root/radiance/ray/src/ot/oconv.c
Revision: 1.1
Committed: Thu Feb 2 10:33:04 1989 UTC (36 years, 4 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * oconv.c - main program for object to octree conversion.
9 *
10 * 7/29/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 #define MAXOBJFIL 63 /* maximum number of scene files */
22
23 char *progname; /* argv[0] */
24
25 char *libpath; /* library search path */
26
27 int nowarn = 0; /* supress warnings? */
28
29 int objlim = 5; /* # of objects before split */
30
31 int resolu = 1024; /* octree resolution limit */
32
33 CUBE thescene = {EMPTY, {0.0, 0.0, 0.0}, 0.0}; /* our scene */
34
35 char *ofname[MAXOBJFIL+1]; /* object file names */
36 int nfiles = 0; /* number of object files */
37
38 double mincusize; /* minimum cube size from resolu */
39
40
41 main(argc, argv) /* convert object files to an octree */
42 int argc;
43 char **argv;
44 {
45 char *getenv();
46 double atof();
47 FVECT bbmin, bbmax;
48 char *infile = NULL;
49 int outflags = IO_ALL;
50 OBJECT startobj;
51 int i;
52
53 progname = argv[0];
54
55 if ((libpath = getenv("RAYPATH")) == NULL)
56 libpath = ":/usr/local/lib/ray";
57
58 for (i = 1; i < argc && argv[i][0] == '-'; i++)
59 switch (argv[i][1]) {
60 case 'i': /* input octree */
61 infile = argv[++i];
62 break;
63 case 'b': /* bounding cube */
64 thescene.cuorg[0] = atof(argv[++i]) - FTINY;
65 thescene.cuorg[1] = atof(argv[++i]) - FTINY;
66 thescene.cuorg[2] = atof(argv[++i]) - FTINY;
67 thescene.cusize = atof(argv[++i]) + 2*FTINY;
68 break;
69 case 'n': /* set limit */
70 objlim = atoi(argv[++i]);
71 break;
72 case 'r': /* resolution limit */
73 resolu = atoi(argv[++i]);
74 break;
75 case 'f': /* freeze octree */
76 outflags &= ~IO_FILES;
77 break;
78 case 'w': /* supress warnings */
79 nowarn = 1;
80 break;
81 default:
82 sprintf(errmsg, "unknown option: '%s'", argv[i]);
83 error(USER, errmsg);
84 break;
85 }
86
87 if (infile != NULL) { /* get old octree & objects */
88 if (thescene.cusize > FTINY)
89 error(USER, "only one of '-b' or '-i'");
90 nfiles = readoct(infile, IO_ALL, &thescene, ofname);
91 if (nfiles == 0 && outflags & IO_FILES) {
92 error(WARNING, "frozen octree");
93 outflags &= ~IO_FILES;
94 }
95 }
96
97 printargs(argc, argv, stdout); /* info. header */
98 printf("\n");
99
100 startobj = nobjects; /* previous objects already converted */
101
102 for ( ; i < argc; i++) { /* read new files */
103 if (nfiles >= MAXOBJFIL)
104 error(INTERNAL, "too many scene files");
105 readobj(ofname[nfiles++] = argv[i]);
106 }
107 ofname[nfiles] = NULL;
108 /* find bounding box */
109 bbmin[0] = bbmin[1] = bbmin[2] = FHUGE;
110 bbmax[0] = bbmax[1] = bbmax[2] = -FHUGE;
111 for (i = startobj; i < nobjects; i++)
112 add2bbox(objptr(i), bbmin, bbmax);
113 /* set/check cube */
114 if (thescene.cusize == 0.0) {
115 if (bbmin[0] <= bbmax[0]) {
116 for (i = 0; i < 3; i++) {
117 bbmin[i] -= FTINY;
118 bbmax[i] += FTINY;
119 }
120 VCOPY(thescene.cuorg, bbmin);
121 for (i = 0; i < 3; i++)
122 if (bbmax[i] - bbmin[i] > thescene.cusize)
123 thescene.cusize = bbmax[i] - bbmin[i];
124 }
125 } else {
126 for (i = 0; i < 3; i++)
127 if (bbmin[i] < thescene.cuorg[i] ||
128 bbmax[i] > thescene.cuorg[i] + thescene.cusize)
129 error(USER, "boundary does not encompass scene");
130 }
131
132 mincusize = thescene.cusize / resolu - FTINY;
133
134 for (i = startobj; i < nobjects; i++) /* add new objects */
135 addobject(&thescene, i);
136
137 thescene.cutree = combine(thescene.cutree); /* optimize */
138
139 writeoct(outflags, &thescene, ofname); /* write structures to stdout */
140
141 quit(0);
142 }
143
144
145 quit(code) /* exit program */
146 int code;
147 {
148 exit(code);
149 }
150
151
152 cputs() /* interactive error */
153 {
154 /* referenced, but not used */
155 }
156
157
158 wputs(s) /* warning message */
159 char *s;
160 {
161 if (!nowarn)
162 eputs(s);
163 }
164
165
166 eputs(s) /* put string to stderr */
167 register char *s;
168 {
169 static int inline = 0;
170
171 if (!inline++) {
172 fputs(progname, stderr);
173 fputs(": ", stderr);
174 }
175 fputs(s, stderr);
176 if (*s && s[strlen(s)-1] == '\n')
177 inline = 0;
178 }
179
180
181 addobject(cu, obj) /* add an object to a cube */
182 register CUBE *cu;
183 OBJECT obj;
184 {
185 CUBE cukid;
186 OCTREE ot;
187 OBJECT oset[MAXSET+1];
188 int in;
189 register int i, j;
190
191 in = (*ofun[objptr(obj)->otype].funp)(objptr(obj), cu);
192
193 if (!in)
194 return; /* no intersection */
195
196 if (istree(cu->cutree)) {
197 /* do children */
198 cukid.cusize = cu->cusize * 0.5;
199 for (i = 0; i < 8; i++) {
200 cukid.cutree = octkid(cu->cutree, i);
201 for (j = 0; j < 3; j++) {
202 cukid.cuorg[j] = cu->cuorg[j];
203 if ((1<<j) & i)
204 cukid.cuorg[j] += cukid.cusize;
205 }
206 addobject(&cukid, obj);
207 octkid(cu->cutree, i) = cukid.cutree;
208 }
209
210 } else if (isempty(cu->cutree)) {
211 /* singular set */
212 oset[0] = 1; oset[1] = obj;
213 cu->cutree = fullnode(oset);
214
215 } else {
216 /* add to full node */
217 objset(oset, cu->cutree);
218 cukid.cusize = cu->cusize * 0.5;
219
220 if (in == 2 || oset[0] < objlim || cukid.cusize < mincusize) {
221 /* add to set */
222 if (oset[0] >= MAXSET) {
223 sprintf(errmsg,
224 "set overflow in addobject (%s)",
225 objptr(obj)->oname);
226 error(INTERNAL, errmsg);
227 }
228 insertelem(oset, obj);
229 cu->cutree = fullnode(oset);
230
231 } else {
232 /* subdivide cube */
233 if ((ot = octalloc()) == EMPTY)
234 error(SYSTEM, "out of octree space");
235 for (i = 0; i < 8; i++) {
236 cukid.cutree = EMPTY;
237 for (j = 0; j < 3; j++) {
238 cukid.cuorg[j] = cu->cuorg[j];
239 if ((1<<j) & i)
240 cukid.cuorg[j] += cukid.cusize;
241 }
242 for (j = 1; j <= oset[0]; j++)
243 addobject(&cukid, oset[j]);
244 addobject(&cukid, obj);
245 octkid(ot, i) = cukid.cutree;
246 }
247 cu->cutree = ot;
248 }
249 }
250 }
