1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* oconv.c - main program for object to octree conversion. |
9 |
10 |
* 7/29/85 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "octree.h" |
16 |
17 |
#include "object.h" |
18 |
19 |
#include "otypes.h" |
20 |
21 |
#include "paths.h" |
22 |
23 |
#define OMARGIN (10*FTINY) /* margin around global cube */ |
24 |
25 |
#define MAXOBJFIL 127 /* maximum number of scene files */ |
26 |
27 |
char *progname; /* argv[0] */ |
28 |
29 |
int nowarn = 0; /* supress warnings? */ |
30 |
31 |
int objlim = 5; /* # of objects before split */ |
32 |
33 |
int resolu = 1024; /* octree resolution limit */ |
34 |
35 |
CUBE thescene = {EMPTY, {0.0, 0.0, 0.0}, 0.0}; /* our scene */ |
36 |
37 |
char *ofname[MAXOBJFIL+1]; /* object file names */ |
38 |
int nfiles = 0; /* number of object files */ |
39 |
40 |
double mincusize; /* minimum cube size from resolu */ |
41 |
42 |
int (*addobjnotify[])() = {NULL}; /* new object notifier functions */ |
43 |
44 |
45 |
main(argc, argv) /* convert object files to an octree */ |
46 |
int argc; |
47 |
char *argv[]; |
48 |
49 |
FVECT bbmin, bbmax; |
50 |
char *infile = NULL; |
51 |
int inpfrozen = 0; |
52 |
int outflags = IO_ALL; |
53 |
OBJECT startobj; |
54 |
int i; |
55 |
56 |
progname = argv[0] = fixargv0(argv[0]); |
57 |
58 |
initotypes(); |
59 |
60 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
61 |
switch (argv[i][1]) { |
62 |
case '\0': /* scene from stdin */ |
63 |
goto breakopt; |
64 |
case 'i': /* input octree */ |
65 |
infile = argv[++i]; |
66 |
break; |
67 |
case 'b': /* bounding cube */ |
68 |
thescene.cuorg[0] = atof(argv[++i]) - OMARGIN; |
69 |
thescene.cuorg[1] = atof(argv[++i]) - OMARGIN; |
70 |
thescene.cuorg[2] = atof(argv[++i]) - OMARGIN; |
71 |
thescene.cusize = atof(argv[++i]) + 2*OMARGIN; |
72 |
break; |
73 |
case 'n': /* set limit */ |
74 |
objlim = atoi(argv[++i]); |
75 |
break; |
76 |
case 'r': /* resolution limit */ |
77 |
resolu = atoi(argv[++i]); |
78 |
break; |
79 |
case 'f': /* freeze octree */ |
80 |
outflags &= ~IO_FILES; |
81 |
break; |
82 |
case 'w': /* supress warnings */ |
83 |
nowarn = 1; |
84 |
break; |
85 |
default: |
86 |
sprintf(errmsg, "unknown option: '%s'", argv[i]); |
87 |
error(USER, errmsg); |
88 |
break; |
89 |
90 |
breakopt: |
91 |
#ifdef MSDOS |
92 |
setmode(fileno(stdout), O_BINARY); |
93 |
#endif |
94 |
if (infile != NULL) { /* get old octree & objects */ |
95 |
if (thescene.cusize > FTINY) |
96 |
error(USER, "only one of '-b' or '-i'"); |
97 |
nfiles = readoct(infile, IO_ALL, &thescene, ofname); |
98 |
if (nfiles == 0) |
99 |
inpfrozen++; |
100 |
} else |
101 |
newheader("RADIANCE", stdout); /* new binary file header */ |
102 |
printargs(argc, argv, stdout); |
103 |
fputformat(OCTFMT, stdout); |
104 |
printf("\n"); |
105 |
106 |
startobj = nobjects; /* previous objects already converted */ |
107 |
108 |
for ( ; i < argc; i++) /* read new scene descriptions */ |
109 |
if (!strcmp(argv[i], "-")) { /* from stdin */ |
110 |
readobj(NULL); |
111 |
112 |
} else { /* from file */ |
113 |
if (nfiles >= MAXOBJFIL) |
114 |
error(INTERNAL, "too many scene files"); |
115 |
readobj(ofname[nfiles++] = argv[i]); |
116 |
117 |
118 |
ofname[nfiles] = NULL; |
119 |
120 |
if (inpfrozen && outflags & IO_FILES) { |
121 |
error(WARNING, "frozen octree"); |
122 |
123 |
124 |
/* find bounding box */ |
125 |
bbmin[0] = bbmin[1] = bbmin[2] = FHUGE; |
126 |
bbmax[0] = bbmax[1] = bbmax[2] = -FHUGE; |
127 |
for (i = startobj; i < nobjects; i++) |
128 |
add2bbox(objptr(i), bbmin, bbmax); |
129 |
/* set/check cube */ |
130 |
if (thescene.cusize == 0.0) { |
131 |
if (bbmin[0] <= bbmax[0]) { |
132 |
for (i = 0; i < 3; i++) { |
133 |
bbmin[i] -= OMARGIN; |
134 |
bbmax[i] += OMARGIN; |
135 |
136 |
for (i = 0; i < 3; i++) |
137 |
if (bbmax[i] - bbmin[i] > thescene.cusize) |
138 |
thescene.cusize = bbmax[i] - bbmin[i]; |
139 |
140 |
thescene.cuorg[i] = |
141 |
(bbmax[i]+bbmin[i]-thescene.cusize)*.5; |
142 |
143 |
} else { |
144 |
145 |
if (bbmin[i] < thescene.cuorg[i] || |
146 |
bbmax[i] > thescene.cuorg[i] + thescene.cusize) |
147 |
error(USER, "boundary does not encompass scene"); |
148 |
149 |
150 |
mincusize = thescene.cusize / resolu - FTINY; |
151 |
152 |
for (i = startobj; i < nobjects; i++) /* add new objects */ |
153 |
addobject(&thescene, i); |
154 |
155 |
thescene.cutree = combine(thescene.cutree); /* optimize */ |
156 |
157 |
writeoct(outflags, &thescene, ofname); /* write structures to stdout */ |
158 |
159 |
quit(0); |
160 |
161 |
162 |
163 |
quit(code) /* exit program */ |
164 |
int code; |
165 |
166 |
exit(code); |
167 |
168 |
169 |
170 |
cputs() /* interactive error */ |
171 |
172 |
/* referenced, but not used */ |
173 |
174 |
175 |
176 |
wputs(s) /* warning message */ |
177 |
char *s; |
178 |
179 |
if (!nowarn) |
180 |
eputs(s); |
181 |
182 |
183 |
184 |
eputs(s) /* put string to stderr */ |
185 |
register char *s; |
186 |
187 |
static int inln = 0; |
188 |
189 |
if (!inln++) { |
190 |
fputs(progname, stderr); |
191 |
fputs(": ", stderr); |
192 |
193 |
fputs(s, stderr); |
194 |
if (*s && s[strlen(s)-1] == '\n') |
195 |
inln = 0; |
196 |
197 |
198 |
199 |
#define bitop(f,i,op) (f[((i)>>3)] op (1<<((i)&7))) |
200 |
#define tstbit(f,i) bitop(f,i,&) |
201 |
#define setbit(f,i) bitop(f,i,|=) |
202 |
#define clrbit(f,i) bitop(f,i,&=~) |
203 |
#define tglbit(f,i) bitop(f,i,^=) |
204 |
205 |
206 |
addobject(cu, obj) /* add an object to a cube */ |
207 |
register CUBE *cu; |
208 |
OBJECT obj; |
209 |
210 |
CUBE cukid; |
211 |
OCTREE ot; |
212 |
OBJECT oset[MAXSET+1]; |
213 |
unsigned char inflg[(MAXSET+7)/8], volflg[(MAXSET+7)/8]; |
214 |
int in; |
215 |
register int i, j; |
216 |
217 |
in = (*ofun[objptr(obj)->otype].funp)(objptr(obj), cu); |
218 |
219 |
if (in == O_MISS) |
220 |
return; /* no intersection */ |
221 |
222 |
if (istree(cu->cutree)) { |
223 |
/* do children */ |
224 |
cukid.cusize = cu->cusize * 0.5; |
225 |
for (i = 0; i < 8; i++) { |
226 |
cukid.cutree = octkid(cu->cutree, i); |
227 |
for (j = 0; j < 3; j++) { |
228 |
cukid.cuorg[j] = cu->cuorg[j]; |
229 |
if ((1<<j) & i) |
230 |
cukid.cuorg[j] += cukid.cusize; |
231 |
232 |
addobject(&cukid, obj); |
233 |
octkid(cu->cutree, i) = cukid.cutree; |
234 |
235 |
return; |
236 |
237 |
if (isempty(cu->cutree)) { |
238 |
/* singular set */ |
239 |
oset[0] = 1; oset[1] = obj; |
240 |
cu->cutree = fullnode(oset); |
241 |
return; |
242 |
243 |
/* add to full node */ |
244 |
objset(oset, cu->cutree); |
245 |
246 |
247 |
if (in==O_IN || oset[0] < objlim || cukid.cusize < mincusize) { |
248 |
/* add to set */ |
249 |
if (oset[0] >= MAXSET) { |
250 |
sprintf(errmsg, "set overflow in addobject (%s)", |
251 |
objptr(obj)->oname); |
252 |
error(INTERNAL, errmsg); |
253 |
254 |
insertelem(oset, obj); |
255 |
256 |
return; |
257 |
258 |
/* subdivide cube */ |
259 |
if ((ot = octalloc()) == EMPTY) |
260 |
error(SYSTEM, "out of octree space"); |
261 |
/* mark volumes */ |
262 |
j = (oset[0]+7)>>3; |
263 |
while (j--) |
264 |
volflg[j] = inflg[j] = 0; |
265 |
for (j = 1; j <= oset[0]; j++) |
266 |
if (isvolume(objptr(oset[j])->otype)) { |
267 |
setbit(volflg,j-1); |
268 |
if ((*ofun[objptr(oset[j])->otype].funp) |
269 |
(objptr(oset[j]), cu) == O_IN) |
270 |
setbit(inflg,j-1); |
271 |
272 |
/* assign subcubes */ |
273 |
274 |
cukid.cutree = EMPTY; |
275 |
276 |
277 |
if ((1<<j) & i) |
278 |
279 |
280 |
/* surfaces first */ |
281 |
282 |
if (!tstbit(volflg,j-1)) |
283 |
addobject(&cukid, oset[j]); |
284 |
/* then this object */ |
285 |
286 |
/* then partial volumes */ |
287 |
288 |
if (tstbit(volflg,j-1) && |
289 |
!tstbit(inflg,j-1)) |
290 |
291 |
/* full volumes last */ |
292 |
293 |
if (tstbit(inflg,j-1)) |
294 |
295 |
/* returned node */ |
296 |
octkid(ot, i) = cukid.cutree; |
297 |
298 |
cu->cutree = ot; |
299 |
