(obj)->otype].funp)(objptr(obj), cu);
| 226 |
| 227 |
if (in == O_MISS)
| 228 |
return; /* no intersection */
| 229 |
| 230 |
if (istree(cu->cutree)) {
| 231 |
/* do children */
| 232 |
cukid.cusize = cu->cusize * 0.5;
| 233 |
for (i = 0; i < 8; i++) {
| 234 |
cukid.cutree = octkid(cu->cutree, i);
| 235 |
for (j = 0; j < 3; j++) {
| 236 |
cukid.cuorg[j] = cu->cuorg[j];
| 237 |
if ((1<<j) & i)
| 238 |
cukid.cuorg[j] += cukid.cusize;
| 239 |
| 240 |
addobject(&cukid, obj);
| 241 |
octkid(cu->cutree, i) = cukid.cutree;
| 242 |
| 243 |
return;
| 244 |
| 245 |
if (isempty(cu->cutree)) {
| 246 |
/* singular set */
| 247 |
oset[0] = 1; oset[1] = obj;
| 248 |
cu->cutree = fullnode(oset);
| 249 |
return;
| 250 |
| 251 |
/* add to full node */
| 252 |
objset(oset, cu->cutree);
| 253 |
| 254 |
| 255 |
if (in==O_IN || oset[0] < objlim || cukid.cusize < mincusize) {
| 256 |
/* add to set */
| 257 |
if (oset[0] >= MAXSET) {
| 258 |
sprintf(errmsg, "set overflow in addobject (%s)",
| 259 |
objptr(obj)->oname);
| 260 |
error(INTERNAL, errmsg);
| 261 |
| 262 |
insertelem(oset, obj);
| 263 |
| 264 |
return;
| 265 |
| 266 |
/* subdivide cube */
| 267 |
if ((ot = octalloc()) == EMPTY)
| 268 |
error(SYSTEM, "out of octree space");
| 269 |
/* mark volumes */
| 270 |
j = (oset[0]+7)>>3;
| 271 |
while (j--)
| 272 |
volflg[j] = inflg[j] = 0;
| 273 |
for (j = 1; j <= oset[0]; j++)
| 274 |
if (isvolume(objptr(oset[j])->otype)) {
| 275 |
setbit(volflg,j-1);
| 276 |
if ((*ofun[objptr(oset[j])->otype].funp)
| 277 |
(objptr(oset[j]), cu) == O_IN)
| 278 |
setbit(inflg,j-1);
| 279 |
| 280 |
/* assign subcubes */
| 281 |
| 282 |
cukid.cutree = EMPTY;
| 283 |
| 284 |
| 285 |
if ((1<<j) & i)
| 286 |
| 287 |
| 288 |
/* surfaces first */
| 289 |
| 290 |
if (!tstbit(volflg,j-1))
| 291 |
addobject(&cukid, oset[j]);
| 292 |
/* then this object */
| 293 |
| 294 |
/* then partial volumes */
| 295 |
| 296 |
if (tstbit(volflg,j-1) &&
| 297 |
!tstbit(inflg,j-1))
| 298 |
| 299 |
/* full volumes last */
| 300 |
| 301 |
if (tstbit(inflg,j-1))
| 302 |
| 303 |
/* returned node */
| 304 |
octkid(ot, i) = cukid.cutree;
| 305 |
| 306 |
cu->cutree = ot;
| 307 |
