--- ray/src/ot/oconv.c 1989/06/21 08:56:35 1.5 +++ ray/src/ot/oconv.c 2003/02/22 02:07:26 2.12 @@ -1,9 +1,6 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: oconv.c,v 2.12 2003/02/22 02:07:26 greg Exp $"; #endif - /* * oconv.c - main program for object to octree conversion. * @@ -18,44 +15,44 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" -#define OMARGIN (10*FTINY) /* margin around global cube */ +#include "paths.h" -#define MAXOBJFIL 63 /* maximum number of scene files */ +#define OMARGIN (10*FTINY) /* margin around global cube */ +#define MAXOBJFIL 127 /* maximum number of scene files */ + char *progname; /* argv[0] */ -char *libpath; /* library search path */ - int nowarn = 0; /* supress warnings? */ int objlim = 5; /* # of objects before split */ -int resolu = 1024; /* octree resolution limit */ +int resolu = 8192; /* octree resolution limit */ CUBE thescene = {EMPTY, {0.0, 0.0, 0.0}, 0.0}; /* our scene */ char *ofname[MAXOBJFIL+1]; /* object file names */ int nfiles = 0; /* number of object files */ -double mincusize; /* minimum cube size from resolu */ +double mincusize; /* minimum cube size from resolu */ +void (*addobjnotify[])() = {NULL}; /* new object notifier functions */ + main(argc, argv) /* convert object files to an octree */ int argc; -char **argv; +char *argv[]; { - char *getenv(); - double atof(); FVECT bbmin, bbmax; char *infile = NULL; + int inpfrozen = 0; int outflags = IO_ALL; - OBJECT startobj; + OBJECT startobj; int i; - progname = argv[0]; + progname = argv[0] = fixargv0(argv[0]); - if ((libpath = getenv("RAYPATH")) == NULL) - libpath = ":/usr/local/lib/ray"; + initotypes(); for (i = 1; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { @@ -88,21 +85,23 @@ char **argv; break; } breakopt: +#ifdef MSDOS + setmode(fileno(stdout), O_BINARY); +#endif if (infile != NULL) { /* get old octree & objects */ if (thescene.cusize > FTINY) error(USER, "only one of '-b' or '-i'"); nfiles = readoct(infile, IO_ALL, &thescene, ofname); - if (nfiles == 0 && outflags & IO_FILES) { - error(WARNING, "frozen octree"); - outflags &= ~IO_FILES; - } - } - - printargs(argc, argv, stdout); /* info. header */ + if (nfiles == 0) + inpfrozen++; + } else + newheader("RADIANCE", stdout); /* new binary file header */ + printargs(argc, argv, stdout); + fputformat(OCTFMT, stdout); printf("\n"); startobj = nobjects; /* previous objects already converted */ - + for ( ; i < argc; i++) /* read new scene descriptions */ if (!strcmp(argv[i], "-")) { /* from stdin */ readobj(NULL); @@ -114,6 +113,11 @@ breakopt: } ofname[nfiles] = NULL; + + if (inpfrozen && outflags & IO_FILES) { + error(WARNING, "frozen octree"); + outflags &= ~IO_FILES; + } /* find bounding box */ bbmin[0] = bbmin[1] = bbmin[2] = FHUGE; bbmax[0] = bbmax[1] = bbmax[2] = -FHUGE; @@ -141,10 +145,10 @@ breakopt: } mincusize = thescene.cusize / resolu - FTINY; - + for (i = startobj; i < nobjects; i++) /* add new objects */ addobject(&thescene, i); - + thescene.cutree = combine(thescene.cutree); /* optimize */ writeoct(outflags, &thescene, ofname); /* write structures to stdout */ @@ -153,6 +157,7 @@ breakopt: } +void quit(code) /* exit program */ int code; { @@ -160,12 +165,14 @@ int code; } +void cputs() /* interactive error */ { /* referenced, but not used */ } +void wputs(s) /* warning message */ char *s; { @@ -174,36 +181,45 @@ char *s; } +void eputs(s) /* put string to stderr */ register char *s; { - static int inline = 0; + static int inln = 0; - if (!inline++) { + if (!inln++) { fputs(progname, stderr); fputs(": ", stderr); } fputs(s, stderr); if (*s && s[strlen(s)-1] == '\n') - inline = 0; + inln = 0; } +#define bitop(f,i,op) (f[((i)>>3)] op (1<<((i)&7))) +#define tstbit(f,i) bitop(f,i,&) +#define setbit(f,i) bitop(f,i,|=) +#define clrbit(f,i) bitop(f,i,&=~) +#define tglbit(f,i) bitop(f,i,^=) + + addobject(cu, obj) /* add an object to a cube */ register CUBE *cu; -OBJECT obj; +OBJECT obj; { CUBE cukid; - OCTREE ot; - OBJECT oset[MAXSET+1]; + OCTREE ot; + OBJECT oset[MAXSET+1]; + unsigned char inflg[(MAXSET+7)/8], volflg[(MAXSET+7)/8]; int in; register int i, j; in = (*ofun[objptr(obj)->otype].funp)(objptr(obj), cu); - if (!in) + if (in == O_MISS) return; /* no intersection */ - + if (istree(cu->cutree)) { /* do children */ cukid.cusize = cu->cusize * 0.5; @@ -217,45 +233,68 @@ OBJECT obj; addobject(&cukid, obj); octkid(cu->cutree, i) = cukid.cutree; } - - } else if (isempty(cu->cutree)) { + return; + } + if (isempty(cu->cutree)) { /* singular set */ oset[0] = 1; oset[1] = obj; cu->cutree = fullnode(oset); - - } else { - /* add to full node */ - objset(oset, cu->cutree); - cukid.cusize = cu->cusize * 0.5; - - if (in == 2 || oset[0] < objlim || cukid.cusize < mincusize) { - /* add to set */ - if (oset[0] >= MAXSET) { - sprintf(errmsg, - "set overflow in addobject (%s)", - objptr(obj)->oname); - error(INTERNAL, errmsg); - } - insertelem(oset, obj); - cu->cutree = fullnode(oset); + return; + } + /* add to full node */ + objset(oset, cu->cutree); + cukid.cusize = cu->cusize * 0.5; - } else { - /* subdivide cube */ - if ((ot = octalloc()) == EMPTY) - error(SYSTEM, "out of octree space"); - for (i = 0; i < 8; i++) { - cukid.cutree = EMPTY; - for (j = 0; j < 3; j++) { - cukid.cuorg[j] = cu->cuorg[j]; - if ((1<cutree = ot; + if (in==O_IN || oset[0] < objlim || cukid.cusize < mincusize) { + /* add to set */ + if (oset[0] >= MAXSET) { + sprintf(errmsg, "set overflow in addobject (%s)", + objptr(obj)->oname); + error(INTERNAL, errmsg); } + insertelem(oset, obj); + cu->cutree = fullnode(oset); + return; } + /* subdivide cube */ + if ((ot = octalloc()) == EMPTY) + error(SYSTEM, "out of octree space"); + /* mark volumes */ + j = (oset[0]+7)>>3; + while (j--) + volflg[j] = inflg[j] = 0; + for (j = 1; j <= oset[0]; j++) + if (isvolume(objptr(oset[j])->otype)) { + setbit(volflg,j-1); + if ((*ofun[objptr(oset[j])->otype].funp) + (objptr(oset[j]), cu) == O_IN) + setbit(inflg,j-1); + } + /* assign subcubes */ + for (i = 0; i < 8; i++) { + cukid.cutree = EMPTY; + for (j = 0; j < 3; j++) { + cukid.cuorg[j] = cu->cuorg[j]; + if ((1<cutree = ot; }
