root/radiance/ray/src/ot/oconv.c
Revision: 1.4
Committed: Thu Jun 1 19:23:13 1989 UTC (35 years, 9 months ago) by greg
Changes since 1.3: +12 -7 lines
Added ability to read scene from stdin
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * oconv.c - main program for object to octree conversion.
9 *
10 * 7/29/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 #define OMARGIN (10*FTINY) /* margin around global cube */
22
23 #define MAXOBJFIL 63 /* maximum number of scene files */
24
25 char *progname; /* argv[0] */
26
27 char *libpath; /* library search path */
28
29 int nowarn = 0; /* supress warnings? */
30
31 int objlim = 5; /* # of objects before split */
32
33 int resolu = 1024; /* octree resolution limit */
34
35 CUBE thescene = {EMPTY, {0.0, 0.0, 0.0}, 0.0}; /* our scene */
36
37 char *ofname[MAXOBJFIL+1]; /* object file names */
38 int nfiles = 0; /* number of object files */
39
40 double mincusize; /* minimum cube size from resolu */
41
42
43 main(argc, argv) /* convert object files to an octree */
44 int argc;
45 char **argv;
46 {
47 char *getenv();
48 double atof();
49 FVECT bbmin, bbmax;
50 char *infile = NULL;
51 int outflags = IO_ALL;
52 OBJECT startobj;
53 int i;
54
55 progname = argv[0];
56
57 if ((libpath = getenv("RAYPATH")) == NULL)
58 libpath = ":/usr/local/lib/ray";
59
60 for (i = 1; i < argc && argv[i][0] == '-' && argv[i][1]; i++)
61 switch (argv[i][1]) {
62 case 'i': /* input octree */
63 infile = argv[++i];
64 break;
65 case 'b': /* bounding cube */
66 thescene.cuorg[0] = atof(argv[++i]) - OMARGIN;
67 thescene.cuorg[1] = atof(argv[++i]) - OMARGIN;
68 thescene.cuorg[2] = atof(argv[++i]) - OMARGIN;
69 thescene.cusize = atof(argv[++i]) + 2*OMARGIN;
70 break;
71 case 'n': /* set limit */
72 objlim = atoi(argv[++i]);
73 break;
74 case 'r': /* resolution limit */
75 resolu = atoi(argv[++i]);
76 break;
77 case 'f': /* freeze octree */
78 outflags &= ~IO_FILES;
79 break;
80 case 'w': /* supress warnings */
81 nowarn = 1;
82 break;
83 default:
84 sprintf(errmsg, "unknown option: '%s'", argv[i]);
85 error(USER, errmsg);
86 break;
87 }
88
89 if (infile != NULL) { /* get old octree & objects */
90 if (thescene.cusize > FTINY)
91 error(USER, "only one of '-b' or '-i'");
92 nfiles = readoct(infile, IO_ALL, &thescene, ofname);
93 if (nfiles == 0 && outflags & IO_FILES) {
94 error(WARNING, "frozen octree");
95 outflags &= ~IO_FILES;
96 }
97 }
98
99 printargs(argc, argv, stdout); /* info. header */
100 printf("\n");
101
102 startobj = nobjects; /* previous objects already converted */
103
104 for ( ; i < argc; i++) /* read new scene descriptions */
105 if (!strcmp(argv[i], "-")) { /* from stdin */
106 readobj(NULL);
107 outflags &= ~IO_FILES;
108 } else { /* from file */
109 if (nfiles >= MAXOBJFIL)
110 error(INTERNAL, "too many scene files");
111 readobj(ofname[nfiles++] = argv[i]);
112 }
113
114 ofname[nfiles] = NULL;
115 /* find bounding box */
116 bbmin[0] = bbmin[1] = bbmin[2] = FHUGE;
117 bbmax[0] = bbmax[1] = bbmax[2] = -FHUGE;
118 for (i = startobj; i < nobjects; i++)
119 add2bbox(objptr(i), bbmin, bbmax);
120 /* set/check cube */
121 if (thescene.cusize == 0.0) {
122 if (bbmin[0] <= bbmax[0]) {
123 for (i = 0; i < 3; i++) {
124 bbmin[i] -= OMARGIN;
125 bbmax[i] += OMARGIN;
126 }
127 for (i = 0; i < 3; i++)
128 if (bbmax[i] - bbmin[i] > thescene.cusize)
129 thescene.cusize = bbmax[i] - bbmin[i];
130 for (i = 0; i < 3; i++)
131 thescene.cuorg[i] =
132 (bbmax[i]+bbmin[i]-thescene.cusize)*.5;
133 }
134 } else {
135 for (i = 0; i < 3; i++)
136 if (bbmin[i] < thescene.cuorg[i] ||
137 bbmax[i] > thescene.cuorg[i] + thescene.cusize)
138 error(USER, "boundary does not encompass scene");
139 }
140
141 mincusize = thescene.cusize / resolu - FTINY;
142
143 for (i = startobj; i < nobjects; i++) /* add new objects */
144 addobject(&thescene, i);
145
146 thescene.cutree = combine(thescene.cutree); /* optimize */
147
148 writeoct(outflags, &thescene, ofname); /* write structures to stdout */
149
150 quit(0);
151 }
152
153
154 quit(code) /* exit program */
155 int code;
156 {
157 exit(code);
158 }
159
160
161 cputs() /* interactive error */
162 {
163 /* referenced, but not used */
164 }
165
166
167 wputs(s) /* warning message */
168 char *s;
169 {
170 if (!nowarn)
171 eputs(s);
172 }
173
174
175 eputs(s) /* put string to stderr */
176 register char *s;
177 {
178 static int inline = 0;
179
180 if (!inline++) {
181 fputs(progname, stderr);
182 fputs(": ", stderr);
183 }
184 fputs(s, stderr);
185 if (*s && s[strlen(s)-1] == '\n')
186 inline = 0;
187 }
188
189
190 addobject(cu, obj) /* add an object to a cube */
191 register CUBE *cu;
192 OBJECT obj;
193 {
194 CUBE cukid;
195 OCTREE ot;
196 OBJECT oset[MAXSET+1];
197 int in;
198 register int i, j;
199
200 in = (*ofun[objptr(obj)->otype].funp)(objptr(obj), cu);
201
202 if (!in)
203 return; /* no intersection */
204
205 if (istree(cu->cutree)) {
206 /* do children */
207 cukid.cusize = cu->cusize * 0.5;
208 for (i = 0; i < 8; i++) {
209 cukid.cutree = octkid(cu->cutree, i);
210 for (j = 0; j < 3; j++) {
211 cukid.cuorg[j] = cu->cuorg[j];
212 if ((1<<j) & i)
213 cukid.cuorg[j] += cukid.cusize;
214 }
215 addobject(&cukid, obj);
216 octkid(cu->cutree, i) = cukid.cutree;
217 }
218
219 } else if (isempty(cu->cutree)) {
220 /* singular set */
221 oset[0] = 1; oset[1] = obj;
222 cu->cutree = fullnode(oset);
223
224 } else {
225 /* add to full node */
226 objset(oset, cu->cutree);
227 cukid.cusize = cu->cusize * 0.5;
228
229 if (in == 2 || oset[0] < objlim || cukid.cusize < mincusize) {
230 /* add to set */
231 if (oset[0] >= MAXSET) {
232 sprintf(errmsg,
233 "set overflow in addobject (%s)",
234 objptr(obj)->oname);
235 error(INTERNAL, errmsg);
236 }
237 insertelem(oset, obj);
238 cu->cutree = fullnode(oset);
239
240 } else {
241 /* subdivide cube */
242 if ((ot = octalloc()) == EMPTY)
243 error(SYSTEM, "out of octree space");
244 for (i = 0; i < 8; i++) {
245 cukid.cutree = EMPTY;
246 for (j = 0; j < 3; j++) {
247 cukid.cuorg[j] = cu->cuorg[j];
248 if ((1<<j) & i)
249 cukid.cuorg[j] += cukid.cusize;
250 }
251 for (j = 1; j <= oset[0]; j++)
252 addobject(&cukid, oset[j]);
253 addobject(&cukid, obj);
254 octkid(ot, i) = cukid.cutree;
255 }
256 cu->cutree = ot;
257 }
258 }
259 }
